Question about Zodiac Pool & Spa
My zodiac Creepy crawley does not wana sink to the bottom of the pool what could be the problem
    Champion:
    Scholar:
  • Zodiac Expert
  • 239 Answers
The unit is negatively boyant and when filled with water should have no problem sinking to the bottom. you can get weights that go on the hose that will aid in sinking the vac but these are more to adjust the pattern it uses
Posted on Oct 05, 2014
PartsCenter
  • 125 Answers
SOURCE: Baracuda G3 zodiac Clings to bottom or sides moving slowly
here is a link to the Technical Support at Baracuda. this should be able to solve your problems. initially sounds like maybe too much suction.
Posted on Feb 26, 2009
  • 10 Answers
SOURCE: Zodiac Baracuda Zippy Pool Cleaner hose tear
I haven't seen any bulletins on the Zippy hoses. You might adjust the flow to the cleaner. You can find the Manual for the zippy cleaner on this page beneith the diagram. It shows how the star control works. You can also contact the Mfg Technical Support at Phone: 800-822-7933 They might be able to warranty a hose or two for you.
Posted on Nov 05, 2009
  • 366 Answers
SOURCE: the zodiac works for seveal minutes, then the pool
sounds like you may have an air leak somewhere. If not from your zodiac hose, it may be in the plumbing itself. Check the threaded fitting on the suction side of the pump, check the pump lid o-ring, and depending on the pump, check the gasket between the hair/lint pot and the volute or seal plate (especially if it's a sta-rite).
Posted on Nov 22, 2009
Geekman
  • 32281 Answers
SOURCE: Kreepy Krauly In-Ground Pool Cleaner: my creepy crawler wont hammer...
This usually happens when there is a small stick jambing in the bottom of the openning in the Kreepy Krauly where it sucks in the water and rubbish. It is the rubber tube that has a ****, usually something is jambed in the **** to prevent it from thumping.
Posted on May 25, 2010
jharwell668
  • 640 Answers
SOURCE: Hi, we have a Zodiac
With these pool cleaners, getting stuck in one spot is most likely the result of a waterflow problem. Check your water flow valve and make sure that it is adjusted correctly. make sure that you don't have any blockage that would prevent movement and cause the cleaner to stick in one place. This might seem like common sense, but make sure that you have enough hose to reach the entire pool. Many times, when this occurs, the cleaner cannot reach one part of the pool. make sure that your hose balance is correct also.
Posted on Oct 26, 2010
Hurlcon pool pump. Lack of pressure. Creepy crawley will not pulsate. Pump working at 110 pressure - no change. Checked all joints with soapy water.
When you mention the 110 pressure with no change are you saying that the pump is operating at the same level as before and the Kreepy was functional with this level of pressure before? If this is the case then your problem is with the Kreepy itself. This sounds like something is in the Kreepy Krawly line or the unit itself. Many things can become lodged in the unit like acorns, bottle caps, or simply there is a leak in the vacuum hose. I would investigate the unit for impeding debris.
Dec 24, 2015 | Pool & Spa
Why won't it sink to the bottom?
Air trapped in the unit. They do not float unless air is trapped. Turn upside down under water to relieve trapped air.
Jun 23, 2015 | Zodiac Baracuda G2 - In Ground Suction...
Zodiac indigo
Zodiac builds dirt. Jandy used to be pretty good Polaris is hanging by a thread ( both acquired by Zodiac.) I\'m an 18 year veteran in the pool industry. Sorry for the bad luck.
Aug 07, 2013 | Pool & Spa
My creepy crawley has to much suction and gets stuck in one spot is there a way of turning the suction down
Attenuate your skimmer valve slowly to reduce the suction until the cleaner runs smoothly across the bottom of the pool. If you do not have a skimmer valve I would recommend installing an inline PVC valve in the suction hose close to the skimmer so that it is accessible. Close the valve slowly until proper suction is achieved.
Nov 30, 2010 | Universal Kreepy Krauly In-Ground Pool...
Hi, we have a Zodiac pool creepy crawly pool cleaner which seems to work for a while, then get stuck in the one spot and not move in our inground pool.
Oct 24, 2010 | Zodiac Pacer Pool Cleaner
I have a Zodiac Baracuda G3 pool cleaner once the the pump switches off at night the next morning creepy does not sit flat on the bottom of the pool the front side stands up in the the air if you lift the...
It sounds like your house weights need to be adjusted. When the pool cleaner is resting, it should always sit at a 45 degree angle on the bottom of the pool. If it stands up on the front side, try sliding the weight away from the cleaner head. You may need to make several small adjustments to get the balance right, but this is almost surely your problem. Here is a copy of the users manual if you want to read more about hose weights and balance:
http://www.baracuda.com/resources/manuals/TL-2050.pdf
Oct 11, 2010 | Zodiac Baracuda Zippy Pool Cleaner
I took my creepy apart and I can't get it back together. Could I have a schematic?
Your picture says that you have a baracuda, but if you have a kreepy I can help. Here is the owners manual for the Kreepy Krawly. These automatic pool cleaners are not hard to get back together with instructions.
http://www.backyardcitypools.com/images/pentair/kreepy_krauly_manual1.pdf
Jul 15, 2010 | Zodiac Baracuda G3 Automatic In Ground...
May 16, 2010 | Universal Kreepy Krauly In-Ground Pool...
Zodiac pacer
Sounds like diaphragm is ripped
Jun 07, 2009 | Zodiac Pacer Pool Cleaner
Does not clean the whole pool
may need to re-weight it or add helpers.
I had to add a rope system to my pool to get the creepy crawly to all the spots.
Not the best fix - but keeps the pool clean.
Apr 10, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Pool & Spa Logo
91 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
