Question about Ovens
Where can I get a replacement "Oven Function Selector Switch" for a BOSCH OVEN - Model No. HBE632UAU/03 (Year of Manufacture 1991) Part No. 05 5870 which was later replaced by Part No. 05 9863. The mechanical shaft component of the switch that connects directly to the function knob has broken in half & needs replacing. This metal shaft/rod is coated in bakerlite substance & has 4 sets of raised cams that engage to each of the 4 indivdual switch plates when the Oven Selector Knob is turned. It appears to have been weakened by years of heat. Bosch in Melbourne, Australia have told me they no longer make/stock this part & I am hoping someone still does or has an old switch that still has an intact rod. Even if I could get the ROD/SHAFT component only, that would still enable me to repair the switch.
  • 957 Answers
Try going to goole.com and put in appliance parts there will be a number of sites that will come up many in the USA that have many parts.
Posted on May 17, 2014
How do I turn the Miele oven on? Model is H6260BP
To turn on the oven, press the recessed On/Off button on the left below the rotary selector knob. Make sure that the system lock is off. (The display will show S 1 if it is on.) Press and release the function selector and rotary selector knobs if they are retracted. Rotate the function selector to the desired function icon (line up the dot). Then turn the selector knob to select the oven temperature. Press OK to start cooking.
Miele has the manual for the H 6260 BP oven on the product site on the Downloads tab: https://www.miele.com.au/domestic/ovens-1451.htm?mat=09514470&name=H_6260_BP . The direct link to the manual is https://www.miele.com.au/pmedia/ZGA/TX3587/10108150-000-01_10108150-01.pdf . See page 21 for a picture of the oven controls.
I hope this helps.
Oct 04, 2016 | Miele Ovens
I have a Bosch oven with the "key" sign constantly lit and the oven won't function at all. Re set it at wall etc.
the key sign shows that the child lock is engaged. to unlock, usually you push and hold the lock button for a few seconds. the correct button is usually a dual function and so marked. if you need more help, go to manualsonline.com and look up your model number for your manual. good luck
Dec 27, 2015 | Bosch Ovens
I have a Bosch wall oven in my unit but no user manual. The number on the door is bosch hbe632uau/03. Is it ok to close the door when using grill function or will the glass blow out?
if the grill section is behind the oven door then the door should be open
if there is a door for the grill section then the oven door can stay closed
to get a user manual ,go google and type in-- user manual for bosch oven model ( type in what you have) --( or leave it out if it doesn't recognize the model)
If a page is available with a pdf version you can down load it
Oct 19, 2015 | Bosch Ovens
My Neff oven is displaying the locked "key" symbol...does anyone know how to unlock please?
Locking the oven:
Using the main oven function selector, switch 3 x in
rapid succession from the 'off' position to the
oven light function and back again.
- s - is displayed.
The oven cannot be unintentionally
switched on, e.g. by children.
To release the oven, switch 3 x from
the 'off' position to the oven light.
- s - goes out.
Mar 21, 2013 | Neff B1641 Single circotherm super...
Need to replace my oven selector switch on my bosch oven HBN13M55OB/03
My apologies - I submitted this last night but upon checking for any reply from you, I noticed it had not been posted on the page. I now have to write the entire message again!
Obtaining the part is easy, however fitting it is going to be somewhat more difficult as it's a double oven - meaning it's both higher and heavier. Access for replacing the switch and removing the front panel is from the top so the oven will need to be pulled out from the cabinet or removed. However, the double glass doors make the oven rather front-heavy so it's inclined to topple forward!
This is an expensive appliance and I recommend getting this job done professionally. Should you decide to do the job yourself, you do so at your own risk and you should follow all of the saftey instuctions carefully.
The best - and usually cheapest - place to get any genuine Bosch part is directly from Bosch. They normally deliver in 2-3 working days. The Bosch part number you need is 602732:
http://www.bosch-eshop.com/eshop/bosch/gb/prodlg.htm?Maktx=602732&eshoptype=A&autoselected= £19.63 inc. postage
Click on "Add to Basket" and then "Finish and pay >"
Fitting instructions:
I prefer to do this job with the oven fully removed from the housing but it's probably hardwired to the switch/breaker and needs two people to lift it out. Not removing it also means you have to work at a much greater height, so I recommend complete removal, if possible. The job can be done with the oven only half pulled forward from the cabinet, but the front of the oven needs to be fully supported after pulling it forward or the weight of the doors can (and will) cause it to topple forward.
1. Power off at the breaker/main switch. If you are going to completely remove the oven, you will need to power off at the main fuse box and then remove the oven power cable from the switch.
. Remove the screws which secure the oven to cabinet - these are at the sides and are only visible with the doors open
. Pull the oven control knob off of the fascia panel.
. Remove the oven completely or pull it forward half-way (see above)
5
. Remove the front half of the top panel of the oven. I think it just unclips on these, but there may be a couple of screws to remove at the side first. You will now have access to the switch area.
6
. Make a detailed note of how all the wires are attached to the main oven switch. It's a good idea to take a digital photo for reference. Some of the wires are the same colours so make sure you don't get them mixed up. Also, some of the terminals on the switch are double, so it's best to draw a diagram and give all the terminals numbers and record which wire goes to each one.
7
. Detach all,the wires from the oven selector switch. There is another white "box" attached to the back of the switch, but you don't need to disconnect the wires from this. This box is the thermostat which is attached to the temperature probe in the oven with a long wire.
8
. Remove the screws securing the selector switch to the oven and detach the switch. Make note of how all the parts - switch / bracket / support, etc - fit together. Another digital photo may be useful here.
9
. Unscrew and pull the thermostat out from the back of the selector switch. You should now be able to remove the switch from the oven.
10
. Assemble the new selector switch with the bracket, support, thermostat, etc and secure it to the oven.
11
. Refit everything else in reverse order of the above.
This may be a little bit more complicated than you were expecting. If you don't feel confident to do the work yourself, then please seek professional help. If you do decide to DIY and you let me know when you are planning to do it, I can try to be online to assist you if you get stuck anywhere.
Merry Christmas!
BElectric
Dec 18, 2010 | Bosch Ovens
Need selector switch for upper oven
If you are in the u/k, then try these sites
WWW.ESPARES.CO.UK/BOSCH
WWW.4BOSCH.CO.UK/SPARES
If elsewhere, then type in BOSCH SPARES in the your browser bar, and you should be able to find someone who supplies Bosch spares.
Feb 06, 2010 | Bosch Appliances 27 in. Wall Oven Electric...
Bosch oven function error e124
Can you provide a model number for your oven. Is it a single oven or double ? Wall oven or free standing range ?(conventional with cooking surface)
Unfortunately the error codes for Bosch are different depending on the model of the unit.
Thank you, I`ll look for your reply.
macmarkus :)
Jan 09, 2010 | Bosch Ovens
Retractable function selector knob stuck
facia panel most probably need removed, not to bad a job, but oven need to come out... go to bosch, web site...search parts finder with your model , and you will see an exploded diagram, this may help yet you get an idea on how it comes apart.. failing that call an engineer...
Jul 02, 2007 | Bosch HBN 560570B / 560550B Electric...
Oven will not heat?
you have the oven on automatic in error. switch off at mains. leave for 5 mins. turn on, consult your handbook on how to set clock and having done this, bet it works
Jun 12, 2007 | Bosch HBN 43L550B SS Electric Single Oven
Double oven / convection not working
It is likely that the convection element is burned out and needs to be replaced. If all other functions are working then this is the place to start. Teh back panel inside of the oven can be removed by removing the 4 visible philips screws on it. The element should look smooth and round, if not then it needs to be replaced. Be sure to turn power off to the oven before replacing it. Remove the screws that fasten the element to the back wall and gently pull the element away from the wall an inch or so. the wires will be exposed and can be unclipped from the element do not let them fall inside of the back of the oven or you will have to remove the oven from the wall to get at the back panel. Install the new element in the reverse procedure. If the element looks good then it will have to be tested with a multimeter to verify that it is still good before proceeding to check the selector switch for burn marks.
Dec 10, 2006 | Bosch HBL 455 Stainless Steel Electric...
Ovens Logo
78 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
