Question about Health & Beauty
I have a quingo compact scooter. Battery gauge says it's fully charged. Indicator light flashes 5 times then stops for a second then 5 times again. What does this mean?
    New Friend:
Hi
Hi have just bought a second hand quingo compact it's like brand new and everything is fine with it except the battery indicater the needle dosnt move is there a fuse for this I did notice a small amount of condensation but as the back light is working I don't think that is the problem
Any advice please
Posted on Jul 20, 2016
PLEASE CALL THE QUINGO CUSTOMER SERVICE LINE ON 01582 430900 AND ASK FOR JULIE SHE WILL BE ABLE TO HELP
Posted on May 16, 2014
SOURCE: battery power on mobility scooter
The Hand Control has probably bent in from use. ( Where she Pushes the throttle Control )
Grab a hold of it and bend it out towards you slightly
The part about the indicator going down when she moves and back up when she stops is normal
Posted on May 07, 2009
gewiz
  • 1271 Answers
SOURCE: pride mobility scooter. turn key on it keeps
Are you sure that it not in FREEWHELL mode, lever at the back, Regards
Posted on Jun 13, 2009
  • 177 Answers
SOURCE: just bought my dad a second hand go go 3 wheel elite scooter
Hi Linda. Sometimes if there is a blown fuse or faulty connector on the battery leads, the charger thinks the batteries are charged as the voltage coming out of the charger rises to the high level. Some chargers will cut out if this happens. It is probably not the charger.
Make sure the batteries are plugged in correctly, sometimes during transport they will get knocked and become disconnected.
Also make sure that the battery terminals are not loose where the wires connect to the batteries.
Good luck. Neil.
Posted on Jun 05, 2010
  • 177 Answers
SOURCE: Scooter stops intermittenly
Hi. Does the machine stop suddenly, or does it slowly stop as it normally would? Does this happen on hills or slopes?
A lot of scooters have a self-resetting circuit breaker connected to the battery leads. If the machine draws to much current ( amps ) then the circuit breaker trips out. After a few minutes the circuit breaker will reset and you can continue.
This could mean that the circuit breaker is faulty or that the motor is drawing to much current, or is burnt out.
Some machines have a very light duty circuit breaker, and these can trip out often. I have changed many of these circuit breakers for this reason.
Check all your battery leads are secure and tight.
If it is still a problem, get a serviceman to check the motor current is what it should be.
Good luck. Neil.
Posted on Jun 07, 2010
mcdevito75
  • 1970 Answers
SOURCE: Battery full on Ascot Mobility scooter but wont start
mcdevito75 here, Double chek the connection at the battery and motor.
Posted on Jun 26, 2010
Why would the power indicator blink?
The amount of times the light(s) blink is a flash code that indicates what the problem is. Count the number of times it flashes then pauses. We can answer your question when we know what flash code you are having.
Aug 23, 2014 | Drive Medical Phantom 3 Wheel Compact...
My Zip'r 4 is flashing the green light 7 times which means, "A throttle fault has occurred." The Throttle seems to be working fine, How do i fix this issue?
One of the cells of the battery seems to be bad. Though you charge it, and it shows full charge, but at the time of using the throttle the kinetic power is not there. I recommend that you take the battery to battery ware house so they can confirm the problem. If the problem is not with the battery then the issue is with the circuitry, but most likely it is the cranking power of the battery, though it is fully charged, but it get exhausted right away..
Jul 07, 2014 | Zipr Mobility Zipr Xtra 4-Wheel Hybrid...
How can I fix This problem. after about 1.5 miles the scooter comes steadily to a stop. waiting for a few minutes it will go again Ok.
The motor is overheating. The service manual will tell you how to test. Pride has a service manual you can download from their website.
May 20, 2014 | Pride Go-Go Ultra X 4-Wheel
Aquasoothe travelite scooter, the batteries are fully charged, the battery gauge is showing full, but the battery light is flashing. It flashes 7 times then pauses, we can't get the machine to move or...
Response to similar query in 2011.
http://www.fixya.com/support/t5751777-aquasoothe_travel_lite_instruction
not my words. The link to the pdf for this is http://www.discovermymobility.com/store/scooters/summit-scooters/elite-portable-scooter/manual.pdf
you want page 22.
Problem Check Point
The driving of the wheelchair is too slow or insufficient, the status
indicator lamp flashes slowly Batteries are exhausted and need to be recharged
1 flash The battery needs charging or there is a bad connection to the battery. Check the connections to the battery or charge batteries.
2 flashes There is a bad connection to the motor.
Check all connections between the motor and the controller.
3 flashes The motor has a short circuit to a battery connection.
4 flashes Freewheel is engaged.
5 flashes Not used.
6 flashes The controller is being inhibited from driving; this may be because the battery charger is connected.
7 flashes A throttle fault is indicated. Make sure that the throttle is in the rest position before switching on the scooter
8 flashes A controller fault is indicated. Make sure the controller connections are secure.
9 flashes The parking brakes have a bad connection. Check the parking brake and motor connections. Make sure the controller connections are secure.
The-Active-Light
does not function,
the Battery/
Status indicator
flashes rapidly.
Count the number
of flashes:
10 flashes
An excessive voltage has been applied
to the controller. This is usually caused
by a poor battery connection. Check the
battery packs and controller
connections.
Sorry wasn't sure how much space they give you for answers. :)
Oct 11, 2013 | Health & Beauty
Pride mobility scooter celebrity x flashing 5 times not working
Hi remove key put freewheel lever into drive & replace key .turn on...,... good luck.,
Nov 04, 2012 | Pride Celebrity X 3-Wheel Electric Scooter...
DRIVEMEDICAL PHOENIX 3 WHEEL Just bought it and charged it for 10hours. When I put battery into scooter, all the battery lights come on- 2red 1yellow 2green.....so is it charged? are the connections loose?...
Wez Thats a normal indication of a full charge. The battery level indicator will go down as you use the scooter. Always charge the scooter overnite if you use it a good bit during the day. With new batteries it will take 8-10 charging to break them in and operating at 100%. Always store fully charged and if not used alot charge once a week after you have charged the batteries 8-10 times
Hope this helps
Oct 27, 2010 | Drive Medical Phoenix 3 Wheel Compact...
Need manual for craftmatic scooter
Hi. How many flashes between the pauses? Let me know and I can tell you what is wrong with it. Neil.
Jul 09, 2010 | Health & Beauty
Which indicator light on my mobil line battery charge complete
the green light should remain on when fully charged.
Regards
GeWiz.
Jan 11, 2009 | RTO Mobil Line Mobility Scooter Chair...
Health & Beauty Logo
229 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
