Question about Panasonic Televison & Video
Hrr 222k 1kv - Panasonic Televison & Video
I am trying to readdress remote tv2 21.0 IR/UFH PRO but to receiver DISH network VIP 222k. we have tried every way and it always switches remote address tv1. we tried all the steps from the handbook b
Hello, German Quinchia!
I would be happy to provide assistance on this. It sounds like the remote itself may need to be setup correctly. Since this is going to be the second TV, on the bottom of the remote, make sure there is a blue 2 at the bottom instead of a green 1. Once you have the blue 2 showing, try addressing the remote again.
If the problem persists, remove the battery cover. Inside will be a switch. Make sure the switch is toggled to UHF rather than IR. Let me know here if the problem still continues after that.
Tommy Faust
DISH Social Media Representative
Feb 12, 2013 | DISH Network Televison & Video
Honda HRB 216 Lawn Mower Manual
Sure you don't mean HRR? A number of models can by downloaded from the HRR from:
http://lawnandgarden.manualsonline.com/manuals/
Search using the Lawn and Garden Product Manual Finder which can be found on the left side.
Oct 02, 2010 | Garden
New honda hrr auto choke hard to start
sounds like it may need the carb clening out, but it could be the auto choke not closing when cold. there was an issue with some of the early auto chokes on the gcv135/160 engines so check to see if the choke flap is in the closed position when starting from cold, run the engine for approx 10-15 minutes and see if the choke flap has opened fully.leave it to go cold and see if the choke flap has returned to the closed position
Apr 12, 2010 | Husqvarna 160 CC Honda OHC Engine 21 in
My mower (HRR) was hard to start and then would
It sounds like you are in need of a valve job on it. You can check this by removing the spark plug and holding a finger or thumb tightly over the hole while someone pulls the starter cord. If it doesn't literally "pop" your finger off the hole, you have a leaking valve and need to do a valve job or at the very least a valve adjustment
Oct 26, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
How to install a samsung dvd vcr combo on dish remote
Carlos most Dish remotes do not support combo TV's. However if you follow this link you can select the remote you have and find the device codes there that they do support to see if your tv is indeed supported. Dish has a new remote that is a learning type that is standard with the 222k receiver. The 222k is a dual tuner two room HD receiver without DVR. This receiver and remote may be exactly what you are desiring. I hope this answered your question. Thanks for using Fix Ya and let me know if I can be of further assistance.
Dec 12, 2008 | DISH Network IR Remote Control
I have new Polaroid TV/DVD combo & need code for my dish remote
Dish remotes generally will not program to combo units. There are a few exceptions but if you have already performed a power scan and have not had sucess you have one of the units that will not work. Dish is introducing a new receiver called a 222k which has a learning remote to prevent these types of issues. The 222k is a HD dussl tuner NON dvr receiver.It also has an expansion port that will allow a external hard drive to be connected to it which will allow the receiver to behave as a DVR unit but with added benefits an internal DVR model lacks.
Hope this answered your question and thanks for using FIx Ya. Let me know if I can be of further assistance.
Dec 09, 2008 | DISH Network IR Remote Control
Toshiba Regza not recognized by remote
The only solution you may have is to buy a high end universal remote that will control the Dish receiver as well as your peripherals. Dish also has a new receiver- 222k- that offers learning remotes and expanded product codes to support more tv's.The 222k is a dual tuner two room HD non DVR receiver. I hope this assists you. Thanks for using Fix Ya and let me know if I can further assist you.
Nov 29, 2008 | DISH Network IR Remote Control
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
