Hp designjet 4500 firmware - Office Equipment & Supplies
3 Suggested Answers
SOURCE: updating firmware for HP designjet, use new or original settings?
U can always try to up grade firmware by going to www.mymusix.com
Posted on Oct 06, 2009
pineworks
  • 4041 Answers
SOURCE: hp designjet 4500 error message 84.11:01
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 22, 2010
MCDATA 4500 firmware
The Sphereon 4500 (ES-4500) line was purchased by Brocade when Brocade acquired McData back in 2007. These SAN switches and others were marketed using an OEM/reseller model and HP was one of them along with others. So, this switch may still be under and support contract with either Brocade or via one of the OEMs or resellers. If that is the case, then the firmware may be downloaded from whomever the support contract is with. I'm sorry if this seems very complicated but I wanted to explain why it might come from HP or from others depending on the relationship the switch came from.
Oct 30, 2013 | McDATA Sphereon 4500 Networking Switch
How to hook up fax on a HP 4500 all in one
No fax facility for this models...HP designjet 4500 or deskjet F4500
Jan 04, 2012 | HP Designjet 4500mfp All-In-One InkJet...
When i scan an document the scanner put one red line on the photo. this red line appare when print the document.
Have you cleaned the glass platen of the scanner lately? Sometimes a single particle--or smudge--can cause similar issues.
To be sure, try some glass cleaner. If this fails to work, try the following link to HP's latest driver page, especially the 'firmware upgrade' link toward the bottom:
>>CLICK HERE
Hope this helps!
Feb 24, 2011 | HP Designjet 4500 Pass-Through Scanner
HP Designjet 4500 Scanner error 55-203,55-205. Appears at calibration at alignment of chambers
55-203
Problem:
No movement in camera position has been detected during vertical camera
alignment.
Possible Solutions:
Check all the cables connected to the Camera.
Run the scanner maintenance program.
May 18, 2009 | HP Designjet 4500 Pass-Through Scanner
BONJOUR MONSIEUR :JAI DES PROBLEMES AVEC MON IMPRIMANTE HP500PS
MY DESIGNJET 500 HAVE THE 79:04 ERROR IT WAS JUST CUTTING THE PAPER WHEN THIS OCURR
Mar 03, 2009 | HP DesignJet 500ps (42 in.) InkJet Printer
Deleted files -how to recover?
www.recuva.com ... it's a freeware program but works well recovering deleted files.
Robert
Please take a moment to rate this solution thanks
Jan 30, 2009 | HP Designjet 4500 Pass-Through Scanner
Error code 93:11
System Error: 93:11
Description: Unable to pressurize the IDS.
Corrective Action: Try the following:
Remove ALL the Ink Cartridges and reinstall them one by one in to the Printer.
Replace the Ink Cartridges.
Replace the APS Assembly.
If the System Error continues, replace the Ink Supply Tubes and Trailing Cable.
Dec 29, 2008 | HP Designjet 4500 Pass-Through Scanner
15 people viewed this question
jasbo
jasbo
