Question about Dishwashers
Whirlpool ADG 7470/1 Dishwasher has no power,
Checked the main plug fuse was ok, elec going to machine but nothing lighting up or working HELP !
watugot
  • 290 Answers
SOURCE: whirlpool dishwasher stopped working...
It sounds like the thermal fuse in the control console has blown.
Turn power off to unit.
Remove the outer door panel and then the console.
Remove the black plastic cover from over the circuit board if it has one.
You should see the thermal fuse clipped to the circuit board housing.
If you have an ohm meter, check for continuity across it, it should read closed.
If you don't have a meter, unplug the wires from it and and hook them together.
Turn power back on to unit, hold door switches down and cancel cycle. The washer should drain the water.
If this doesn't work, check your door switches to make sure they are closing properly.
Posted on Nov 17, 2007
SOURCE: Whirlpool ADG 6340 Dishwasher
fault 7 is a fill fault . If you take the left side panel off you will see a white plastic tank . The sensor in the tank has failed
Posted on Jun 23, 2008
SOURCE: Whirlpool dishwasher stopped mid cycle
My whirpool dishwasher model ADP4601 is flashing a green light three times and is not doing anything else - any suggestions
Posted on Aug 10, 2008
SOURCE: Whirlpool Dishwasher Model ADG 7560 Unit
found outlet pipe was kinked, stopping water flow
Posted on Sep 09, 2008
SOURCE: Faulty Diplomat Dishwasher - tripping mains fuse
My dishwasher a diplomat 12 program (hja8640) was doing exactly the same where every now and again when turned on at the plug it would trip. After engineers coming out several times and failing to fix it, they condemed it. New one was supplied, however did exactly the same thing. The electrician came back, checked the RCD power breaker and this was fine. It was then discovered that some dishwashers and washing machines send out a lot of earth leakage, combine this with other appliances on in the house can be enough to trip.
Soloution. The electrician removed the kitchen circut from the RCD breaker and intalled another breaker RCD just for the kitcehn loop, this therefore means that the kitchen has a seperate trip from the rest of the house, and touch wood, has solved the problem. This mind you has taken about three months to work out so i hope it saves you some time.
Always use a fully qualified electrician though.
Thanks.
Posted on Jan 09, 2009
No indicator lights Whirlpool wdt710paym dishwasher
If it doesn't run and you have no indicator lights, check the circuit breaker for that outlet. If it is ok, test the output voltage at the plug-in for the machine (115Vac). If it is "live" then check inside the control panel (turn off the breaker first) for a fuse that appears blown. If no fuse problem, CAREFULLY (with breaker back on) see if the main switch is getting power. If it is getting power, the control board is shot...replace it!
Dec 28, 2012 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool dryer dead no power to buttons
I reckon you should take the panel cover off and check the main in line fuse.Assuming you have checked the main fuse.And is ok.There wii be a small white case which has the fuse inside it.The best of luck.
Aug 14, 2012 | Whirlpool Dryers
The dishwasher does nothing like it isn't getting any power. No lights or anything. The disposal is plugged in the same outlet and it works.
the first place to start is with the main fuse if it is still intact then its a mains power component. and this will require a pro tech to trace and repair
Jun 30, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool adg 7540 no power
HI, there are four problem spots that i recommend checking. these are the most common hot spots for a non responsive dishwasher. Check each area thoroughly to address this issue.
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Jul 25, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Front light flashing
Solution to the problem:
Discovered that the dishwasher was covered by our household insurance policy. Phoned and arranged for it to be repaired or replaced (no charge). Engineer coming on Friday.
Jun 10, 2009 | Whirlpool 24 in. ADG6340 Built-in...
Our bosch dishwasher is not working, when we press the button to turn on nothing happens, no lights, nothing, we have checked the fuse and thats ok. many thanks gail
you may have to turn off power at main box, and check wires at bottom of machine and any other junction box , from dishwasher to main power box. pull on wires to see if they will come apart.
Oct 30, 2008 | Bosch Dishwashers
Whirlpool GEW9200LWO Elec Dryer
just check the fuse and plug pin connection in it
Jul 18, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool Dishwasher Not Working
Change the thermal fuse in the control and door switches. The thermal fuse is designed to fail if there is a problem with the switches.
May 17, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
42 people viewed this question
Top Dishwashers Experts
