Question about Dishwashers
ADG 7470/1 Dishwasher has no power, checked the main plug fuse, elec going to machine but nothing lighting up or working HELP !
melnavz
  • 1226 Answers
SOURCE: Kenmore Elite Dishwasher will not start
Consider examine inside there is maybe fuse busted on the panel or in the circuit through the control panel of the machine.
Posted on Feb 06, 2008
SOURCE: Whirlpool ADG 6340 Dishwasher
fault 7 is a fill fault . If you take the left side panel off you will see a white plastic tank . The sensor in the tank has failed
Posted on Jun 23, 2008
  • 171 Answers
SOURCE: Dishwasher stopped working..!!..!! please help
Hi crystal245,
I'm Harvey the Master Plumber.
Your problem is: GE Nautilus Dishwasher suddenly stopped working. NOTHING!! it was fine one day then went kaput the next. I checked the plug in and the circuit breaker but still NOTHING
I run into this often. Ends up being loose, broken or burnt ellectrical connection in d/w junction box most of the time. It's under the d/w behind the kick plate on the right or center. Turn the power off first and remove the wire nuts. Replace wire nuts and/or repair wire ends as nessessary. Beyond that you're looking at a bad control board or failed connection in the unit.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
  • 1462 Answers
SOURCE: I have an AEG Oko
there is no fuse or breaker in appliance.
take outer door panel off and check for breakage in the wiring loom where it enters the bottom of the door. check also the door interlock is operating ok
Posted on Nov 12, 2008
SOURCE: Faulty Diplomat Dishwasher - tripping mains fuse
My dishwasher a diplomat 12 program (hja8640) was doing exactly the same where every now and again when turned on at the plug it would trip. After engineers coming out several times and failing to fix it, they condemed it. New one was supplied, however did exactly the same thing. The electrician came back, checked the RCD power breaker and this was fine. It was then discovered that some dishwashers and washing machines send out a lot of earth leakage, combine this with other appliances on in the house can be enough to trip.
Soloution. The electrician removed the kitchen circut from the RCD breaker and intalled another breaker RCD just for the kitcehn loop, this therefore means that the kitchen has a seperate trip from the rest of the house, and touch wood, has solved the problem. This mind you has taken about three months to work out so i hope it saves you some time.
Always use a fully qualified electrician though.
Thanks.
Posted on Jan 09, 2009
During any cycle selected or part of the cycle the machine stops and beeps repeatedly I have to reset machine,sometimes it works fine and completes the cycle more often it takes a few attempts.
could be the door switch or the main control board . only a service tech can tell you for sure .but not listing a MAKE and MODEL does not help anyone help you
Nov 26, 2015 | Dishwashers
Dishwasher does not turn on
This is a long shot but on some dishwashers and washing machines if the drain pump is faulty the machine will not power on. Not saying it's the case with yours but easy to check and nothing to lose
Oct 31, 2015 | Frigidaire Dishwashers
The dishwasher does nothing like it isn't getting any power. No lights or anything. The disposal is plugged in the same outlet and it works.
the first place to start is with the main fuse if it is still intact then its a mains power component. and this will require a pro tech to trace and repair
Jun 30, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool adg 7540 no power
HI, there are four problem spots that i recommend checking. these are the most common hot spots for a non responsive dishwasher. Check each area thoroughly to address this issue.
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Jul 25, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Frigidaire dishwasher fdb2415lf will not turn on. Was working fine, no fuse blown, not disconnected.
I have one of these modles and yesterday after it finished I noticed a lilttle green light on below the main options, a little lock that is telling me to "hold to unlock" not sure what that means, so tried this morning to "hold" nothing happened as need to run the machine, and right now there is no response. HELP!!!!!!!
May 31, 2009 | Frigidaire 24 in. FDBB944C Built-in...
Our bosch dishwasher is not working, when we press the button to turn on nothing happens, no lights, nothing, we have checked the fuse and thats ok. many thanks gail
you may have to turn off power at main box, and check wires at bottom of machine and any other junction box , from dishwasher to main power box. pull on wires to see if they will come apart.
Oct 30, 2008 | Bosch Dishwashers
I have no power on my dishwasher. I ran an extension cord to another outlet that I know has power and still nothing. I don have any led lights or anything. Can you help. GE model # GHDA960K03BB. Thank...
Few components may cause power failure to your Dishwasher.
1. Disconnect your power plug from the socket outlet.
2. Trace the cord to where it connected to your dishwasher.
3. Tight those connectors firmly .
4. Plug back your dishwasher power cord .Start your dishwasher.
If nothing happen, check if control board came with fuse or bimetal. check the continuity of the fuse., You may also check your latch assembly.If no power still change the console or the control board.
Jul 26, 2008 | GE Dishwashers
Whirlpool GEW9200LWO Elec Dryer
just check the fuse and plug pin connection in it
Jul 18, 2008 | Whirlpool GEW9200L Electric Dryer
My dishwasher does not turn on
check socket is ok - plug in something with a light into the same socket as an easy way of checking. otherwise go to where mains terminates on the appliance and check power is actually present - you will need a multi-meter
Jun 19, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
