Question about Airtemp Heating & Cooling
I need a new plastic control knob for my Airtemps air conditioner. Below it says "MASTER CONTROL" and it controls the fan and air conditioning levels. Model number B1V10S2C Serial number KL389479 2929 Can I get this part ASAP?? Thanks, Alice Barden
  • gitlbarden Jun 23, 2009
    Thank you!!!
    Genius:
  • 1,847 Answers
You can get the parts from this link....
http://www.appliancefactoryparts.com/airconditioners/airtemp/b1v10s2c.html
Let me know if you need further assistance
Thanks
Kevin
Posted on Jun 23, 2009
I want to install an air conditioning unit on the roof of a 1995 ford econoline van. How do you do it?
The air conditioners on RVs are 110 volt AC. They do not run on 12 volts and should not be run on inverters. You would need at least a 2000 watt generator, preferably 3000.
If you have the power, it requires cutting a 14 inch square hole in the roof. The air conditioner is clamped down by 4 bolts from the inside, part of the internal control package. You would need what is called a "non-ducted" inside unit which would have the thermostat and control knobs.
Mar 14, 2015 | Heating & Cooling
I need a master control knob. I don't know the model number of the Emerson Quiet Kool air conditioner.
Without the Model Number, it's hard to know what knob fits your model. However, the link below, may provide some help. But, having the Model Number would be a bulls eye. Remove the front of the AC unit. There may be a manufacturer's data plate inside, which would provide the model number.
http://www.appliancefactoryparts.com/airconditioners/emerson/emerson-knobs.html
Hope this helps you.
Jul 13, 2011 | Emerson Quiet Kool 6GC53 Air Conditioner
The control knob on my Carrier model Vision Aire window air conditioner broke. I'd like to buy a replacement know to control the fan.
Jules, without a correct Model Number (not Vision Aire, that's just a glitzey name), it's hard to steer you in the right direction on where to find the knob. If however, you can come up with a correct model number, you can go to the link below and search for it by your Model Number.
http://www.appliancefactoryparts.com/airconditioners/carrier/carrier-knobs.html
Hope this helped you.
Jul 06, 2011 | Heating & Cooling
Amana ptac ac turn on runs short time on cool and go to fan mode warm air.
If this unit has the old style control with the knob instead of the digital control panel
then I would suspect this first. This is the first component to fail on these units. I have
replaced two already and the kit has good instructions and all components.
Takes approximately an hour to do and mount the new sensors. (The transformer is
hidden beneath the sheetmetal just below the control board). You should be able to order this kit through any appliance parts store for around 175 dollars versus almost
800 dollars for a new PTAC. Hope this is helpful.
Jun 26, 2011 | Amana PTH123B25AJ Heat Pump Air...
Heat blows out at floor only and ac does not come on even though light Indicates it's on. Has rear defrost and light works..Also has recirculating air button . I'm guessing the whole heating control in...
I would first remove the fuse for the heater control head for one minute and then put in and retry.
The control head could have locked up on you with a volt spike. The rear defrost switch does not go through the same circuit in the heat as the hvac controls. Could be a broken know also.
Could also be mechanical linkage on side of heater box above accelerator pedal may have broken or popped apart. or if electrical motor control may be actuator.
#76-11-01: HVAC CONTROL KNOB SPINS FREELY (REPLACE) - (Oct 9, 1997) 999999995.gif SUBJECT: HVAC CONTROL KNOB SPINS FREELY (REPLACE ALL THREE KNOBS)
MODELS: 1996-97 CHEVROLET AND GMC M/L AND G VANS 1995-97 CHEVROLET AND GMC C/K TRUCKS
CONDITION:
SOME CUSTOMERS MAY REPORT THAT ONE OR MORE HVAC CONTROL KNOBS SPIN FREELY, RESULTING IN LOSS OF FAN, TEMPERATURE AND/OR MODE OPERATION.
CAUSE:
THE KNOB'S PLASTIC INNER SHAFT MAY CRACK WHEN FORCED AGAINST ITS STOP.
CORRECTION:
IF ANY ONE OF THE THREE HVAC CONTROL KNOBS EXHIBITS THIS CONDITION, REPLACE ALL THREE KNOBS WITH NEW P/N 16268157.
PARTS INFORMATION:
P/N DESCRIPTION QTY 16268157 KNOB, HVAC CONTROL 3
Sep 27, 2010 | 1995 GMC Yukon
Knob control stems cracking
hello. when the stems crack, it is generally due to age and drying out of the plastic. you may be able to get new knob controls at your local appliance store. You can also do a repair with some clear one minute epoxy. J.
Jun 24, 2010 | Goldstar R1203 Air Conditioner
Dometic air & analog thermostat control kit
Had one doing similar recently, and after a thunder & lightning storm. Nothing worked, but kept blowing 2 amp fuse in thermostat, when anything tried, heat or cool. Pulled plastic control box down from inside upper unit (AC) made sure breaker was off, took of plastic cover and smelled inside, and could smell burnt plastic smell. Replaced, control box, that got fan only working. Tried another thermostat , everything worked as it should. Turns out the lightning, or power surge, or whatever, shorted out the thermostat, and control box at same time.
Aug 03, 2008 | Dometic Rooftop RV Air Conditioner
Master control knob
I am not sure which knob it is. but I believe these are the part numbers for the knobs on your machine.
CRC111404290011, CRC111404290019, 111404290019, 111404290011, 111404290023
Check this link. It shows a thermostat control knob in stock.
http://www.appliancefactoryparts.com/search/modelinfo.php?modelsID=115657&typeName=air%20conditioner
Jun 30, 2008 | Hampton Bay HBLG5004 Air Conditioner
Broken Knob for fan control
once you take off the front housing, the switch itself shoud be easy to remove and replace...sometimes, a used appliance store/repair office can get a suitable replacement part. Trick is to mark the wires as you remove them from the switch and take hte switch with you while you go part hunting. Also would help to have model and serial number (and brand name) noted to take along. Papdaddy
Sep 22, 2007 | Comfort-Aire CS-101A Air Conditioner
Heating & Cooling Logo
22 people viewed this question
Top Airtemp Heating & Cooling Experts
Tim Whalen
David White
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Airtemp Heating and Cooling Expert? Answer questions, earn points and help others
