Question about LG Computers & Internet
Need driver for lg l226-wty-bf - LG Computers & Internet
Need electrical diagram for LG flatron l206wtq-bf
hello Buddy Mcsparrin for 5 parts capacitors how much ohm did you add with screwdriver to discharging capacitors ?
Oct 06, 2012 | LG FLATRON L206WTQ-BF Monitor
Hello my flatron l206wtq-bf doesnt work the light of power flash blue and the monitor doesnt open do you have a solution for me thanks
Your unit has a power supply that has failed. When the power board starts failing you may get a wavy display, it may be slow to show a picture or you may just get the flashing power button light that you have. The problems are caused by parts called capacitors that have bulged and failed. Here is a link to a repair guide for the LG L226 that uses the same power supply board as your unit.
http://www.ccl-la.com/blog/index.php/lg-l226wtq-bf-monitor-repair/
The dis-assembly information is almost the same to.
I hope this helps, if so please rate my solution.
BuddyMc
Aug 01, 2011 | LG FLATRON L206WTQ-BF Monitor
Cannot find drivers for lg l225wt monitor for w7 support
Here is winXP/Vista driver.
Usually Vista drivers works on Windows 7 without problems.
May 11, 2011 | LG L225WT-BF 22 inch LCD Monitor
Hi i have a lg l226wty-bf monitor that does not turn on and has a blue led flashing on and off under the power button. What do i do?
Open and look at the tops of the capacitors. I bet there are at least 2-3 "bulging" tops. Replace them and the problem WILL be solved;.
Apr 07, 2011 | LG L226WTY-BF Monitor
Need monitor driver for LG Flatron L1752T. Thank you
You can download the driver from the following site:
http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=L1752T-BF&initialTab=drivers&targetPage=support-product-profile
It is under the drivers and software tab.
Please leave feedback if this was helpful. Thanks.
Mar 18, 2011 | LG L1752T-BF 17" Flat Panel LCD Monitor
How do i dismantle L192WS LG monitor ? please help
We have a full disassembly and repair guide for this model monitor posted on our site at:
http://www.ccl-la.com/blog/index.php/lg-l196wtq-bf-lcd-monitor-repair/
I hope this helps, if so please rate our solution.
BuddyMc
Jan 01, 2011 | LG L196WTQ-BF 19" Monitor
My model no is FLATRON L1752S-BF and serial no is
The LG Flatron L1752S is made in 2006. You can go to LG website here. I do not believe it is under warranty. http://www.lg.com/us/support/repair/support-warranty-claims.jsp
Apr 05, 2010 | Gateway FPD2275W LCD Monitor
Can't get monitor to power on
I have a similar switch on mine, although mine is a Gateway. So my solution is going to assume the same indicators and functionality.
On mine, a blue-violet power switch indicates it is off, red indicates standby mode, and blue to indicate it is on and/or searching for a signal. When turned on (blue), the monitor will go to standby mode (red) after 3 to 4 seconds if it does not detect a source signal. So if you toggle the power switch to blue and it soon changes to red, you'll need to check your signal, cable, or possibly for a bad source connection on the monitor.
Oct 12, 2009 | LG L206WTY-BF Monitor
Bafo bf-1284 can't detect
I need a driver for BF-1284 in windows xp
Aug 29, 2008 | BafoTech BAFO BF-1284 Parallel Adapter
Computers & Internet Logo
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
