Braemar fault codes
Fault 13 what is it ?
Braemar heater control unit showing flashing reset
Your Braemar control unit is indicating that it needs to be reset to continue operating.
Jul 07, 2018 | Heating & Cooling
What repairs should be made for diagnostic codes 13 and 51 .
which engine, that be first. no? look at it and what is it?
ill pretend 4.0L I-6
old car, with OBD1. code 13 and 51 are fully covered in the FSM.
ever seen and fsm? login to aldata.com and read.
and is discussed , infinitely on all jeep forums on the net. endless.
google that.? yet?
here ill google for you
i google jeep 13
http://www.allpar.com/fix/codes/faults/code13.html
and jeep dtc 51
http://www.allpar.com/fix/codes/faults/code-51-52.html
13 would cause 51s so,...... work that.
Oct 02, 2014 | 1994 Jeep Grand Cherokee
Will a fridge still work if fault code 13 is displayed?
13 error code means heater element in freezer drain bad replace have to take apart whole freezer
Aug 12, 2014 | Thetford Refrigerators
Braemar heater
IS AIR INTAKE BLOCKED BY WALLS, FURNITURE, OR DUST AND DEBRIS?
Jul 21, 2013 | Heating & Cooling
Braemar spectrolink reset error 05
I had the fault code 05 (spectrolink controller) recently on a Braemer TG420 ducted heater. The heater would start and cut out on high temp as the room fan was not starting. I checked under the house and found the cable fitted to the return air thermistor had been chewed. I repaired the section of cabling and restarted the unit and it worked fine. Fault Code 05 is to do with the Thermistor in the return air duct.
Mar 27, 2012 | Heating & Cooling
Braemar spectrolink comfort controller keeps on asking to be reset works ok for a while then goes to reset
Look for the error code on the right hand side of the display above the zone section and below the actual temp displayed.... refer to:
http://www.braemar.com.au/PDFDocuments/Section8_ServiceTroubleshoot.pdf
Jul 21, 2010 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
