EDISecure DCP 240+ card printer keeps giving me an error message that the ribbon is broken, what can I do to prevent that?
SOURCE: Zebra ZM600 - ribbon in error
Make sure the ribbon sensor is in the proper position and that there is nothing covering it, like a piece of label that came off and got stuck to the sensor. Here is a picture of where the sensor is located. Did you make sure you put the ribbon sensor plate back in? If not you will get this message. Make sure the Print Method is correctly set! Although I exclusively use Thermal-Transfer (ribbon is loaded along with label stock) my 140xIII had Print Method set to Direct-Thermal and printed labels just fine. The only problem I could see was that the Ribbon In warning would not go away.
After changing the Print Method the warning went away and printing continues as before
Posted on Nov 16, 2009
xptareq2000
  • 1447 Answers
SOURCE: The Brother DCP 7020 printer displays error
back cover door switch is displace so it called back cover open.
Posted on Nov 22, 2009
  • 4 Answers
SOURCE: keep getting broken ribbon message on zebra P330i printer
Hello, assuming the supplies are Zebra and there is no discernible damage to the ribbon, it could mean that the ribbon sensor on the printer is broken. if your printer is still under warranty you can ship back to Zebra (Illinois) to get it repaired. The zebra website has info on how to return printers for service. Hope this helps.
Posted on Mar 08, 2010
  • 4 Answers
SOURCE: broken ribbon message for my zebra card printer
It could mean that the ribbon sensor on the printer is broken. Sounds like you need to send back to zebra for repair. This is free if printer is still under warranty. check out zebra's website for info on how to return printers for service.
SOURCE: DCP-165C Compact Colour Inkjet Multifunction Printer: in brother dcp 165 printer the error message clean...
brother dcp-165c printer unable to clean , see troubleshooting and routine maintenance chapter in User's guide
Posted on Jun 06, 2010
Hi, I have the card Printer Edisecure DCP340+ it was working perfectly, I just format my PC and tryed to install it again ! The problem when i connect it to any PC it is recognized as DATACARD SP55
If you re-formatted the PC, then you likely wiped out the instance of the correct driver for your printer. Windows typically does not come with a driver for any but the most popular ID-card printers. When you reconnected the EdiSecure printer, it likely associated it with what it believed to be the closest driver to the one required (but missing) - the Datacard driver. To correct:
1. Through the Windows Control Panel, then Device and Printers (or Printers and Faxes if WinXP), find the instance of your printer (set up as Datacard); right-click on it; select "Remove Device" (or "Delete", if WinXP);
2. When complete, disconnect the printer from the PC;
3. Through Windows Control Panel => Programs (Add/Remove Programs if WinXP), find and un-install any instances you find of Datacard programs or drivers;
4. Reboot your PC;
5. From either the printer's install disk, or the manufacturer's website, download and install the correct driver for your Windows OS. If prompted to re-boot, do so. NOTE - do not connect the printer to the PC until you are either prompted to do so by the driver-installation program, or the installation completes normally and without errors.
6. Connect the printer to the PC. Give Windows time to recognize the device, associate the new/correct driver, and tell you it's ready for use.
7. Check in the Windows print center (Control-Panel=>Devices & Printers (or Printers & Faxes) to verify that it is now recognized as an EdiSecure printer.
Mar 31, 2015 | Datacard Office Equipment & Supplies
Brother dcp 7055 printer toner ended error
i haver Brother Laserjet DCP 7055 printer. Once i refilled its toner but now on 2nd time i refilled it the printer is gives an "Toner Ended" error & replace the toner message.... Pls help meto solve it... Thanks lucky bareilly
Jan 10, 2012 | Office Equipment & Supplies
My printer show the error 99 Ribbon Break/Jam but the ribbon is ok is not broken and i can not see some jam. Can you help me
Pls do the following:-
Ribbon Break/Jam
(PC Error Message No. 99, 108 and 109)
The Ribbon is not able to find the next panel correctly. Check for jams/breaks.
If jammed, clear the jam. If broken, repair by taping the Ribbon back on to the take-up core.
Press Resume to continue or Cancel to abort.
Thank You...........
Jul 26, 2011 | Fargo HDP5000 Thermal Printer
Datacard sp35 - cleaned it several times, First it will tell me the card is lost, we fish the card out, next it will tell me that the printer ribbon is broken. it is not broken, we have wasted so much...
Sounds like the rollers are going bad. From time to time the rollers on this device can definitely go bad. That's the reason you have to keep fishing for your cards. Try replacing the rollers on the device.
It may require some technical knowledge.
Please feel free to ask any further questions.
Dec 16, 2010 | Datacard SP35 Printer
Brother DCP 7020 Keeps giving me the "Drum Error" Message
Dear sir you see properly drum unite has a drum image sensor its demage so you change your copier drum unite, thanks.
Nov 17, 2009 | Brother DCP-7020 All-In-One Laser Printer
Keep getting broken ribbon message on zebra P330i printer
Oct 15, 2009 | Zebra Eltron P330i Card Printer
I'm having trouble with the Javelin J330i printer. When trying to print cards it doesn't pull them through correctly and then gives an error that the ribbon is broken. I have tried resetting the printer,...
check the feed tires ,the ones that feed the paper/cards into the printer. they maybe slick with paper dust. I recommend taking a cotton dish cloth or rag with some 409 cleaner on it the the feed tires clean all the paper dust off the tires let dry then try to feed card again. sound like the sensor is covered with paper dust, and is giving a false error.
Jul 09, 2009 | Javelin Systems Inc Javelin Viper PC...
P430i - Ribbon Broken / Out of Ribbon error
ribbon cut again and again after put 2 or 3 cards pls give instruction how to solve the problem.
Mar 03, 2009 | Zebra P330i Thermal Card Printer
Error / Ribbon Jam/Broken
When you open and close the lid on this printer, it tries to realign the ribbon. If you are getting this error, I suggestion you Calibrate the print ribbon through the print driver printing preferences on the Calibrate tab.
Dec 12, 2008 | Fargo DTC550 Thermal Card Printer
Datacard SP35 + giving broken ribbon error
You have to clean the roller under the printerhead.
The big black one..
I suggest you install Diagnostics.
Go to motor test, and take the transport fast reverse. 300 sec.
Now you can clean the roller easy.
Nov 25, 2008 | Datacard SP35 Printer
76 people viewed this question
jasbo
jasbo
