Question about Polaris 2012 LXT 600 IQ
Any common problems with electronic fuel gauge?
Mine reads empty all the time. The wiring harness to the dash multi gauge was damaged and I thought when I replaced that it would be O.K.
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 70 Answers
Sounds like you have a grounding problem. check and make sure that the sending unit is grounded. should fix the problem unless the sending unit is bad...
Posted on Jun 08, 2014
Fuel pump wiring diagram
there is two things : fuel gauge and dash fuel gauge. The fuel gauge in tank rated to 0 to 90ohms.disconnect wire at the tank take a variable resistor connect it to wire .read the dash gauge if it move as you move the resistor. if ok fuel tank gauge is at fault
Aug 09, 2013 | 1998 Chevrolet K1500
Fuel gauge Stuck
The most common way to find out is to test both components.
The sending unit in most vehicles grounds the gauge on the dash.
You would unplug the sending unit - pump harness at the tank and ground the sending unit wire. If the gauge climbs up to full the sending unit is at fault.
You could also measure resistance in the circuit in the tank when the tank is close to empty and after filling it up. The resistance should be different each time.
Mar 11, 2013 | Cars & Trucks
Gas hand reads full all the time
Fuel gauge may be the problem, but may also be a short in wires going to fuel gauge
Battery power goes to gauge in dash then to resistor in tank to ground. If the wire going to tank is shorted to frame it will always read full. Test this by disconnecting the wire going to the tank. If it goes to empty then you know the reason, either resistor in tank is bad or wire shorted.
Feb 23, 2013 | 1991 Cadillac Fleetwood
Fuel gauge reads correctly then goes to empty
9 times out of 10 the fuel pump/level sender assembly is the cause. Sometimes the gauge pod is faulty, and there have been cases where there were either poor connector pin fit issues and/or chaffed/melted/cut wires in the harness that leads back to the fuel pump. It is an extremely common fault and would be surprised if the pump/level sender assembly wasn't the cause.
I hope this info helps!
~subyguru~
Sep 21, 2012 | 1999 Pontiac Grand Am GT
Jus bought a 91 izusu pick up... gas gauge doesnt work.. wat do i gota do to fix this??
Talking about fuel gauge issues and how do you how do you diagnose, ... is the dash unit right here, and obviously the gauge doesn't read correctly. ... to fix the fuel gauge, so you can actually fix the fuel gauge electronically by reflashing the program. ... How to Troubleshoot a Malibu Fuel Gauge & Dash Light Not Working ...Could be a bad fuse - fuse # 17 is a 15 amp fuse for the fuel gaugeCould be a bad float on the fuel gauge sending unit inside the gas tank ( it's with your electric fuel pump ) If the float gets a pinhole or crack in it , the float fills with gas and sinks so the gas guage reads empty all the time Could be a wiring problem
Oct 15, 2011 | 1991 Isuzu Pickup
My fuel gage is reading full at all times and the radio will not come on is this a fuse issue or two different issues?
You definitely have two different issues as the fuel gauge and radio are on different circuits. The radio could be a blown fuse, which would require finding a short circuit. The fuel gauge could be as simple as a bad connection at the sending unit or a lost ground on the fuel tank. Disconnect the fuel gauge at the tank and with a twelve volt test light well grounded probe the harness terminals with the key on (engine off). The fuel gauge should move when the sending unit wire is probed, and the test light should light dimly. Other terminals are a ground for the sending unit, a ground for the fuel pump, and power for the fuel pump. If the gauge moves when the sending unit wire is probed the problem is either the sending unit or a bad harness connection. If the gauge doesn't move during the probe there is a wiring problem (open circuit) or a bad dash gauge. Hope this helps.
Jul 02, 2011 | 1998 Ford Windstar
The fuel gauge is'nt working.I tryed to ground it
When testing a fuel guage you should disconnect the wires to it,guage should read over full,ground the float wire,turn off key then turn back on should read empty.You have to cycle the key for guage to move.If still inop the wire is broken in the harness between the tank and the dash.Voltage on the float wire is low.When tested with a test light it will barely light the light and pulsate.This test indicates the wiring is good.
Apr 17, 2010 | 1991 Chevrolet C1500
2001 HYUNDAI FUEL GAUGE
well its either the wire between the tank and guage in dash or it is the gauge in the dash
Aug 15, 2009 | 2001 Hyundai Accent
1997 sonoma fuel gauge not working. Shows empty or just above empty all the time.
Possible in tank sending unit .Disconect tank harness and jump 2 wires (not pink/ black) to verify harness and gauge .If gauge moves with jumper,you will need to proceed with tank removal in order to access the top lock ring which secures the assembly and service the sending unit.
Jul 29, 2009 | 1997 GMC Sonoma
Fuel gauge error
The best way is to use a gauge tester to vary the resistance to the dash gauge. You will need to unplug the harness back at the tank and connect there. It will either be a pink wire or a yellow wire to the gauge.
Aug 08, 2008 | 1995 Lincoln Town Car
Polaris 2012 LXT 600 IQ Logo
309 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
Bill Boyd
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
