Question about Ricoh Office Equipment & Supplies
How do I fix error SC552 on Ricoh 2000? - Ricoh Office Equipment & Supplies
pincer
  • 377 Answers
SOURCE: How do I fix error
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared.
The magic keystrokes, clear the error code:
The Fix
In order to clear error SC542, you must perform procedure 5810.
Press and hold online + escape, then power on.
Use up and down arrow keys to select SP2
Press Enter
Use up and down arror to locate SP5
Press Enter
Use up and down arrow keys to select 810
Press Enter
Confirm the selection
Power off and on.
The error code is now cleared
Posted on Oct 04, 2008
SOURCE: Error code sc 552 on Ricoh CL7100
To clear any code on a Ricoh / Savin copier that will no reset by turning the power off / on you need to first enter the service program mode. This is a safety feature installed when repeated resets of some codes could cause damage to the machine or possible fire hazard. Most of the time these codes deal with the fusing unit. The fusing units operate at around 180 degrees celcius. Thats pretty near the point where paper catches fire so you see the need for safety there. Anyway, you can sometimes get a false fuser code if the room is cold in the morning when you first power up the copier and the machine takes longer than normal to reach operating temp. Another reason can be that maybe you didn't push the fuser back in good enough after clearing a jam and the electrical contacts did not make good contact. In these instances you can clear the code and go back to copying. Should the code come back after doing one of these resets then it means there is a bigger problem with your fuser and you need to call for a service visit to have the problem fixed.
Here is the reset for it:
1. Press the Clear Modes (yellow on most machines)
2. Press the numbers 1,0,7
3. Press and hold the Clear / Stop (red on most machines)
after a few seconds on machines with an LCD display screen you should see the screen change to display "SP mode" with a few selections. On older or smaller machines without an LDC display screen you should see a flashing "0" on the panel. This lets the machine know its ok to reset the code. Do not make any selections in this mode. SP mode if for making electrical adjustments to the copier and taking the machine out of spec can cause a lot of problems for you. Once you enter the SP mode you just need to turn the machine off / on. (make sure you do so with the main switch that you have to rock back and forth and not the button that just gets pressed to shut down the machine, the main rocker switch is often located on the front door or on the left side of the machine, sometimes covered by a swinging cover you have to lift first)
If you do not hit the keys in the right order, the machine will not go into SP mode. You can just start over with step one untill you get into SP mode.
After doing this and the code resets but then comes back again or gives you another code, you'll have to place that service call. If not then happy copying to you.
Posted on Jan 14, 2009
  • 86 Answers
SOURCE: function sc:552 problem RICOH AFICIO 2018d
To reset error, enter SP mode by pressing: Clear (yellow) button, 1 0 7, and press and hold the Stop (orange) button for 3 seconds then switch off and on the copier.
If the error is still there, please check the following in the fuser unit;
  • Check and clean or replace the possible defective thermistors or out of position.
  • Fusing heaters open circuit.
  • Thermostats for open circuit.
  • Power supply unit.
Good luck and please rate me, thanks.
Posted on Mar 02, 2009
  • 4 Answers
SOURCE: Desperate!!! Ricoh AP3800C Error SC552 fixed last week now back
SC552 means that the pressure roller (Lower roller in the fusing unit located in the left hand door of the machine) is not warming up correctly. Is the copier installed somewhere cold? i.e. a garage? If conditions are ok and damp is not a problem, either the thermistor that controls the pressure temperature is defective, or the lamp that warms it up is defective. They are the two more common problems, might be worth looking for one on ebay. However they are approx 250 pounds so if you can find a second hand one thats cheap for spares I would recommend that. Email me if you have to do this and I will talk you through changing the parts.
Posted on May 14, 2009
newport74
  • 58 Answers
SOURCE: My ricoh sp c811dn suddenly started displaying the
552...... A Heating roller warm-up error 2
?? The heating roller temperature does not reach the ready
temperature for 90 seconds after the heating lamp on.
?? The heating roller temperature does not reach 80°C for 13 seconds
after the IH inverter on.
?? Defective thermistor
?? Defective IH inverter
Related SC code: SC 542
1. Check if the heating roller thermistor.
This code is there to prtect against high temp in the fuser that could cause a fire...best to have a tech look at it
Posted on Feb 26, 2010
Sc552-03 on my ricoh Aficio sp c830DN please what is the remedy
Jun 05, 2013 | Office Equipment & Supplies
I have a copier ricoh aficio 2550 and presents me code SC552. As the unlocking?
I have a copier ricoh aficio120 and presents me code SC552. As the unlocking?
Feb 13, 2013 | Office Equipment & Supplies
What's your problem?error code SC552 on ricoh savin c4540
fusing thermistor error, clean, replace the thermistor
Oct 31, 2011 | Savin Office Equipment & Supplies
Sc552
Pressure roller warm-up error
pressure roller thermistor bad or dirty
Jan 15, 2010 | Ricoh Aficio AP3800C Laser Printer
Error msg "sc552,Functional problem" on a Ricoh Afficio 1013F?
You either have a defective thermostat (thermistor) in your fuser, or a defective power supply. The error can only be reset by a tech in service mode after the problem is fixed
Jul 16, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Function sc:552 problem RICOH AFICIO 2018d
Mar 02, 2009 | Ricoh Aficio AP3800C Laser Printer
Dec 23, 2008 | Ricoh Aficio AP3800C Laser Printer
How do I fix error SC552 on Ricoh 2238C?
The Fix
Press Enter
Press Enter
Press Enter
Power off and on.
Oct 04, 2008 | Ricoh Office Equipment & Supplies
Functional problem sc552
I take it this is for a Ricoh?
SC552 is a pressure roller warm up error. It didn't detect the right temperature when it was turned on.
Turn the copier off for 30 seconds and then turn it back on again. If the error message returns, a technician should look at the fuser section to see whats causing the problem.
Aug 01, 2008 | Office Equipment & Supplies
21 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
