Question about StarTech.com StarView SV211K 2-port KVM Switch
Some channels not working just keep getting message scrammbled channel have checked codes they seem to be fine.
    Scholar:
  • 54 Answers
Hiya this is what I did & hopefully it'll work for U too - 1) Deleted all th channels & reset 'factory settings' by entering the code 0000, turned th box off waited a couple of minutes & turned it back on !!! 2) You may have to redownload channels so reconnect yr box to the computer & follow the link below (But try without doing this & goto stage 3) first & please let me kno if that works :- http://www.4shared.com/file/76886028/fd4ac296/GTRom_the_box_Super_8102e_081129.html?err=no-sess ) & press download !!! 3) ReConnect & Turn box back on; goto menu & press 1570 to get into the CASS SYSTEM & turn EMU on Reinstall channels & voila
Posted on Jun 23, 2009
How to reset channel auto scan.After I finish channel scan,message pops up stating PLEASE RUN CHANNEL AUTO SCAN,
If when You scan, and you don't get at least one channel, it will keep showing You this message! look at screen it will show new channels! if no new channels check to make sure your coax is hooked up good, also make sure you are using right setting if outside antenna, select antenna, if cable select cable for your source!
Nov 03, 2016 | Televison & Video
4 radio communication
Pls swotch off qt & keep the same channel also keep all privacy codes to 0 , try ur set it will get connected to rest 3 , do not forget to keep privacy code 0
Jun 05, 2013 | Motorola Talkabout T5500 (7 Channels)...
Why is my right channel not working on my Technics reciever?
The right channel output section or speaker might have damaged. Seek tech support.
Jun 03, 2012 | Audio Players & Recorders
With my Sony Bravia 46" xbr the screen keeps cutting out. I'm usig hdmi cables and can't find a reason why te tv keeps cutting out. The sound still remains but picture doesn't. Not even out technician can...
Usually this happens to my set when I am in HD cable channel mode after being on a non-digital ANALOG channel.
I basically reset the TV by changing to a DIGITAL cable channel -- stay on that channel for ten-twenty seconds -- then I switch back DIRECTLY to a HD channel (key in channel number directly on remote).
TV works fine -- seems to be a glitch when the TV changes modes from Analog to HD
Jun 29, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
I HAVE PUT IN CODES FOR 5AO1 TWICE STILL NOT WORKING HAVE RE -SCANNED CAN ANY 1 HELP PLEASE:-)
Re-check the codes, it only takes one wrong number or letter and they wont work.
00 CF 53 OC 33 79 61 71 85
01 52 5E 8D 45 FC 75 F6 4A
Make sure you press store after each line you put in.
Jan 17, 2010 | StarTech.com StarView SV211K 2-port KVM...
I can't change channels,message on TV says,'' no input available''.
Have you tried reprogramming the Dish remote with the Sharp code? That might bring back the TV control. Another option is to use the TV's control panel menu button (if available), go to the setup choices and have the TV scan for channels while the Dish receiver is on. It will find channel 3 then, and probably nothing else, so the set will stay on that channel.
Mar 20, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Channel edit option has gone..
switch off take batterys out of remote plug back in after 30 secs insert batterys try again should sort your prob mate send me your codes to check also kiki
Dec 17, 2008 | StarTech.com StarView SV211K 2-port KVM...
Technosonic stb2009 working fine until last night when the picture froze and the sound went off. Changed channels only to find that all channels are blank, did a reinstall only to be told to check my...
It seemed to sort itself out. I switched it off for 24 hrs and then the following evening switched it back on and hey presto it was working again, haven't a clue how it did it but it did
Aug 12, 2008 | Televison & Video
StarTech.com StarView SV211K 2-port KVM Switch Logo
136 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
