Question about Refrigerators
I have an Elle Gold fridge modle D260 and I need a shelf for the freezer and a new glass to cover the veg tray I live in Germiston can you help
  • 62 Answers
SOURCE: Freezer
there are what are called door "cams" on the bottom of the doors. One piece is on the bottom of the door and the other one is on the hinge. Both pieces need to be replaced and it is possible both your doors may need them. The parts come as a hinge assembly. That means you need to replaced the hinges on the bottom and they should come with the piece that goes on the bottom of the door also. You may also have a blocked defrost drain. There is a hole in the center rear, under the evap plate there where you see the dripping. that may need some air pressure blown through it to clear it. remeber, ever time the unit defrost, you will get that water.
Posted on Sep 01, 2008
docjohn174
  • 943 Answers
SOURCE: whirlpool gold
hi thanks for the question it looks like the drain tube is clogged up you can clean this out first turn off fridge let thaw pull back cover off vacuum any dirt you find find the evaporation tray that's where the melted ice is suppose to go buy a small plastic hose to shove up the tube clean out should be ok the appliance doc
Posted on Sep 13, 2008
SOURCE: Replacement glass shelf required
Not too sure what your glass shelf looks like, but if you can't find replacements it might be easier to just get a sheet of plexiglass and glass cutting tool from a home depo (or the like) and cut it to the correct measurements. That's what I did for mine.
Posted on Jun 16, 2009
SOURCE: bracket holding glass over fruit / veg compartment broke
http://www.partselect.com/Schematics/Maytag/54436.gif Maybe this diagram will help you. www.partselect.com I just replaced the Crisper Shelf Frame. I received it very quickly. I am now looking for some sort of support for the whole shelf, because it still seems to be sagging. I may have to invent something. If anyone out there has a solution, please post it.
Posted on Aug 12, 2009
  • 44 Answers
SOURCE: top of freezer not freezing, bottom of fridge is?
Could be the evaporator fan motor is not working. This is what circulates the air from the freezer to the refrigerator section.
Posted on Aug 25, 2009
Crisper glass cover for Avanti fridge
have the local glass shop cut a new one for you
Dec 06, 2015 | Avanti FF8SSR Top Freezer Refrigerator
Vegetable tray in my samsung fridge broken
Have you tried other places on the net by searching by part number in a web search engine? There may be some private vendors that sell these parts.
I found some companies are not very good for spare parts. This is especially with older units. The life expectancy for most appliances in these times is about 5 to 7 years. In most countries the manufactures are not obliged to supply parts past about 7 years past the last devices of the model in question were manufactured. Your fridge is more than that age!
Apr 02, 2017 | Samsung Refrigerators
Water in veggie crisper and meat tray, Moisture build up on glass shelfs
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 18, 2010 | Whirlpool Refrigerators
I have a Hotpoint slimline 8214. No matter what setting i select ( 0-9 ), the little freezer box keeps over-icing and it also collects on the bottom of the ice-box where the drip-tray is located.
the little ice box collects all the condensate in the fridge,there is no way of stopping it,but you can slow it down by covering all food(except fresh veg).put the ice tray in a polythene bag.etc.....
Aug 13, 2010 | Refrigerators
Need a new glass shelf for fridge and on oven the
the least costly way is to get a piece of glass from home improvment store and have it cut to fit
Jul 03, 2010 | Refrigerators
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
Top of freezer not freezing, bottom of fridge is?
Aug 24, 2009 | Refrigerators
Fridge is freezing stuff
try to call a technician the defrost system of Ur fridge might be damaged or u have a leak of gas on ur system.. tell him to check the thermostat.. also
Mar 09, 2009 | Candy CPCA270FFK Bottom Freezer...
Nov 28, 2008 | Zanussi ZTX520W Top Freezer Refrigerator
Bracket holding glass over fruit / veg compartment broke
Aug 26, 2008 | Amana ARB2217CSR Bottom Freezer...
Refrigerators Logo
12 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
