Question about Samsung HP-S5073 50 in. Plasma HDTV
Tv wont turn on but light in front blinks\ - Samsung HP-S5073 50 in. Plasma HDTV
2 Suggested Answers
Axle80
  • 73 Answers
SOURCE: Wont turn on and front lights blink
Start by checking the lamp, there's no sure fire way to tell if its the lamp or not.Remove the lamp housing door off the back right side of the tv (if you are looking at the back of the tv, it has one black screw holding it in place. Look inside and you'll see the black and silver metal housing. Then loosen the gold screws on each side of the lamp housing. You'll know you're looking at the right thing because there is a black handle that lets you pull the housing straight out (after loosening the screws, the screws wont come completely out). Take into account the amount of time it has been since you replaced the lamp, 3-4 years seems to be about average. You won't really be able to tell if the lamp is burned out or not by looking at it. Sometimes there is a break in the glass tube inside the bowl, sometimes its a white powder in the small bulb at the bottom of the glass tube. Either way, use the stickers on the housing to get your lamp number and order a bulb. Rivervalleyelectronics.net is a great place to look. I use them all the time. Any osram or philips bulb off ebay will work fine too. Email me directly if you need further assistance. Cfoley@hawaii.rr.com Good Luck
Posted on Jun 13, 2009
Standby light blinks and tv wont cut on
How many times the standby light at its front panel blinks? Count it. These blinks are fault indications. Check this link for more details about Sony Blinking codes. Count the blinks that occur once, after switch the TV On by its front panel power switch. Check it.
Jan 02, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv wont turn on, the power indicator nor the remote receiver light does not light up, the 3rd circle on the front of the tv blinks red!! But it wont come on regardless, tv is only 2 years old, what to...
The blinking red light means set is in shutdown because of a short inside the tv.
Someone to begin would have to open it and check power supply voltages inside the set....that is the first step.
Mar 18, 2012 | Televison & Video
Tv wont turn on, just red light blinks
From the owner's manual of that model:
If a red light is blinking on the front of the TV, the set has entered protection mode. If this happens it usually means you simplyneed to reset the TV. Unplug the TV for 60 seconds. Then plug the TV in and try to switch it on. If the light is still blinking red,call the Customer Care Center at 1-800-531-0039
Dec 08, 2011 | Philips 55PL9524 55" Rear Projection...
Red light is flashing on front of tv and it wont turn on
If the red light is blinking but wont turn on . your tv has a defect. maybe the defect is on the board. causing not to osolate.needs a qualified technician to fix your problem.
Jun 24, 2010 | Toshiba 32A33 32" TV
Screen wont come on
Your color wheel has gone bad. I recommend this repair to only be done by a qualified Samsung service center. Part costs less than $100
Jun 01, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Hitachi 50v500 tv lamp light blinking no picture
I have one of these units, if the light is blinking and no picture as you have stated then you will need to replace the bulb in the unit. it is contained in the front of the unit behind the front panel on the right, you would remove the front panel after unplugging the unit, remove the single screw and pull out the box. replace it and then reverse the proces. the bulbs can be obtained for about $130.00 to $200.00 depending on where you get it from. Shop around.
Feb 07, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Tv not working after lamp replacement
CK Fan if it is going bad set will shut down.
Feb 06, 2009 | Televison & Video
My samsung tv wont turn on, red light keeps flashing on the front.
i had this with my samsung and my mums instead of pressing red power button press either switch from analog tv to digital button or just press a number
Jun 04, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Samsung HP-S5073 50 in. Plasma HDTV Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
