Question about Dell E172FP 17" LCD Flat Panel Monitor
Can i see the black diagram acer v193
Monitor no dispplay orange led keep on flashing
2 Suggested Answers
  • 3 Answers
SOURCE: Blinking Orange LED light on E151FP monitor
This monitor is know for a lot of parts that go bad, luckily they are usually the same ones.
If you are a technician or know one who can help you. Below is a list of part to repair/replace once the case is opened. (dont try this if your unfamilier with working on electronics.
1) F601= 2A Fuse
2) C605= 68uf 400v (must change)
3) R615= 0.68ohm 1watt
4) Q601= SSS6N60A
5) R613= 1Kohm 1/8watt (value changed to 2.3Kohm or higher)
6) R623= 4.7ohm 1/8watt (value changed to 7.2ohm or higher)
7) D604= 1N4148
8) IC601=UC3842B
9) C707 & C703= 1000uF 16V (must change, because of bad ESR value) secondary filter capacitor.
This problem of dell e151fp lcd monitor, you just need to resolder the inverter section (bad points or dry joint) and also check the capacitor value with ESR meter. It will solve your problems.
Posted on Oct 19, 2008
What is the best brand of monitor without lot of problem like black screen orange stand by light?
Any known brand, such as Samsung, Dell, Acer etc.
The main thing with monitors these days is to choose one that is LED back lit. LCD's use inverters that are very power hungry and they tend to burn out capacitors after a couple of years of use.
LED how ever are very low energy and don't need an inverter circuit to power the LED's, thus MUCH better life time.
Apr 30, 2014 | Computers & Internet
I have a acer.x223w when,it powers up the.screem stays black, n i get a blue blinking light on.the bottom
I disagree with ikkenom only due to the symptom of the flashing blue light. This would indicate to me that the monitor is not getting any display signal and is in sleep mode at least the is what happens on my Samsung monitor. Used to be that they use a two color led in the monitor, green when ON and getting display signal and amber or orange when in sleep mode. I would check the computer by trying a different monitor. If you have a second monitor, great, if not, maybe a friend will let you bring your computer over and try the computer with their monitor. Could also be a display adapter setting. Do you get any change when you first turn on your computer? i.e. Do you get the BIOS or manufacturer screen when first turned on? Also if you disconnect the monitor cable from the computer and power cycle the monitor, do you get a No Signal display for a few seconds before the monitor goes black and the blue light starts flashing?
Let me know what happens with the testing above or if you need further instructions to carry out testing.
Thanks, Jim
Feb 21, 2013 | Computers & Internet
My ACER Monitor shows green striped pixels wherever there is BLACK colors on the screen. Eg: Shadows in a video game, wallpaper with black background. It happens on and off, but the more it happens the...
The problem is either the video graphics card in the computer or the monitor, if you have a backup monitor check the computer first, if the same problem persists the video graphics card is bad. If however the second monitor is fine, then your monitor is the problem, The screen is breaking down, if you have a detachable video cable, sub it for another to make sure there are no issues,if okay your monitor is the problem and not cost effective for repair.
Jan 03, 2011 | Acer V193 Monitor
I live in Seattle and have an Acer V193B that 'went dark' when I hot-pluggged the VGA connector into my laptop. I *assume* the problem is the chip that buffers the VGA lines is blown. (I know the cable and...
maybe a short circut happened and fried your monitor's decoding unit... There probably is nothing you can do to fix it and you can't really do anything with it other than trashing or potentially expermenting with the thing, but bewarned, It may jump back to your laptop...
Oct 01, 2009 | Acer V193 B LCD Monitor
My monitor is new .. the screen stays black and the power button flashes green ... how do i fix this ????
Hi!
I have acer al1716 LCD and whan the computer is turn on, the lcd led turn green but the lcd is showing black, what i can do?
thank you!
Apr 16, 2009 | Acer AL1716 17" LCD Monitor
Sir Help me with my Compaq monitor MV520 it won't turn the power led flashing orange to green continously
it could be th epower supply and it could be the monitor.
power ON button should not flash orange regardless what you do. it should stay green. then orange. not orange to green to orange.
try the monitor on another PC if you can fine one.
the other thing is are the 2 monitor similar (CRT to CRT and LCD to LCD), you can't mix the the two, they will work but need different video driver to function correctly.
Oct 20, 2008 | Compaq MV 540 15" CRT Monitor
Acer Al 1714. LED light is blinking (orange not green).Monitor black.
Well, suddenly it worked again. But I waited the whole day >.>
Aug 22, 2008 | Acer AL1714 17" LCD Monitor
Acer aspire 9300 laptop
Right click anywhere on the desktop, open the screen saver tab, click on the power button at the bottom. You'll see a box that reads monitor, set this to never. That should take care of the screen shutting down. As far as the orange light, I'm guessing that's the battery light, and it's time for a new battery.(It should be green and flashes orange when the battery no longer works properly)
Jun 12, 2008 | Acer Aspire 9300 Notebook
Acer notebook not working
change ur battery n c.. i think ur battery is dead.. nt sure
Feb 14, 2008 | Computers & Internet
Dell E172FP 17" LCD Flat Panel Monitor Logo
81 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
