Question about Samsung Cell Phones
Why wont my samsung charge?
Since the battery ran out on my samsung it no longer charges, before running out it was working perfect. but now its not doing anything, what could the problem be?
  • 30 Answers
A lot of times it is a loose connection from your charger to the phone. "wiggle" the connection while it is plugged in, if it briefly charges......that's your problem. Probably need to have it soldered back
Posted on Jun 11, 2014
JingJong
  • 7 Answers
SOURCE: wont charge!
1. The charger may be damaged To check if the charger is damaged, use another functioning charger. The charger cable has a tiny wire that easily breaks when used without proper care. If the phone still does not charge with a functioning charger, try next step. 2. The battery may be damaged Change the battery and try charging again. If the phone still does not charge with a functioning battery, try next step. 3. The battery terminals may not connect properly with the battery connectors Check the battery connector to see if the battery and the connector connects well. The phone will indicate charging only when there?s enough power supply from the battery. click here Solution Procedure: If problem is confirmed, adjust the battery connector using tweezers to reach the battery terminal and establish connection. Or try next step. 4. The charging pin may be damaged or does not connect well with the board's interface Check the charging pins to see if they are well connected to the mother board. Sometimes the charging pins wear out or loosens from its connection with the mother board. Solution Procedure: Check if the pin is bent. Straighten the pin using tweezers. Make sure the board interface is also clean otherwise, you will need to clean it by rubbing its surface using an eraser or brushing it with a board solution. Or replace with a new charging pin. Make sure the charging pin touches with the board interface to establish connection. The CCONT IC for DCT3 or UEM for DCT4 or the "K" resister for non-Nokia models may be damaged If the phone still does not charge after adjustments are made, the problem is CCONT IC for DCT3 or UEM for DCT4 or ?K? resister for non-Nokia models.
Posted on Aug 26, 2007
SOURCE: Samsung t509 won't charge
would something like this work?
http://www.bayho.com/p/PCMB-DC-KE850.html
Posted on Jun 04, 2008
scanner077
  • 52 Answers
SOURCE: sgh p310 wont charge
Hi!
Please check your charging port if the pins are still OK. Please also try a new charger. Perhaps your charger is already defective.
Have fun!
*Your vote is highly appreciated. Thanks in advance!
Posted on Dec 31, 2008
  • 7 Answers
SOURCE: My MOTOKRZR K1 battery/phone will not stay charged very long.
Let ur phone completely die. Don't charge it or anything when the low battery notice comes on. After it completely dies, put it on the charger only until it says charge complete. U might have to do it a few times to get ur battery performing as it should. If you charge ur battery too often, it causes ur battery to swell (weird I know) and your battery starts resisting charge. Hope this helps!! (I used to have the same phone and the same problem. I did this, and now my mom is using the phone and has an exceptional battery time)
Posted on Mar 22, 2009
GrinningFool
  • 625 Answers
SOURCE: Samsung charging problem
If very well could be the charging port. Have you tried a different charger?
If it is the charger port, You have 3 options.
1. get it repaired, warrant if possible
2. Get a new one
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on ebay2.gif.
For more information and links to the parts check the following link below.
Samsung SGH-D900 charging problem repair
Posted on Aug 18, 2009
St-99 bluetooth headphones wont turn on after charging
The headphones may have been delivered with defective batteries that are unable to charge after initial use. Also, the charger could be defective.
Jan 20, 2014 | Audio Players & Recorders
My DS Lite wont charge! Help!
Try another charger, yours may be faulty. Alternatively,the battery may need replacing as it is no longer holding charge, these can be obtained very inexpensively from Ebay and you will just need a small cross head screwdriver to remove the cover on the back of the DS lite, then tap the unit in your hand to dislodge and remove the battery.
Dec 22, 2013 | Nintendo DS Lite Console
Samsung galaxy s3 not charging
try and charge it by connecting the usb cord to your computers usb port.
Nov 22, 2013 | Cell Phones
My car clicks with a battery charger but wont do anything off the charger?
MAKE SURE ALL FUSES ARE OK AND MAKE SURE THE EARTH STRAP TO THE BODY OF THE CAR IS SECURE, THEN MAKE SURE THE BATTERY HAS A CHARGE COZ IF NOT IT WONT HAVE ENOUGH TO START THE CAR EVEN OFF THE SMALL BATTERY PACK,HAD THIS PROBLEM BEFORE.
Apr 08, 2013 | 2002 Kia Spectra
Lost all power in mitisubi gallant
If your machine ran out of battery power from not charging and the car will run with a fresh or charged battery, then check the alternator fuse on the positive battery clamp. If it is blown then even though your charging system is in perfect working order, your battery will go dead and your car will die in the middle of the road. If blown by the fuse at a dealer, replace it and charge your battery.
Jul 11, 2011 | 2004 Mitsubishi Galant
I have the WG5405 WORX 18 Volt Cordless Sweeper Blower with 2 LI-ION Batteries and 1/2 Hour Charger. After charging and using one of the batteries until it ran out, I put it back on the charger. Now I...
These batteries are notorious for losing charge and can be incapable of holding charges. Keeping them in a cold garage over the winter is bad for them too.
The other option is that the charger is bad.
May 03, 2011 | Garden
Engine wont start right up take few minutes engine runs like **** longer it runs better it runs then today that altanater light comes on and battery goes dead so i went to charge it wont charge the...
the alternator is definately bad, if it ran your battery dead like that, and of course as you can tell your battery is trash and needs replaced.. not sure what to tell you on how it runs, considering once it warms up it runs good.
Dec 05, 2010 | Acura TL Cars & Trucks
My samsung rant keeps saying abnormal stae, charging disabled. What do I do?
It is a quick with the charger. Turn the phone off then try charging it. If that doesn't work, change the battery, and with the phone off, charge it.
Sep 11, 2010 | Samsung Rant Cell Phone
New battery wont charge back up
there is a problem with your charger. dell chargers have a habit of blowing. there is a small chip in them that tells the computer that it is ok to charge the batery, that little "safety feature" blows out and will no longer charge your battery. you will have to buy a new charger, either at a store like best buy (make sure it specificly says it is compatible with dell) or go to the dell website to order an "official" one. both options are unfortunately a little expensive, but your only option. i had the same problem with my xps1330.
Jul 19, 2009 | Dell Latitude D500 Notebook
My Samsung Blackjack II won't charge.
Return to the carrier for warranty repair.
If you are out of warranty there are some options you can choose from
1. Get repaired
2. New phone
3. external charging source
The external battery charger runs about 20 dollars on ebay with an extra battery.
Check out the following link to find more about these options
Samsung BlackJack II Battery charging problems
Jul 02, 2009 | Samsung BlackJack II Smartphone
Cell Phones Logo
18 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
