Question about Makita 6349DWDE 18V 1/2" MXT Driver - Drill Kit
MAKITA impact driver td020d has no reverse action
rowdy45176
  • 2176 Answers
SOURCE: makita 12v impact driver- no reverse
I would suggest that you go to Makitatools.com and type in your model number and look at the breakdown for complete disassembly procedures. The only problem it could be it the tab on the switch or the shift lever is broken I would have to think it is the switch. Let me know if I can help more.
Posted on Mar 29, 2009
efs_perpends
  • 1996 Answers
SOURCE: Makita 6916D impact driver sick
Do you have a second battery to check whether the fault is with the drill or the battery?
If you have more than one battery and you experience power loss with both, confirm that the charger is charging properly by using a different charger, if possible.
Sounds like it might be time to purchase a new battery. You could take it to a local Makita distributor and try a fresh battery to see if that does it, but after time even these rechargeable batteries need to be replaced.
I'd say that's the culprit 90+% of the time.
Thanks for trying FixYa!
Posted on Mar 30, 2009
SOURCE: Makita 14.4V Cordless Impact Driver only works at high speed
Most cordless drill / drivers like this have electronic switchs which unfortunately would have to be fixed by a repair agent. Depending on it's age - make sure that you tell the agent that it never really worked properly, warrentys only cover parts that were faulty from manufacture and not wear and tear, so it may get fixed for free depending on the repair centre
Posted on May 19, 2009
rowdy45176
  • 2176 Answers
SOURCE: disassemble , houseing makita Model 6935FD Cordless
I would recommend going to Makitatools.com and typing in your model number for a schematic. Basically all you have to do is remove the 4 screws on the front holding the gearcase and then remove all the other screws holding the handle halves together. Let me know if I can help
Posted on Jul 14, 2009
  • 384 Answers
SOURCE: Disassemble a Makita 6980FDWDE Impact driver
Sometimes fasteners are hidden under labels.
Posted on Jul 24, 2009
My makita 6914D impact drill works fine when it will start. Sometimes when I pull the trigger nothing happens on either forward or reverse. When I change batteries it may or may not work . I checke
It could be your brushes are worn down and not fully contacting the armature. If they are very short and the armature comutator looks burnt, you need part number CB424 to replace your brushes. Most likely your problem is the switch. Sometimes the contacts in the switch get dirty or burnt and if you move the switch just right, a clean contact may be made but usually it won't work. The switch is part number 651939-6. Both are available on sites like www.ereplacementparts.com.
Mar 01, 2014 | Makita 6914D 12V 1/4 in. Impact
The screw point got stuck inside of the makita
Low quality steel drill bits get stuck in the Makita because the hammer impact squashes the metal, forming a ridge that gets snagged on the anvil's steel ball bearing. Use only impact drill bits.
Sep 15, 2011 | Makita 18V LXT Lithium - Ion Cordless...
I have a 18 volt makita cordless impact driver i can not get the driver bit out it seems to be stuck in the chuck very tight
Try holding the bit with pliers and running in reverse, maybe with a shot of oil. That might free it up. You can also try tapping it (firmly) on the side of the bit
Aug 18, 2011 | Makita 18V LXT Lithium - Ion Cordless...
My 14.4 volt impact driver just buzzes when you pull the trigger and I can't figure how to get it apart
fist is the battery good, if it is then I would go on line to Makita and look it up for specs
Aug 16, 2011 | Makita 6935FDWDE 14.4 Volt Nimh Cordless...
Hammer on Makita model 6905H corded impact wrench 1/2 size broke.
go to web site there is a parts list for your model and order the part
May 01, 2010 | Makita 1/2" Corded Impact Wrench
My drill is stuck in reverse
Use left hand screws.....or take housing apart to see what has jamed the selector switch.
Jul 28, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Makita 12v impact driver- no reverse
Mar 29, 2009 | Makita 12V Cordless Impact Driver -...
Bit is stuck in btd142 driver
the makita impact drivers are picky about the bit that you use. if you use a single sided bit you have to make sure the distance between the channel and the end is 9mm (3/8) and if you're using a double sided bit you have to make sure the distance from tip to channel is 12mm (15/32)
try using a 1/4" wrench on the bit in reverse while pulling the collar back. if that doesnt work, tap the tip of the bit with a hammer with the collar pulled back
Nov 29, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Makita 6349DWDE 18V 1/2" MXT Driver - Drill Kit Logo
35 people viewed this question
Top Makita Drills Experts
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
