Question about Continental PS78111 Compact Refrigerator
Ps78139 icemaker not getting water to ice tray
  • 778 Answers
Hello, Check the water line coming into the back of the refrigerator to make sure not kinked. First replace inline water filter. If that doesn't fix, then the icemaker will have to be replaced.
Posted on May 16, 2014
Ice maker overfills the ice tray, ejecting large block of ice instead of individual cubes.
What is your model number? Sounds like you may need a new icemaker. Sometimes when the icemaker motor goes bad it causes the icemaker to keep filling even though it hasn't kicked out the ice in there. Also, are you sure there isn't 2 valves on the refrigerator?
Nov 15, 2015 | Refrigerators
Ice wont come out of automatic dispenser
If there is frozen ice in the icemaker tray then the heater element to slightly warm the tray for ice ejection is not working. If there is nada in the icemaker tray then water is not getting to unit - check water solenoid or the water line going to unit.
Nov 20, 2013 | Freezers
My icemaker fills the tray but when the water shuts off it drips on the the ledge under the tray and ice builds up. Also now my ice cube tray seems to be leaking.Are parts available or does the entire unit...
My ice maker would not return to a level position after dumping out the ice. When the water turned on to refill the ice tray, it would run off the tilted ice tray and into the ice basket thus freezing all the ice cubes in the basket together. To remove the icemaker, there are two screws that hold the icemaker to the top of the freezer. Turn off the icemaker. Remove the left screw and loosen the right screw by removing the screw on the left. Slide the icemaker outward and it should come loose. Unplug the power connector from the icemaker to the freezer. The ice tray can be removed from the icemaker by gently pulling the tray to the right and the slot it goes into on the left side of the icemaker to the left. Once the tray is out of the assembly, inspect the round plastic shaft on the left side of the ice tray. Mine had two flat spots that were worn into the plastic from use. I used a dremel tool with a round barrel sanding disk at the tools lowest speed to remove the flat spots and decrease the overall diameter of the shaft which stopped the tray from sticking. Reassemble the ice tray in the icemaker.
Mar 10, 2010 | LG LSC26905TT Side by Side Refrigerator
Icemaker not producing ice
you need to troubleshoot the problem, if the wire arm that tells the ice maker to stop making ice when full is in the upright position the ice maker will not make ice. the problem has to be either the switch on this arm malfunction. but probably in MOST cases it is your electronic water valve which has gone out. this is located on the water supply line on the back of the fridge at the bottom probably behind some cardboard or plastic. it is the same kind of water valve as a dishwasher uses, if it malfunctions it will not deliver water to your tray, manually fill the tray and put the arm down, if the maker dispenses the ice out of the tray, chances are your electronic valve is broken.
Apr 07, 2009 | Whirlpool ED2FHEXN Side by Side...
Icemaker does not make ice after first harvest.
theres whats called a cam inside of the ice maker and that is more than like;ly the problem. you can but your own ice maker from place like first service. good luck.
Jan 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool Refrigerator Model ED25PW Ice maker tray not filling with water
Just had this issue - after checking all line connections, I pulled the ice maker feed water line from the back of the unit and found the tube was blocked with ice. Melted the ice with some hot water, and all is good once more. I would check for this before getting into the solinoid.
Aug 27, 2008 | Refrigerators
Ice machine not making ice
Hi, everak11,
Three possible solutions for you.
1: No water coming in from inlet valve. Check voltage on inlet if you have voltage and no water then replace valve.
2:Icemaker not cycleing. Lift the arm on the icemaker to shut it off and leave it for about an hour. Come back in and turn the icemake back on by lowering the arm. If the icemaker does not begin a new cycle and the arm start rising then the problem is most likely an icemaker. Replace Icemaker
3:Refrigerator not cold enough. If the freezer is not getting cold enough the icemaker will not cycle. Check the temperature in the freezer and make sure it is getting down to 0 degrees. If not then you may have another problem with your refrigerator. I hope this helps you, Let me know if you have any other questions or symptoms. Mike
May 08, 2008 | Refrigerators
Hotpoint HSS25GFP icemaker stopped working
are u sure that model # Is right.. DOnt come up in any of my model data bases Seems like u might of got a bad icemaker.. if the water is coming into the icemaker from the water valve.. icemaker has to have power, to do that... all funtions after that would be controled by the iceaker .. The only other thing i can think of is your refrigerator has to be a certain temp to activate icemaker somewhere around 0 give or take some to be safe
Aug 21, 2007 | Hotpoint HSS25GFP Side by Side...
Side by side fridge / freezer - Icemaker problems
What kind of ice maker do you have? Is it "Ice Maker Plus"? Pull the ice bucket out so you can get a better view. On the back of the freezer is a spout ramp that should connect to the back of the ice tray water deflector that the wire connects to. (I know, It's cold in there). The water deflector is connected to the back of the ice tray which sends the water to the tray. It should snap in.
Jul 06, 2007 | Whirlpool ED2FHSS Side by Side...
Continental PS78111 Compact Refrigerator Logo
Top Continental Refrigerators Experts
John Tripp
John Tripp
Tom Chichester
Are you a Continental Refrigerator Expert? Answer questions, earn points and help others
