Question about Sharp EL-738 Scientific Calculator
Which is the data key on the sharp el738f - Sharp EL-738 Scientific Calculator
    Scholar:
    New Friend:
  • 74 Answers
Use the ENT key for data entry.
So press mode 1 for stat then type in the value e.g. 23 and press ENT.
Posted on May 16, 2014
How do i calculate interest on a R20000.00 loan at 13% for 5 years on teh sharp el738f calculator
First make sure all previous amounts stored are cleared by pressing 2nd F MODE.
Then type in the original value 20 000 and press PV.
Type in the interest 13 and press I/Y.
(If i assume that the interest is compounded yearly my calculation is more simple)
press 5 and N
Press COMP FV and your answer will be - 36 848.70
(If I assume that the interest is compounded monthly, i need to input a little bit more data into my calculator)
Press 2nd F I/Y (to get to payments per year) and press 12 and ENT. Press ON.
Then press 5 and 2nd F N and then press N again.
Now calculate FV by pressing COMP FV which should give you - 38 177.13.
Take this value and subtract the PV from it to get the amount of interest earned.
May 16, 2014 | Sharp EL-738 Scientific Calculator
To input data on the SHARP EL738 you need use the ENT button. Type in the data value and press ENT after it.
Can't find statistcal mode
Press the MODE button (below on) and choose 1 for stat (press 1) then choose SD for single data (or univariate data) and LINE for bivariate data (two-variable data).
To carry out the calculations you need to press the ALPHA key first and then press the number key with the blue statistics function you would like to do. For example, pressing ALPHA 4 will give you the average.
Apr 06, 2014 | Sharp el-531x scientific calculator
Sharp advanced EL-531x how to input number after number for stats
First you have to set the calculator in STAT mode, presumably Standard Deviation or SD. The display should show a STAT annoucer to the top. To enter values use the key M+ (or the key next to which is marked DATA. The screen displays the number of data values entered so far.
To get the statistics you must use the keys marked with x bar, n, Sigma x, etc.
Feb 27, 2013 | Sharp el-531x scientific calculator
SHARP MX-3100N CODE E7-06
MFP -Image data decoder error
Try to clear code. enter sim with program key- asterisk*-clear key- asterisk*(P-*-C-*) enter sim 14 print key execute yes clear all machine will reset. if code comes back it is not just not a fluke and you may have another issue.
Aug 28, 2011 | SHARP MX-3100N
Can not find Calculator Solution Data Input Function Key for corp finance work on bonds valuation.
To enter data in stat mode, use the Change key.
MODE 1:STAT
Choose Standard deviation or any regression model
In standard (0:SD) deviation,
If a data item has a frequency larger than 1 (the elemnt is repeated), the sequence is as follows. 15 repeated 3 times
15 [(x,y)] 3 [DATA]
Feb 06, 2011 | Sharp ELW535 Calculator
How do you reset a Sharp Scientific Calculator Model EL-5103 and is a manual available? Old but still working.
Reset instructions from the Sharp Instruction Manual include removing the batteries, re-installing them, then pressing the [OFF], [ON], [2nd F], and [CL] keys in that order. This will erase any saved formulas and data.reset-sharp-scientific-calculator-oaktevzxqwobflsbvgxv12ee-1-0.jpg
Jan 08, 2011 | Sharp Office Equipment & Supplies
How do you reset the X/Z reading , my readings just keep accumulating?
Turn the key to X or Z position then first press the dot (decimal) button and after that press the CA/AT/NS button. And your data reseted to 0. If you key is in the X position you are reseting the X data, in the Z position you are reseting the Z data.
Oct 21, 2010 | Sharp XE-A404 PC Desktop
My Sharp XE A203 has ceased operation and shows IPL on the screen. Nothing works! Help!
hmmmmmmmmmmmmm
press CL key ,didnt change display,
when power on & remove your batteries one by one
then replace batteries again one by one
display **** MRS *************** and press CL key
then machine came normal condition
but your data is lost.
reenter your detailss
Jul 05, 2010 | Sharp XE-A402 Electronic Cash Register
Sharp OZ-730 sticky keys
I have a a Sharp yo-480. I've fixed sticky keys many times. I back-up data in the organizer first. (yo-480 doesn't have a flash memory) then carefully dissasemble unit. Lift out rubber keypad and use WD-40 to wipe circut board and keypad. It's the sticky residue that makes the keys stick
Nov 16, 2009 | Sharp Wizard OZ-730
Sharp EL-738 Scientific Calculator Logo
370 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
