Question about INTEX Sand Filter Pump
Sand in little window on intex sand filter
Why is there sand in the little window?
  • Intex Master
  • 1,631 Answers
That is not too alarming, if you are getting sand in the pool under the return line, then you could have a broken lateral assembly in the filter.
Posted on May 27, 2014
4 Suggested Answers
  • 8404 Answers
SOURCE: my intex sand filter is
You have a broken "lateral". You will have to remove the sand from the filter, find and replace the broken lateral (pipe with slots in it in the bottom of the filter). When you are ready to refill the sand, put enough water in the filter to cover the laterals (several inches actually) to avoid damaging them as you fill.
Thanks for allowing me to assist you this evening @ FixYa.com
Posted on Jun 22, 2011
  • 22 Answers
SOURCE: intex sand filter motor will not run
Opening the little drain plug at the bottom should relieve the pressure and make it easier to turn the basket lid. Is there water to the top of the basket? I had to loosen the clear top of the basket to bleed the air out. If you open the drain where you backwash, will water flow out? It should. Mine flowed out even without the motor running if I remember correctly. If it does not, my guess would be some kind of obstruction.
Increase Engine Horsepower.
Posted on Jun 02, 2012
Testimonial: "Thank you, found hair in impellar once I cleaned it out worked perfectlty"
hunter19_46m
  • 7482 Answers
SOURCE: Leaky Leaf Filter On Intex Sand Filter
Hi thevideowatc
Check your o-ring seal to make sure it doesn't have sand under or on it, also it may have cracks in it, or the filter may have cracks in the housing...if that is so, then replace the housing.
Bud
Posted on Apr 14, 2013
I have a new Intex sand filter 3000gph I shut it off to backflush it and it will not turn on its not the electrical source any suggestions?
Intex 2650 gal/hr Sand Filter Pump Setup Instructions ...
? 10:52
www.youtube.com/watch?v=uS_95spxFaM
Feb 3, 2011 - Uploaded by Blue Fade Marketplace This video show in detail how to setup the Intex 2650 gal/hr Sand Filter ... 16" Intex 2650 gph Pool Sand Filter Pump Instructional Video 56671 ...
Jul 23, 2015 | Intex Garden
Intex sand filter is noisy
these pumps on these things do make a lot noise (so much i found it's scare's deer from my yard thats eating my apple trees)
air trapped inside sand filter makes noise as well this will work it's way out after time
Jun 22, 2014 | INTEX Sand Filter Pump
How to prime a sand filter pump
use a garden hose connected to house supply to fill the housing and pump head , after that Pump should be able to take over and use water pulled from skimmer , if all your joints and seals are good , if it looses prime ,even after resting for a little while , ck all your joints and seals for leaks ,remember not all leaks ,Leak Out some leak In !!
Apr 23, 2014 | INTEX Sand Filter Pump
Wish to upgrade cartridge filter pump to sand filter pump. Pool size 15' X 48" / pump 1000 gph - 637R /Item no 56945 Which intex sand filter is the best one?
First, understand that sand doesn't filter as finely as cartridges, so "upgrade" may be the wrong word. Cartridges filter down to about 10 microns, sand filters to 25-30 microns. (i.e.the cartridge will catch particles up to 3X smaller than sand will.)
If you still want to change, get the biggest sand filter available that you can comfortably afford. For superior results look at above ground pump/filter packages built by Hayward or Pentair. Intex products are just built to margin and are not designed for long term usage.
Aug 31, 2013 | Intex "" Metal Frame Pool Set (56998e)...
Intex sand filter not working
timer set to bypass? try ON if all good , timer is bad look for water damage sometimes water gets inside and rusts stuff all up
Jun 17, 2013 | INTEX Sand Filter Pump
Hi thevideowatc
Bud
Apr 13, 2013 | INTEX Sand Filter Pump
Intex sand filter has low pressure
to low a pressure on a sand filter most often is caused by a improper sand charge inside it
Sep 21, 2012 | INTEX Sand Filter Pump
Intex sand filter motor will not run
Jun 02, 2012 | INTEX Sand Filter Pump
My intex sand filter is shooting sand into the pool
Jun 22, 2011 | INTEX Sand Filter Pump
INTEX Sand Filter Pump Logo
250 people viewed this question
Top Intex Garden Experts
Charles T Nevin
Charles T Nevin
Tom Chichester
Bill Boyd
Are you an Intex Garden Expert? Answer questions, earn points and help others
