Question about Yamaha WX5 Midi Wind Controller
What might make my wx5 notes stick
My g and d keys won't work
How do I reprogram a ysmaha WX5 EWI.
look it up on a pc and see if they well give you the instructions on how.
Jul 04, 2017 | Music
With no octave keys pressed the wx5 is playing an octave too low
Please have a look at the instruction manual again. The 8ve keys are assignable/editable for up or down. You can change the range of the scale this way. I own a WX7 and a WX5. They both work this way.
Apr 17, 2014 | Yamaha WX5 Midi Wind Controller
Wx-5 interupts sound / chopped off sound
Please consult your manual again. The velocity and breath pressure are adjustable. The procedures and location of the switches and potentiometers are described in the manual.
Dec 21, 2013 | Yamaha WX5 Midi Wind Controller
Keys stick on yamaha wx11
It must have been dropped. Look to see if one side is bent so as to pinch the key. Gently pry it until it moves. Add lubricant if needed
Nov 26, 2013 | Yamaha WX5 Midi Wind Controller
Suzuki ss-100 piano keys stick, won't play
I had an issue with my Suzuki GP-3 and I did a research and found a company called VMI Electronics (619)244-0006 they found me a technician in my area also there is a repair kit called Key Mod that fixes issues with the keys hanging low, here is the link to order it on ebay: http://www.ebay.com/itm/Key-Mod-Piano-Rod-Replacement-Kit-/190822310728?pt=LH_DefaultDomain_0&hash=item2c6de56348
Mar 28, 2013 | Music
Ewi and vocoder setup
hi, i have a YAMAHA WX5, and want to know if it's to use a Vocoder?
Mike Phillips is the same, or if it only works with the EWI 4000s?
and as a connection is made?
thank you!
Feb 04, 2013 | Akai Ewi4000s Electronic Wind Instrument
Yamaha wx5 out of tune (1 tone to low) and pitch bend wheel working up but not down...
As an electrical engineer, I suspect that one end of the resistance element or the voltage supplied to it is broken. This could be a broken circuit trace on a board or failure of the pitch wheel pot. This is iff the device has a center tapped pot. IF IT DOESN"T (schematics are hard to find on this) then the bias setting for the pitch wheel may be wrong. First thing would be to look if the the wheel has slipped on the control shaft.
Jan 03, 2011 | Yamaha WX5 Midi Wind Controller
I can't get my Yamaha WX5 to sustain, or play more than one note. I got it to do it long ago by accident, but can't seem to get it to do it again. I think I was using a Yamaha Keyboard for the sounds at...
Reread your manual pages 14 and 15. Note page 14 tells you that "When using a monophonic tone generator such as the VL70m, the Normal Hold and Follow Hold functions CANNOT be used." I have both the WX5 and WX7. I also have both the VL70m and the WT11. The VL70m has a lot of better sounds, is editable and has better effects the WT11 allows you to use both follow modes. Any polyphonic midi keyboard with a midi in jack will allow you to use the follow modes. Read the directions on page 9 of your WX5 manual to hook your WX5 to the keyboard. Set your keyboard to receive all midi channels. I think it is Omni On, Poly. Hope this helps.
Nov 06, 2010 | Yamaha WX5 Midi Wind Controller
Wurlitzer organ, highest key plays note one octave too low.
If this is the kind of organ with the wire sticking out of the key that makes contact with the bus bar to create the note you will have to make sure that key is operating the same as adjacent keys. The busbars have to be clean and the contact wires have to be clean. Sometimes when cleaning the wires they will spring out of place and not make contact with the appropriate bus bars. Check that key against the rest and see what you find. Hope this helps.
May 17, 2009 | Music
2 keys(reeds) are not working ,my keyboard is yamaha DGX200,how to open it
It is a design fault. A technician advertising on the net informed me i can get it fixed by him and yamaha will pick up the fee.
Nov 12, 2008 | Music
Yamaha WX5 Midi Wind Controller Logo
63 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
