Question about Panasonic Workio DP-1820E Copier
Adf cover is open in workio panasonic - Panasonic Workio DP-1820E Copier
3 Suggested Answers
  • 86 Answers
SOURCE: panasonic workio dp-4530
the power switch going off is a saftey function because when the cover is open the AC line inside the machine is open circuit.
When you close the door you effectivly close the circuit however if the machine still detects an open circuit the machine trips the power switch as a safty precaution.
Possable causes...
FAULTY DOOR INTERLOCK
FUSER UNIT lamps/fuses
Thank You
Posted on Feb 16, 2008
Phonesmith
  • 113 Answers
SOURCE: need Panasonic WORKiO® DP-2330 driver
Hello , this is the link for the most up to date driver. Just choose your language and operating system
Thank you.
http://www.panasonic.net/pcc/support/mfp/dp-3030/gdi/download.html#01-2
Posted on Mar 29, 2010
Panasonic DP3030 Workio copier - won't feed document on top ADF
Hi p Hinkle,
Go in to function mode (function + original size + 3 at the same time). Go to F7 for counters, find the fuser web counter and set it to 240,000 to reset it. Set any other counter alarms that go off to 0. The maintenance period is supposed to be 240k copies, but from the factory it comes set as 120k so you can change that if you want.
Still having Problem Then follow Us For Panasonic Printer Support
Feb 07, 2014 | Panasonic Workio DP-3030 Printer
I have Panasonic network printer workio 8020, Fault code J93 is showing on display but there is no paper misfed in adf.
There is a sensor that is either knocked out of position or broken. It is not that difficult to take apart if you are a bit handy. First remove the covers and then remove the top cover.
Feb 06, 2014 | Panasonic Workio Dp 8020e
I have a Panasonic Workio DP3030 showing error code J93 paper misfeed in ADF. I have followed the manual and there is no paper jammed but I can't get rid of the error message.
Generally a paper misfeed is not a paper jam. The rubber pickyp rollers probably need a clean but turning the printer off for 10 minutes and turning back on should eliminate the message.
Nov 03, 2013 | Panasonic Workio DP-3030 Printer
Panasonic DP 2500 photocopy machine from you a few months ago. I cleared a few paper jams and have not had a problem until now. The message on the machine says to ?close the ADF cover?. I do not know what...
the top cover that opens to the left normally has a small piece of plastic that slots into a sensor toward the back of the adf. this small piece has broken off so the machine thinks the adf is open. an engineer would need to replace the door for you.
Jul 22, 2010 | Panasonic Workio DP-2500E Copier
Adf cover u20 error Cover is closed.
the tray that you put you originals on, lift it up towards you left. under that tray is another door sort of hidden away, that needs to be closed
Apr 02, 2010 | Panasonic WORKiO DP-C262 Printer
Error U20
U20 indicates the ADF cover is open, look to see if something is preventing the ADF cover from closing, like small piece of paper or something out of place.
Apr 27, 2009 | Panasonic Workio DP-2500E Copier
Remove misfed paper code J93
J93 means = paper remained in adf . sounds like you have a problem with the reed point sensor in the adf door . little black plastic arm , right side should be dangling
Jan 13, 2009 | Panasonic Workio DP-190 Multifunction...
My Panasonic DP2500 copier
remove paper jam light stuck on, but there is no paper jam
Apr 17, 2008 | Panasonic Workio DP-2500E Copier
Panasonic workio dp-4530
Possable causes...
Thank You
Feb 15, 2008 | Panasonic Workio DP-4530 Copier
Panasonic DP150 FX Workio information screen is saying "Warming Up"
remove the paper drawer and check at the back of the mc where the cassette was for paper
Mar 21, 2007 | Panasonic Workio DP-150PA Copier
Panasonic Workio DP-1820E Copier Logo
43 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
