My vizio model vtba1008 won't power up the green light is on
    Top Expert:
  • Televison & ... Master
  • 75,581 Answers
Main board fault. Check and replace damaged component/s at its main board. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
Posted on May 16, 2014
Vizio VP422 won't turn on ORANGE LIGHT PLEASE HELP*
if you plug in the set, and the "Vizio" light isn't orange, most likely you have a faulty power supply board. Tests will need to be performed to be sure.
Mar 22, 2013 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
My Vizio tv , model number e3d320vx. The back light, power light , and Vizio symbol come on but that's it . Won't do anymore .
Eprom failure most likley so the main board will need to be replaced. I would send a email to customerservice@tvrepairworld.com to see if they have the replacement main board for your model they should have it available.
Jan 02, 2013 | Televison & Video
Vizio p50hdtv10a led light blinks 10 times when powered off
If the problem is same with different input devices and you have ensured the are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 16, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
Power surge while it was turned off. when power was restored 47" vizio lcd/hdtv screen flashed then went black. won't turn on even with vizio trouble shooting steps, repair shop says needs a new...
sounds like you have a bad back light inverter board and it needs to be replaced. if it is still under warranty then try to get the manufacture to repair it for you. just don't tell them its from a possible power surge. check sharp's web site for more info. i think vizio is made by sharp electronics.
Aug 25, 2011 | Vizio Televison & Video
50" vizio hdtv will not turn on and light in front not on
If TV is completely dead, no green/orange light, no any clicking sounds after you unplug it from the wall outlet and plug it back in - it is a problem with Power Board. Best case scenario - It's just a fuse that needed to be replaced. You have to remove back cover and locate fuses (1-4) on the board that power cord is attached to. You have to use multimeter to check it. If fuses are OK - next step is to replace whole power board. But before you do anything - make sure you got power out of the wall outlet and/or your power strip is in working condition.
Mar 10, 2010 | Vizio Televison & Video
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Trys to power up makes Buzz, then nothing but light stays green.
those vizio plasma have a lot of problems, its still most likely the Ysus board, but it will have to be tested to know for sure. If you bought it at coctco you are in luck, if bought a couple of years ago they will give you a full refund. you can try replacing it yourself by checking shopjimmy.com or ebay
Jan 18, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio P4 Plasma TV, won't turn on
if your vizo p4 blinks red 10 times its your power supply board ckeck your two fuses on the board,if those are not bad change your power supply board if you can find a board for that model vizio p4 .the phillips tv uses the same board
Oct 11, 2008 | V, Inc. Vizio P4 Plasma Television
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
