Peavey xr696f the amplifier blew up all the outputs
    Problem Solver:
  • 8 Answers
This is most likely not anything you can do yourself. You need to find a good electronics technician that repairs PAs, guitars amps etc...
Check with your local music store and inquire about a repair tech.
Posted on Jun 06, 2014
How do i set up a Peavey xr560 mixer and graphic equalizer
PUT OUT PUT EQUALISER IN INPUT RETURN PUT IN PUT EQUALISER TO OUTPUT MIXER
OR JUST PUT EQUALISER BETWEEN MIXER AND AMPLIFIER MEAN OUT PUT EQALISER TO IN PUT AMPLIFIER AND INPUT OF MIXER TO OUT PUT OF MIXER
Oct 12, 2014 | Peavey Audio Players & Recorders
Peavey 150m power amplifier - no audio, hum
Bad caps probably..old unit, do you have a capacitor analyzer...if not you might find a Sencore LC102 to test caps with on ebay...
Jan 16, 2013 | Peavey Xr600b Mixer Amplifier "last One"...
I have a Peavey xr 684 that is blown out on the right or main side but the left or monitor side works just fine. I don't own it but I am trying to fix it for our church. I'm thinking that someone ran the 2...
The first thing to do is check or more likely replace the power output devices (located on the massive heat sink) on the faulty channel. Then look around for burnt and damaged parts. You might need to replace bias resistors on that faulty channel, which are connected with the output devices. If it powers up as it stands the power supply section should be OK.
May 19, 2010 | NAD C350 2-Channel Amplifier
Peavey amp shut down
The output stage has a problem. From your description, I'd guess that the high voltage supply has failed. The low volume and distortion suggests that you are trying to power the speakers from the driver section rather than the outputs. There is a resistor that fails in some of this series. If I remember correctly it is either a 2K or 3K resistor 10 watts in size. If you have no experience with repairs, I'd seek a service shop that is familiar with these units. The part runs between $5-$10.
Dan
May 07, 2010 | Peavey Pv 2600 Power Amplifier
No output on the right side of the peavey 2600 amplifier but the right is ok
Each channel is protected separately. I suspect that the outputs are fried on the right side or the output fuse has blown. This should be checked by a service shop.
Dan
Jul 15, 2009 | Peavey Pv 2600 Power Amplifier
TRANSISTOR TYPES FOR PEAVEY XR684 MIXER AMPLIFIER/ARRANGEMENT
Go to Peavey's website
http://www.peavey.com
You may find what you are looking for here if not you may have to call them.
Jun 30, 2009 | Peavey Pv 2600 Power Amplifier
Peavey 1500 PA amplifier, no output from channel A
is amp configured correct
use same input and same speaker on both sides
check output fuse on A
if fuse ok then problem is inside unit
get tech to open and check all input and output wiring
Jan 12, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Ive bought a Peavey 1500 pa amplifier and would like to know are the a b knobs on the front treble and bass.If they are how would I take the outputs at the back of the amp to my Soundcraft mixer.
The Peavey A/B controls are output gain controls. Your mixers stereo output goes into the amps inputs, channels A & B. The Peavey is the output stage to your speaker system. If you you connect the outputs from a power amp to the inputs of a mixer you will blow the mixers input stage, amongst many other things and possibly damage the amplifier too. The bias (Bass, Mid, Treble controls) are on the mixer, not the amplifier. Unless you are using a mixer amp, which you are not. A PA system DOES NOT work in the same way as an intergrated hi fi amp.
Nov 07, 2008 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
