Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Ihave the same problem with my GD25SFXHS02 fridge.
The tube that supplies the icemaker is frozen solid. No ice is being made and I pulled the arm up so the water is not trying to fill the ice maker any more. It was making a peculiar noise. Any help would be well received.
  • 351 Answers
Simply de thaw that tube and see what it does for ya
Posted on Jun 23, 2009
Model KFIS25XVMS9. Why doesn't it make ice?
sounds like the ice maker is the problem not the inlet .
Oct 15, 2015 | KitchenAid Refrigerators
Sub Zero model 632 Icemaker shutoff arm stuck in the up position. No water in ice tray. Tried turning frig off for 30 seconds, no luck. Checked water supply, it's good. Metal fill tube not...
The shut off arm is in up position. This is the off position for the ice make. Try pulling the down to the first level this will engage the micro switch to start the ice maker. Also, behind the ice maker is a 4 wire plug remove the plug and see if there were some electrical arcing. But first before removing the ice make plug--Please unplug the refrigerator first before work on the ice maker. stewbison
Aug 20, 2011 | Sub-Zero 632 / S
Lg side by side model number lrsc23915sw ,ice maker shut off arm only moves only about one half inch upword,front of arm attached to curved plastic piece this model was bought in canada
the icemaker arm on the L g are diferent dont try to pull up not a shut off arm this has a switch under side of ice maker if u kift up on the arm on this icemaker yo uwill need to buy a new icemaker and they arent cheap check for an ice jam between auger in icemaker if you havent pulled up on arm ive also seen the water fill tube to icemaker frozen
Jan 28, 2011 | LG LRSC26920TT Side by Side Refrigerator
Maytag sidebyside MSD2758DRW ice maker won't make ice
If the ice maker no longer make ice, check the following.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on.
On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice.
Check your door seals and thermostat, repair/replace as necessary.
Thanks
Jul 10, 2010 | Maytag Refrigerators
I had the power out on my refrig for about 8 hours. Now the ice maker has stopped making ice. Water in the door works, but no water going to the ice maker and not dropping ice. Do I need to defrost the...
There is a dual acting water valve that feeds the ice maker and door water seperately.
If your power went out - chances are good the solenoid on the icemaker side of the valve has failed - so it will not open the valve on the demand of the icemaker timer.
To find out - you will need to check that there is voltage at the valve.
With a model #, I can help you better.
Thanks!!
Feb 20, 2010 | Refrigerators
We have a Maytag MSD2754ARA refrigerator and heard water leaking under it last night. We checked and it is coming from the line connected to the icemaker. The line inside is frozen solid. I have read that...
You'll need to first defrost/thaw the freezer and the water line in order to get water flowing again. This can take some time, so you might want to shut off the ice maker by lifting the ice maker bin arm, which will stop it from cycling/calling for more ice to be made.
You can try to thaw the line by using a household hair dryer, but unless you have only a small area of the water line frozen, it could take some time. That is why it is best to empty the fridge/freezer and keep the doors open and the unit off to allow for a complete defrosting of the unit. Have towels, sponges and buckets handy to get all the water.
It sounds like it could just be the frozen water line, but until you thaw it out, you can't really determine if that's all it is.
Jul 13, 2009 | Refrigerators
Ice maker not makeing ice anymore
check the output power supply
Jul 07, 2009 | Refrigerators
My ice maker wont make ice the water is not going in the tray
First, make sure the arm on the ice maker not in the up (off) position.
Second, pull out the refrigerator from the wall and make sure there is no crimp in the line from the wall.
Third, check that ice is not frozen around the plastic teeth. Pull out the whole ice bucket and thoroughly check that something is not blocking or frozen in the wrong place.
This will get you started.
Jul 11, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Whirlpool fridge model WF-NL300 ice maker not working. No water in icemaker. Black water supply tube that fills icemaker was frozed solid with ice. I thawed it in a cup of hot water. Unsure if line could...
Turn ice maker off for 24 hours to thaw out any additional frozen lines.
Make sure that you do have water from source to unit. Water valve grit screen may be clogged with debrie or water valve is bad.
Feb 29, 2008 | Refrigerators
Whirlpool refrigerator ED22TEXHW01 ice maker
Tammi, you first want to check to make sure the water inlet tube to the icemaker is not frozen shut. Next, get yourself a jumper wire about 4 inches long with the ends stripped exposing the wire on each end. Pull off the ice maker cover, it will pull right off. Now you are looking at the module. On the module, left side, you will see two test points marked V and L. Insert one end of the jumper wire into V and the other marked L. You are now sending 120 volts to the water valve and water should fill the ice maker providing the inlet tube is not frozen over. If it doesn't fill, you either have a bad water valve or module itself. Also check to see if the clips that hold the center gear on the module are not broken. Catriver..post back.
Mar 22, 2007 | Whirlpool GD2SHGX Refrigerator
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
216 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
