Question about 3Com Computers & Internet
How to do a power on self test via cli - 3Com Computers & Internet
My 2013 VW beetle power windows are no longer working
You need to have the BCM (Body Control Module) put thru a self test, the windows are controlled via this computer module.
Jul 06, 2017 | Cars & Trucks
I have a johndeer f725 it runs on one cly. what is wrong?
do a compression test on the engine looking for burnt valve or a valve held open on the one cylinder.
Jun 16, 2013 | Garden
My canon ip1900 is printing with smudged lines how can i resolve this
troubleshoot the problem to canon website and they will lead you to a self diagnosis that will correct your printer
Jun 29, 2012 | Unknown 7 Pk Canon Compatible Pgi-5bk...
Beltronics rx65 service required can I fix this problem??
This detector - along with other high-end types that require a microprocessor to analyze signals - performs a self-test when powering up. This is done for the same reasons a Power On Self Test is done on your computer. There's a lot going on inside and if just one area is malfunctioning data may not be processed correctly and in the case of the detector - resulting in aggravating false alarms or worse - not indicating an alert when needed.
You should arrange for the detector's return to Beltronics for thorough checking / realignment. Contact Beltronics via this link.
I hope this helps!
Mar 05, 2012 | Beltronics Vehicle Parts & Accessories
No display, light goes green but on screen says no connection then goes yellow for standby tried both DVI and VGA so now linked my pc to my tele via DVI to HDMI and works fine anyone know what this could...
here is the simple test to detect hardware malfunction.
on every monitor these days whether its CRT or LCD already programmed inside self test.
detach your cable data to CPU and power on your monitor. if its displayed self test on your screen mean its OK and something wrong with your CPU, could be VGA error.
if its just black display mean some is wrong with your monitor.
if you post more detail maybe we in FIXYA could help.
thanks.
Mar 11, 2011 | Hannspree HW191D LCD Monitor
Dell 1704 monitor goes to black screen after one
Hi my name is Rain.
Ok so that im clear on the problem. your monitor will come on but in a matter of seconds it goes to a black screen?
If this is the problem. The answers you seek will most likely
be in your video card.
Try this test:
  • Unplug monitor from the computer.
  • Turn on monitor .
  • Look for monitor self test screen.
If you see the monitors self test screen then your problem indeed is
the video card . You will need to replace the video card inside of the computer.
Nov 23, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Benz e420 multiple cyl missfire
hello,good day,hoping your car is already scan with hht or star,then engine missfiring very general,you have to check fuel injection and ignition system,hoping your fuel system is clean,if your tester appear your cly.8 coil is defect,try to put cly.8 coil in other cly.for testing purpose,hoping your engine is v-8,119,or 113,or try to check the pressure diapram in fuel rail,ty
Jun 24, 2009 | 1997 Mercedes-Benz E-Class
No CLI on my Philips CD130
I downloaded the CD130's manual and noticed that this problem was to do with my service provider.  I contacted them and confired that I needed to initalize the function via them.  So now I know!
Sep 27, 2008 | Lands Phones
Cisco 1750 not showing anything in cli in hyperterm
First, make sure your terminal settings are correct.  Also, make sure you are using the right cable.  Cisco provides a flat, blue console cable with every router and switch.
Cisco lists the necessary terminal settings for most of their models here: http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008010ff7a.shtml
Power off the router and then power it back on.
If you are still not seeing any characters through your terminal application, then the router is most likely dead and will need to be replaced.
Sep 16, 2008 | Computers & Internet
Computers & Internet Logo
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
