Question about Haynes Chrysler Mid-size Front-wheel drive Repair Manual for 1982 thru 1995 covering LeBaron Coupe/Convertible, LeBaron GTS, E-Class, New Yorker 4 cyl, Dodge 400, 600, Lancer & Plymouth Caravelle with 2.2, 2.5 and 2.6 liter engines and then the Chrysler LeB
Head bolt torque spec
2.6 head bolts spec
    Sergeant:
  • 194 Answers
65 to 72 Ft. Lbs.
Posted on May 16, 2014
Flywheel torque spec's for 1983 Ford F-100
Could it be a F-150 instead?
Ford Engine Bolt Torque Chart Bolt Torque Spec Chart for Ford Engines
These specs are for stock-type bolts with light engine oil applied to the threads and the underside of the bolt head. Moly and other lubes offer reduced friction and increased bolt tension, which will affect the torque figure. If you use after-market performance bolts like ARP's, you should follow the recommended torque specifications.
260, 289, 302 Torque Spec.
Fastener Type Torque Spec Main cap bolts 60-70 ft-lbs Outer main cap bolts 35-40 ft-lbs. Connecting rod bolts (40-45 ft-lbs. for 289 HP & Boss 302) Cylinder head bolts 65-72 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs Oil pump bolt 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolts 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351W Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 90-100 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs. Oil pump bolts 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351C, 351M Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (45-50 ft-lbs. For Boss 351C) Cylinder head bolts 105 ft-lbs. (125 ft-lbs. For Boss 351C) Rocker arms (non-adjustable) Rocker arms (non-adjustable) 5/16in. intake manifold bolts 21-25 ft-lbs. 3/8in. intake manifold bolts 28-23 ft-lbs Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 9-12 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs. 360, 390, 406, 427, 428FE Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Crossbolts for 406-427 40 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (53-58 ft-lbs. For 406 and 427) Cylinder head bolts 80-90 ft-lbs. (100-110 ft-lbs. For 1963-67 427) Rocker arm shaft bolts 40-45 ft-lbs. Intake manifold bolts 32-35 ft-lbs. Oil pump bolt 12-15 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 429-460 Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 140 ft-lbs. Rocker arms (non-adjustable) 18-22 ft-lbs. Intake manifold bolts 25-30 ft-lbs. Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs.
Dec 18, 2015 | Ford Cars & Trucks
Torque spec's for the fly wheel
Dec 18, 2015 | Cars & Trucks
Need head bolt torque specs for a 1996 saturn sl
Quote:
Originally Posted by norvelplagbao52
1993 saturn sl2 1.9 dohc cylinder head torque
specs and sequence
Cylinder head bolt
tightening procedure:
CYLINDER HEAD BOLT TIGHTENING SEQUENCE:
INTAKE
SIDE
8 4 1 5 9
7 3 2 6 10
EXHAUST SIDE
In sequence,
torque the cylinder head bolts. Torque: 30 Nm (22 ft-lbs).
In sequence,
torque all bolts. Torque: 50 Nm (37 ft-lbs)
In sequence, turn each bolt an
additional 90 degrees.
specs and sequence
Cylinder head bolt
INTAKE
SIDE
8 4 1 5 9
7 3 2 6 10
EXHAUST SIDE
In sequence,
In sequence,
Sep 19, 2013 | 1996 Saturn SL
Husky model VT631502AJ head torque specs
I am certain there are torque specifications but I don't know what they are. You might be able to get them from the manufacturer. Lacking that, determine what the bolt strength (usually indicated by marks on the bolt head) and with the bolt strength and size you can determine what the appropriate torque would be for that size bolt. Too little torque and the head will leak. Too much and you will strip out the threads or twist off the bolt head. A 13mm head is nominally a 1/2", which is not a very large bolt head thus the bolt shank is not going to be particularly large, probably somewhere in the 7 to 9 mm range. Check online for torque specs. If you can't identify the specific bolt strength I would assume it is the lowest normal value for that size bolt. There shouldn't be any particular reason for using high-strength bolts in this type of application.
Aug 03, 2012 | Air Tools & Compressors
1985 sportster 1000cc cylender torque specs
Hi Anonymous, in a criss cross pattern and your torque specs are:
1. 1/4" bolts 10 ft lbs.
2. 5/16" bolts 20 ft lbs.
3. 3/8" bolts 35 ft lbs.
4. 7/16" bolts 55 ft lbs.
5. 1/2" bolts 75 ft lbs.
Have nice day.
Jul 08, 2012 | 1979 Harley Davidson XLH 1000 Sportster
Head bolt torques spec
3.8L V6
cylinder head bolt torque
step 1 37 ft lbs.
step 2 an additional 130 degrees
step 3 4 center bolts an additional 30 degrees
Jul 07, 2010 | 1999 Buick LeSabre
Need to know the head bolts torch specs on 98 toyota v6
heres the torque specs and the way to tighten the head bolts for your 1998 toyota sienna, hope this helps,
12 point bolts step 1- 40 ft lbs
step 2- additional 90 degrees
May 12, 2010 | 1998 Toyota Sienna
Always use new head bolts.
1)tighten to 40ft/lbs
2)back off 1/2 turn
3)tighten back to 40ft/lbs
4)tighten an additional 90 degrees
5)tighten an additional 90 degrees.
Aug 16, 2009 | 1999 Ford Escort
Need to know cylinder head bolt torque specs
Head Bolt Torque For your 1994 Oldsmobile Cutlass Supreme (3.4L SFI DOHC): clearpixel.gif Foot pounds (Final torque) clearpixel.gif Note: Torque sequence --------- | 6 2 3 7 | | 5 1 4 8 | --------- Step 1: torque in sequence to 33 Ft/Lbs Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque. clearpixel.gif clearpixel.gif clearpixel.gif Foot pounds (Final torque) clearpixel.gif Note: Torque sequence --------- | 8 4 1 5 | | 7 3 2 6 | front --------- of engine | 6 2 3 7 | | 5 1 4 8 | Step 1: torque to 40 Ft/Lbs --------- Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque.
Feb 07, 2009 | 1994 Oldsmobile Cutlass Supreme
Need to find specks on cylingder head for 1996 toyota tercel
The cylinder head bolt torque is a 2 step process.
First: Torque all of the bolts to 45 Nm (450 Kgf-cm or 33 ft lbs.)
Replace any head bolt that will not torque to the above specs.
Second: after all ten bolts are torqued to the above specs, the head bolts are then "Torqued to Distance"...
Starting at the center bolts, retorque all ten bolts an additional 90 degrees.
Hope this helps, the graciousness of a FixYa rating would be greatly appreciated.
Jan 21, 2009 | 1996 Toyota Tercel
Haynes Chrysler Mid-size Front-wheel drive Repair Manual for 1982 thru 1995 covering LeBaron Coupe/Convertible, LeBaron GTS, E-Class, New Yorker 4 cyl, Dodge 400, 600, Lancer & Plymouth Caravelle with 2.2, 2.5 and 2.6 liter engines and then the Chrysler LeB Logo
77 people viewed this question
Top Haynes Heating & Cooling Experts
gbob59
Mike
Lawrence Oravetz
Are you a Haynes Heating and Cooling Expert? Answer questions, earn points and help others
