Question about Panasonic SC-VK31 220 Volt 5-VCD/CD Changer Shelf System
Sa-vk91d Power Amplifier IC - Panasonic SC-VK31 220 Volt 5-VCD/CD Changer Shelf System
How can reset Panasonic sa-vk91d
While stopped and "DVD/CD" is the source, press and hold [L, STOP] on the main unit and[h10] on the remote control for about 3 seconds until "Initialized" disappears from the television. Turn the unit off and on again. All settings will return to the default values
Nov 23, 2015 | Panasonic Audio Players & Recorders
How to reset panasonic sa-vk91d
Unplug. wait 10 min,s and re plug.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Nov 17, 2015 | Panasonic Audio Players & Recorders
Panasonic sa vk91d
Forgot the player's password
Dec 12, 2013 | Computers & Internet
Modifying a Panasonic VK91D system and I want to bypass the Disc Initialise stage that it starts up with because I'm getting rid of the whole disc feature of the system..
If you are clever enough and can work in C++ redesign the firmware. Otherwise, nothing can be done as the system is written as it is.
Jan 27, 2018 | Panasonic Electronics - Others
Same problem
The overload indication tells us that there is a problem in the final stage of the amplifier section. This model uses an AMP-PAC or large amplifier IC (part number RSN-3305) which is now defective. If you can solder, try resoldering the pins on this IC. Sometimes a poor solder connection can cause a voltage offset that will be detected as a fault and shutdown the system like this. If the resoldering fails, the IC will need to be replaced. Parts cost will be in the $75-$95 range.
Dan
Sep 14, 2009 | Technics SA-AX720 Receiver
Technics SA-AX720 AMP
The audio amplifier IC of your device are damaged you need to replace it.
Jul 04, 2008 | Technics SA-AX720 Receiver
Panasonic SA VK550 - F61 eror
Hi, i had the same problem with a panasonic player, when you see the code F61 in the screen it is because the audio output IC is defective,change that and the set will work perfectly. hope it work.
Feb 05, 2008 | Panasonic SC-AK33 CD Shelf System
Panasonic SC-VK31 220 Volt 5-VCD/CD Changer Shelf System Logo
42 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
