Question about Ovens
Kenmore glass top oven. Autonettoyant ultra brake. I purchased it second hand from a family who moved to a new city. It came with the house that they had purchased two years prior to that. Not sure of the year. All 5 elements on stove will not generate heat when turned on. All lights and clock work. It does say PF, power failure beside the clock. The stove and oven worked just the day before, what should I do? This single mom needs to bake her sons birthday cake for his 6 th birthday :)
  • 957 Answers
Unplug the unit for a few mins and then reconnect the unit. many times this will reset from a pf code
Posted on May 17, 2014
4 Suggested Answers
SOURCE: Neither heating element in oven will heat.
Get new heating elements
They are out
Posted on May 17, 2009
  • 2692 Answers
SOURCE: I have a GE Single Wall electric
First your broiler heating element may have gone bad and now you oven heating element may have gone bad. Using an OHM meter disconnect them and test for their value.Full scale on the meter means it is shorted. No meter movement means that it is open.Eitehr means to obtain a new element(s) and replace it/them.
Posted on Jun 11, 2009
SOURCE: I have a Kenmore Ultra Bake Stove, we had a power
PF is usually power failure.
If "PF" appears at any other time, a power failure occurred. To remove "PF"and to reset the clock, press STOP/CLEAR.
Unplug the unit for half an hour or so to see if it will reset.
If not try to get into the diagnostics so you can see if there is a stored
error code
Posted on Feb 15, 2010
Unable to remove light cover inside oven
I'm not familiar with that oven model, but as I have had a similar issue with my Neff oven light, I thought I would give you the benefit of what I had discovered. The light cover in my oven is a round, thick glass cover. The hand book has a graphic showing that the cover is simply twisted with one hand in an anti-clockwise direction as viewed straight onto the cover. No way! The first issue is that the lamp housing is right in a tight corner and getting sufficient grip on the cover is tricky. I put rubber gloves on to increase the grip and resorted to using two hands to exert as much force as I could manage, but it only moved a small amount. I think the movement was only the entire lamp housing moving in the oven wall, rather than any movement of the cover. I tried warming up the oven (not too hot) in the hope that the cover might release due to expansion, but no go. I then wondered if cooking grease / deposits and bonded the cover to the holder; although it appeared reasonable clear. This appears to have been the issue as I applied WD40 to the seam where the glass meets with the lamp housing and left it for a few minutes. It needed a second application, but eventually came free. On inspection, there was only a minor 'varnish' on the glass that appeared to have prevented the two parts from moving. Using WD40 weakened the bond eventually, but it also made the glass incredibly slippery, so gripping the glass cover after application is difficult. I used the rubber gloves and wiped the glass well to remove any residual WD40 prior to attempting to twist the glass cover off.
Oct 06, 2014 | Neff Ovens
Glass panel missing on grill (top oven) door?
if there seems to be a hole there and not a solid door then yes there should be glass there. try doing a goggle search on the brand . there might be a pic there to show you what is should look like.
Nov 12, 2011 | Ovens
Moved into this house. Has no manual on Kenmore glass top stove, on how to use self cleaning oven. Looking for manual or directions on how to use it. Only have model # 790.96011400 and serial # VF50635079
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 13, 2010 | Ovens
No manual to Kenmore electric oven 8+ years old
if the glass bulb cover has a 'wire' across it that's the spring clip that holds it in place.pull clip down or aside to remove cover,unscrew bulb as you would any other.if it doesn't have aforementioned clip.try to rotate cover counterclockwise to disengage 'ears' from 'slots',similar to the the way a blender fits the base.look under cook-top,above oven door for the lock lever that must be pulled out [engaged] for self clean to work.
Oct 11, 2009 | Kenmore Ovens
Kenmore Ultra bake self cleaning oven is showing code E0 - F2
My oven will not stay on, when started to preheat it will come on for a few seconds and they it will make a beeping noise and the codes E0 F2 will appear. The codes stay on even if the oven is off.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Glass top and oven 7 months old still has the new oven smell
possible that the insulation that surrounds your oven cavity has yet to fully cure, i would run a clean mode, this will get the unit to max temp fro 3 hours, fully curing any insulaton for sure
Dec 02, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
116 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
