Question about Whirlpool Duet GHW9150P Front Load Washer
My Whirpool washer model # LA 9100XTWI is approximately 17 years old so the fix might be replacement; but the problem seems minor so here goes. To start the wash cycle the water usually runs into the tub as the soap and clothes are added. The water doesn't run into the tub. I have run it through all the cycles and it still won't allow water to run into the tub, rather Hot/Cold, Hot/Hot or Cold/Cold is selected. It did the same thing yesterday evening but today it ran a couple of loads after overnight. We have unplugged and allowed it to sit with no results. Is there some part not working, is is ready to die or should we contact a repair man? Thank you for any help you can offer
    Sergeant:
  • 296 Answers
Hi
chek this site to ve an indepth knowledge
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm/printable
http://www.repairclinic.com/0088_11_1.asp#Level1_3
hope u will b helpfull
do let me kno
regards
Posted on Jun 23, 2009
OUR WHIRLPOOL/CABRIO MODEL WTW6600SW2 IS FLASHING F1. WHAT IS PROBLEM?
Lool on this site for F1 fault. Apparently a very known problem, seems with control pcb. I called Whirpool today on a machine purchased in 4/07 with a 4 year extended warrenty from Lowes, and they didn't even question it. Said a repairman would be out to replace part and parts and labor are covered by Whirpool. Call them at their 1800 #, Mention it's the infamous F1 fault, have model and seriel # at rear of top load door ready for the technical help person, and they'll take care of it.
Dec 08, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
With my hpvs17e power goes on then a black screen why does that
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 21, 2009 | HP Vs17 17" LCD Flat Panel Monitor
MAG 700P monitor display goes black after 60 seconds
Can you send pictures of the power board to me at tech@ccl-la.com I will check our service manuals for the model and get back with you about a solution.
Buddy
Corporate Computer
Jun 29, 2009 | Mag Innovision LT782S 17" Flat Panel LCD...
Washer seems normal....dishes and inside of washer are stained and not clean. Using the same bottle of soap that we have been.
What is the manufacturer and model number of your dishwasher? Approximately how many years old is it?
Recommend two things:
1.) Switch to a brand name powder (like Electrosol or Cascade)
2.) Check (or have checked) the heating element in your DW. That will almost certainly fix your problem, unless your pump/impeller is being blocked by debris.
Good Luck!
Apr 01, 2009 | Dishwashers
Whirpool washer burning smell
i would consider getting aanother washer.if it keeps doing this the machine will cost you more than its worth. time to call a repairman in again id guess..
Jan 11, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
When energized, screen stays on for about two seconds then blanks
Hi...there,
Well, it's seems your monitor backlight inverter are bursted. Usually, the monitor had a 1 year for the screen panel and 3 years for parts and labors. You're still under warranty, send it back to manufacturer for repaired.
Nov 15, 2008 | Proview PL713S 17" Flat Panel LCD Monitor
Whirpool washer
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 12, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Mar 22, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Whirlpool Duet GHW9150P Front Load Washer Logo
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
