Question about Ricoh Office Equipment & Supplies
How to resolve error SC300? - Ricoh Office Equipment & Supplies
Error sc300 on Ricoh mpc 7500. i replaced the drum unit and its fine but after two weeks the error came up again
The error code you gave shows several possibilities for your issue:
Drum charge corona wire, The output of the charge corona wire of the black PCU is abnormal.
Causes
• CGB power pack connection loose, broken defective • Check CGB power pack connection to BCU • CGB power pack defective • BCU defective • Replace OPC drum
Of the five possibilities above, replacing the drum is the most likely cause. Since you only had your drum for a couple of weeks I would take it back to where you purchased it and ask for replacement. Sometimes you get a bad drum out of the box from the manufacturer. It happens. If the same error code pops up again, I recommend you call your local Ricoh dealer for further troubleshooting.
Aug 26, 2016 | Ricoh Aficio Office Equipment & Supplies
Where is crank shaft sensor location on 95 lexus sc300 please help
images for Where is crankshaft sensor location on 95 ...
eplaced engine on '97 SC300 now new engine does not have Crank ...
www.clublexus.com/.../633233-replaced-engine-on-97-sc300-now-new-...
May 4, 2012 - Location: arizona. Posts: 3 ... apparently 95-97s had an additional crank sensor. .... 1995 Lexus SC300 5spd Na-T ( TT Ecu Mod + a few others) 2jzge position sensor??
Nov 2, 2011
SC400 Crank Shaft Position Sensor. WHERE?????
Oct 11, 2011
SC300 No Spark
Oct 2, 2010
What happens if the Camshaft Position Sensor goes bad?
Jun 18, 2009
More results from www.clublexus.com
Lexus Crank Position Sensor ' LS400 SC300 ES300 GS300 ...
www.partsgeek.com > Crank Position Sensor > Lexus Parts & Accessories
Products 1 - 10 of 68 - 95 1995 Lexus LS400 Crank Position Sensor Denso NLA 7/13 ... 96 1996 Lexus SC300 Crank Position Sensor Denso Includes Pigtail.
Jan 27, 2016 | Lexus Cars & Trucks
How do I fix code 13 engine speed sensor Above 1000 rpm
Clearing the codes is simple that is done by removing the fuse of the EFI from junction box 2 for 10 seconds. Make sure to remove the jumper wire and switch the key off before clearing the codes.
Here are some common Lexus vehicles 1990-1995 codes:
Code 12 and Code 13 Rpm signal circuit fault
Code 14 Igniter signal circuit fault
Code 16 ECT control signal fault
Code 21 and Code 28 Main oxygen sensor fault (for ES300; SC300 & GS300 models)
Code 22 Coolant temperature circuit fault
Code 24 Intake temperature sensor circuit fault
Code 25 and Code 26 Air fuel ratio fault (for ES300 & SC300 models)
Code 27 Sub-oxygen sensor circuit fault (for ES300 CA & GS300 models)
Code 31 Low airflow meter voltage (for ES300 and GS300 models)
Code 32 High airflow meter voltage (for ES300 model)
Code 35 Barometric pressure sensor circuit fault (for GS300 & SC300 models)
Code 41 and Code 47 Throttle position sensor circuit fault
Code 42 Vehicle speed sensor circuit fault
Code 43 Starter signal
Code 51 Switch condition signal fault (for ES300; GS300 & SC300 models)
Code 52 Code 52 and Code 55 Knock sensor circuit fault
Code 71 EGR system circuit fault (for ES300; GS300 & SC300 models)
Code 78 Fuel pump control circuit fault (for GS300 & SC300 models)
Nov 18, 2014 | 1990 Lexus LS 400
Error Code sc300-01
Replace Charge corona end blocks
Dec 12, 2013 | Ricoh Aficio Office Equipment & Supplies
MP 6001. What is error code SC300?
Charge corona error - check front door switches
OR
replace corona unit and enblock as set
OR
Power pack defective # AZ32 0163
Aug 16, 2013 | Ricoh Aficio Office Equipment & Supplies
Como soluciono el error sc300 de la ricoh 2060SP
sc300 on a Ricoh 2060 is a corona wire error. Typically what happens is the corona wire has snapped, and a new wire needs to be installed.
May 28, 2010 | Ricoh Aficio AP3800C Laser Printer
RICOH SP C222SF SC300ERROR WHAT IS IT. CAN IT BE
SC300 on a C222SF is a high voltage power error. You could reseating the connectors for the high voltage power supply and the engine board (EGB), but more than likely one of those two boards will need to be replaced.
May 25, 2010 | Ricoh Aficio SP C222SF All-In-One Laser...
Sc300 service call
On the SP C222SF, sc300 is a high voltage output error. More than likely, either the high voltage supply board (HVSB) or engine board (EGB) is bad and needs to be replaced. However, before going that far, you can try turning off and unplugging the machine and reseating the connectors that go to those two boards. Sometimes a loose connector can cause a service code, and fixing the connection can clear the problem up.
Feb 07, 2010 | Ricoh Aficio SP C222SF All-In-One Laser...
Sc300 had this code on afico 1075
Charge corona output error 1
The feedback voltage from the charge corona unit is too high
Possible causes -
· Charge P.P. defective
· Poor charge corona unit connection
Jan 25, 2010 | Office Equipment & Supplies
1992 SC300 starts initially then won't start
fuel filter is hardly ever been a problem with a lexus or toyota.you need to check for spark at the plugs.then go from there.
Jun 11, 2009 | 1992 Lexus Sc 300
26 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
