Question about Schaerer Coffee Makers & Espresso Machines
The machine says grinder block
After filling the bean hopper the machine says grinder block. What can I do
  • 8 Answers
SOURCE: Coffee beans will not grind
If the grinder is blocked try changing the grinder setting up to the coarsest setting (I think it is numbered 16 on this model) and then vacuum or fill with beans and push them through. Be sure that any damp coffee has gone as you don't want the grinder blades to be left wet.
Never freeze or refrigerate your coffee beans as the condensation from doing this can also block your grinder. Also never use coffees that have been flavoured during the roasting process as they are often too sticky or oily and will block your grinder. These coffees should be ground using a grinder that can be easily pulled apart for cleaning...which is not the case in the Saeco automatic machines.
After you have finished clearing your grinder you will want to turn it back down to a finer setting ( a setting of 6 or 7 works well on this model) however you should only turn the grinder setting finer while the machine is actaully grinding. Otherwise you may find the coffee beans jam between the blades.
If you are unable to clear the blockage it might need to go to a technician.
Posted on Dec 09, 2007
mirran
  • 515 Answers
SOURCE: Water in bean dispenser/grinder
If you look at the bean hopper you will see two screw, loosen this and take off the bean hopper. Now you will see the grinder, you have to take of the adjustment on the side, that plastic on the grinder.
Now you can turn the ring anticlockwise, and take out the middle of the grinder.
Let me know if you wondering about anything
Posted on Jul 13, 2008
  • 60 Answers
SOURCE: fill beans message keeps coming up on jura capresso impressa s9
You need to open the grinder, it`s probably packed with old fine powdered coffee that blocks the outlet. Clean this out and try again. Since it works normal when you use pre-ground coffee, there shouldn`t be any problems with any other parts.
Let me know if you want a description for have to open and clean the grinder.
Posted on Jun 02, 2009
SOURCE: DGB-900bc will not grind
I experienced the same problem after many uses. You need to pull the hopper off and clean out the path the grounds take to the filter basket. It is no doubt clogged up. I used compressed air to really clean it out good.
Good Luck
Posted on Aug 31, 2010
SOURCE: No coffee brewing with beans, but with coffee brewing with ground coffee.
make sure you use very dry non-oily coffee beans
Posted on Jan 31, 2011
My Rancilio Rocky Burr coffee grinder w/doser is not grinding the beans they simply remain in the hopper
It is most likely that something is blocking the pathway to the grinder. As the Rocky is a direct drive grinder there is no gear that could be broken.
Try to remove the beans from the hopper and inspect the pathway, move the beans that might be under the 'disk'. If that is not working you might have to open the grinder;
  • remove all coffee beans
  • unscrew the three screws in the bottom of the hopper
  • remove the hopper
Now you can see the grinder wheel and tell if it is turning normally.
This might be a good opportunity to give the grinder a thorough cleaning.
Do not soak it in water, just a stiff small brush (e.g. a toothbrush) is the best tool. And perhaps accompanied by a vacuum cleaner :)
If you have been using very 'oily' beans for a long time they might have clogged the grinding wheels.
Good luck,
Villi
Mar 02, 2015 | Rancilio Coffee Makers & Espresso Machines
I have cleaned my machine and put the grinder back inside its housing but it says the grinder is blocked and won't operate. I cannot understand where it can be blocked.
You removed the grinder? Or you removed the outer burr from the grinder? It can be tricky to get back in place with the correct lineup. If you don't do it just right, it won't sit down in place like it is supposed to. Here are the full instructions, you may just need the last little bit about lining the burr up on reassembly.
From wholelattelove website:
You do not need to clean the grinder as often as you may think. Usually we do not recommend cleaning the grinder unless there is a problem with calibration or a clog. Avoiding oily beans, flavored beans, and beans stored in the fridge or freezer will typically prevent issues.
If you do experience issues with your grinder, cleaning it is the most common solution. To clean your grinder, follow these directions:
1. Remove the water reservoir, turn off and unplug the machine.
2. Take the cover off of the bean hopper and vacuum out the beans.
3. Remove the 3 Phillips head screws that are in the bean hopper.
4. Lift up the bean hopper and set it aside.
5. Open the machine's service door and remove the drip tray and the brew group.
6. Remove the rubber gasket from the top of the grinder area.
7. The grinder is made up of 2 pieces. The inner piece has 4 tabs that the rubber gasket sits on. The outer piece has teeth in a ring on the exterior covering ½ the circumference.
8. Rotate the outer ring 180 degrees counterclockwise. You should be able to lift off the inner ring. There is a red spot on the outer collar which should now be facing the 9 0'clock position when you are at the front of the machine.
9. Vacuum out all of the beans and ground coffee.
10. If possible, use a small pipe cleaner to get grounds out of the "pathway" going to the front of the machine. It is located on the floor of the grinder at about the 5 0'clock position.
11. Above where the brew group would be located, there is a gray triangular tab attached to a door on a hinge. Pull down on the triangle - coffee grounds may come out.
12. Look above the trap door and you will see the other end of the chute. Vacuum out the chute and clean with a pipe cleaner.
Reinstalling
1. Drop the inner burr onto the grinder with the tab that has the red and blue marks facing the right hand side of the machine at approximately the three-o'clock position.
2. Rotate the outer collar so that the red mark lines up the red/blue marks on the inner burr.
3. Reinstall the rubber gasket that goes over the grinder. The slots in the gasket line up with the four tabs of the outer burr.
4. There is a straight piece located directly to the right of the grinder. This is your dosage control. There is a piece that can slide backwards and forwards on this dosage arm. Push this arm all the way to the back of the machine.
5. Set the knobs in the bean hopper to #0 on the grind setting knob. Set the doser knob all the way to the plus setting. Now place the hopper back into the machine.
Note: You may have to rotate one or both of the knobs, a small amount, to get the bean hopper to set down on its supports.
6. Install the 3 screws.
7. Replace the water reservoir.
8. Fill the bean hopper with a cup of beans.
9. Plug in and turn on the machine.
10. Reinstall the brew group and the drip tray.
11. Once the machine warms up, press the small coffee button. When the grinder comes on set the grind setting to 6.
Note: You may have to press the small coffee button twice or 3 times before the machine will make a cup of espresso.
Oct 09, 2010 | Gaggia Titanium Espresso Machine
Machine says beans are empty and will not brew.
Try adjusting the grinder coarser when it is running. Either the grind is too fine or the grinds chamber is blocked, remove the brew unit and check the gate to the grinder on the inside right.
Jul 30, 2010 | Saeco Magic De Luxe Espresso Machine
Grinder Blocked said on screen. Any Quick fixes?
This has happened to me twice. Usually caused by a trapped bean in the grinder. Here is how I fixed it. It is easy.
Inside the plastic bean hopper is a screw located in the bottom. Remove it and lift off the hopper. Have someone help you as you turn the machine upside down to remove all the beans. Use a tooth pick or a wooden skewer to pick out any beans lodged inside the grinder housing. Once completed, return the unit to its upright position.
Look inside the hopper and locate the grinder stem which is gold colored. On top of the stem is a hex bolt. Take a hex wrench with a 7/16 hex socket, connect it to the grinder hex bolt and turn it "counter clockwise" about half way which is the same direction the grinder turns. Add some beans and see if it works. If not, turn the hex bot "clockwise" a half to a full turn. Add beans and check.
This helps move the grinder out of its "stuck" position.
Nov 03, 2009 | Saeco Incanto Sirius Fully Automatic...
Our Saeco Delux Magic coffee maker will not grind the coffee when we push the button. A light comes on that indicates that the grinder could be jammed.
Hi
The grinders run on a timer. If the grinders does not fill the doser in time you will get a light saying no beans. If this happens and there are beans in the hopper push the lever to the largest # and push the brew button again. This will clear the light and it should brew. If it is at the largest # already your beans are probably shiny and there is to much oil in the beans and this is what is clogging the grinder.
Apr 10, 2009 | Saeco Magic De Luxe Espresso Machine
My Saeco won't grind the beans
There's moisture in the grinder & it's clogged - just dismantle the grinder & clean it, then ensure you don't splash water into the bean hopper when you fill the water tank.
Mar 29, 2008 | Saeco Magic De Luxe Espresso Machine
Gaggia Trevi or Spidem Trevi
You may have a legitimate mechanical malfunciton but sometimes the simple solution is the right one! The chute on this (and other) superautomatic does not like the oily residue that beans inevitably leave. All it takes it gently putting one or two fingers into the bean hopper as the grinder motor starts to sound louder/faster (this is caused by the grinder motor being under less load/strain because no beans are feeding) and wiggling for 1-2 seconds. If you do this immediately after hearing the grinder motor's rpms increase you will not get a "fill bean hopper" error message2.gif. No hard pushing is required, just a gentle wiggle. There is a shroud over the actual bottom of the hopper, so you don't want to stick your fingers beyond that. If you are concerned about actually sticking your fingers into the hopper while the grinder is running, you can simply push down on the top of the beans with gentle pressure which will in effect force the beans down and accomplish the same thing. This technique + regular cleaning of the grinder may be all you need. Hope this helps! Tony
Jan 02, 2008 | Spidem Trevi Anthracite Espresso Machine
Coffee Makers & Espresso Machines Logo
37 people viewed this question
Top Schaerer Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Schaerer Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
