Question about Rowenta Irons
Steam is escaping from underneath the iron, how to fix this?
    New Friend:
  • 3 Answers
Household irons can drip and spit out liquid water from the holes in the metal sole plate instead of producing steam if you have set the temperature too low. The obvious remedy is to increase the temperature, but this setting is not appropriate for all types of fabric. For example, the highest setting is generally recommended for removing wrinkles from cotton garments, and the lowest setting is generally safe for silk garments. Using the iron and its steam functions as the manufacturer intended can reduce or eliminate dripping. If that doesn't solve your problem, consider additional steam iron troubleshooting.
Posted on May 16, 2014
My swan dual steam iron leaking and steam comes from underneath(bottom) onto my ironing board/ counter top ! Only used it about 3 times Any ideas Tia
You may have to reposition your iron so it is not flat against the board when not in use. The instructions should be quite clear about the correct "resting" position.
Dec 18, 2015 | Top Irons
I have a lauraStar Magic Evolution and Steam is escaping around the filling cap. Alot What do I need to do
rubber fittings destroyed in internal compartment,ervice by expert professional
Jan 12, 2015 | Irons
Swan steam iron
The iron has failed and is leaking steam where it shouldn't be leaking.
May 23, 2017 | Irons
Lost steam pressure
see this causes and fix it.God bless you
Inspect the steam vents from the outside, and use a pipe cleaner or other small utensil to remove any excess buildup that is blocking the vents. Be careful not to let the buildup fall down into the steam vents.
  • 3 Clean the steam iron's directional spray tip. Minerals and other debris can build up on the nozzle over time and will greatly hinder the use of your steam iron.
  • 4 Pour equal parts vinegar and water into the steam iron's water supply tank. Put the steam iron above an empty pot, and turn the iron on. Let it steam the solution until all the water/vinegar solution is gone
    Sep 23, 2012 | Tefal UltraGlide Easycord FV4256 Iron
    HI I have a Bosch Sensixx B25L iron. Steam isn't coming out of holes, seems to be escaping from edge of iron. Handle very hot (Too hot to hold on to), burns your hand when steam button is pressed
    I just fixed mine - it had exactly the same problem.
    First, though, check it's not within the Bosch TWO year guarantee; if it is, they'll either fix or replace it.
    If it's not under guarantee then the problem is probably the rubber tubing that connects the external steam tube to the hotplate. You'll need to dismantle the iron. Mine had split right next to the spring clip that holds it on. I shortened it, clipped it back on and all is now well.
    Jul 28, 2012 | Bosch sensixx TDA 8333 Iron
    Steam escaping?
    do the following step:
    1) distilled water and softened produce leak , change the water
    2)put water until the LEVEL
    3)give time enough thermostat for heating. if you use before to HEat enough produce leak.
    4)switch dial off to test the water stop leaking,when the steam setting is NOT working.
    5) shake back and forth for a few time, to turn on back it is auto-off function.Can be leak when is auto-off mode
    God bless you
    Jul 14, 2012 | Irons
    Steam gauge is broken and iron will not produce steam
    http://www.fixitclub.com/Parts_Components/Appliance_Controls.shtml click the link  Maintenance and repair tools you'll need to fix an electric iron include these:
    • Screwdrivers
    • Toothpicks or pipe cleaners
    • Sewing needle
    • Commercial electric iron cleaning solution or vinegar and water
    • Commercial soleplate cleaner or baking soda and water
    • Steel wool
    • Emery cloth
    • Metal cooking pot
    you will need a speacial tool screw driver  also called as g5 screw driver to open it.available at local repair store. If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
    If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
    If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
    If the iron does not spray properly, inspect and clean the nozzle (see below).
    If the iron leaks or spits, clean the steam vents, nozzle, and tank.
    If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
    Mar 26, 2009 | Rowenta Irons
    Steam escaping around the cap
    If new parts are needed, and I am in California, I use the website below for DG-980 parts:
    California Electric Service
    (925) 827-1011
    1170-G Burnett Avenue
    Concord, CA 94520
    http://www.californiaelectricservice.com/
    Hope this helps, good luck and keep in touch.
    Jun 28, 2008 | Rowenta DG-980 Iron
    Irons Logo
    144 people viewed this question
    Top Rowenta Irons Experts
    Joseph Hoffmann
    Are you a Rowenta Iron Expert? Answer questions, earn points and help others
