Question about LG 42LC2D 42 in. LCD HDTV
My Panasonic TX37LZD80 Television turns itself off at exactly 6.40pm and 9.00pm every night??? I then press the tv button and it comes back on again. other than that the tv works perfectly? can anyone tell me why this is happening and how to rectify it please??? any advice would be very gratefully received.
    Sergeant:
  • 181 Answers
Hello. It sounds like the tv was set in turning off mode at those times you said. The best thing to do is read the tv's owners manuale first. Then care fully go though the settings just like you did when you bought it brand new. Good Luck.
Posted on May 16, 2014
rlamkin
  • 44 Answers
SOURCE: My LG-37" Flat-Panel LCD HDTV-37LC7D turns on automatically
The main board needs to be replaced.
Posted on Jul 03, 2008
  • 8457 Answers
SOURCE: Television goes blank without warning for undetermined time
Power supply board have problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Mar 03, 2010
SOURCE: my lg dgital television has started turning itself
I had exactly the same problem with mine. I re-routed the power and ariel lead so that they were not running both together and it stopped the problem ! it's been fine since i did it 4 months now and counting. No more scary episodes of TV suddenly blaring out at 03:00 am :-)
Posted on May 16, 2010
  • 608 Answers
SOURCE: Hi, my LG 37LG60 TV has an annoying problem where
had a very similar situation with my Phillips 42 in. LCD TV.
Here was my Problem. The Power Supply Board. I opened it up( Warranty was Expired) and found several faulty capacitors on the PSB. Its pretty common. Major Electronic companies were sold faulty capacitors that fail in 2-5 years instead of 10-20 due to a lack of preservatives. It wouldn't surprise me if you have the same problem. TV will work fine for a few years and then just fail completely or slowly deteriorate.
Here are the solutions
1. Have it Repaired
2. Check for faulty caps and if you find some(budged or leaking) you know you have located a problem
Remove the board and replace the whole thing.
3. If you have some soldering skills you can replace the faulty caps.
Caps are very inexpensive, under a dollar in most cases. I replaced 4 for about $5.00
Hope this Helps.
Good Luck
Posted on Dec 10, 2010
windowvistab
  • 139 Answers
SOURCE: LG 42pc5d plasma television.
It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this IC is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
Hope this will help in solving the problem.......
Posted on Jul 08, 2011
How do I get to my HDMI channel?
It isn't a 'channel' it is a connection port. Once a cable box or DVD / blue Ray player is plugged into it, you choose the port using the Input button on your remote and scroll through them.
That set has 2 HDMI connectors on the back panel, right side, more or less by themselves, to the lower left of the antenna jack.
See the link. In the cluster of 3 photos, click the center one, then zoom it. Source(s): http://www.crutchfield.com/S-QWOJIeQP36Y... kg7or · 4 years ago
All the info on the television including manuals and inputs can be found here,
ftp://ftp.panasonic.com/television/howto/combo_connections_howto.html
58 Class 58 0 Diagonal 1080p Plasma HDTV with Anti Reflection
Jan 01, 2016 | Panasonic Televison & Video
I have switched the TV off at the switch. When I have turned it on again the picture doesnt appear and the red light just keeps flashing.
First you need to try turn it on using the remote, by pressing any of the number buttons on the remote. If it does the same, then you go ahead to press the power button from the television to see if it comes on.
If either of them does not turn on the television, then you will have to reset the television. To do so, unplug the television for some minutes, lets say about 5 minutes, then you plug it back on, then press and hold the power button for about 15-30 seconds and it will restart the television.
That should help start up the television.
Hope this helped.
Goodluck
Elect_Comp
Jun 27, 2011 | Panasonic Televison & Video
Last night the set just turned off by itself. When I try to power on, the power light comes on for a second and then it shuts itself off again.
I am having this exact problem. The TV turned off by itself and now when I try to turn it on, the power light stays on for a sec and goes of with a click sound.
Any TV experts who can HELP?
Apr 20, 2010 | Mitsubishi WT-46807 46" Rear Projection...
Tv wont turn on
how was the pix on your tv befor it shout off if it look like a 3d piix you have bad con.v ic to see f you do open it up and look for two big ic or stk. and look for the power suppy line and unplug it now tv should come if it do come on you have bad con.v stk 392-120or 110
Dec 07, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Ilo 26hd lcd tv
I unplugged mine over night and plugged it back in this morning but it still will not turn on. It is still in standby mode
Dec 17, 2007 | iLO 2600 Television
Diagnostic Mode?
Press and hold power & action button on front of tv hold untill tv turns off release - Set will come back on with other menu just press channel up . this should clear setup mode.
Nov 18, 2007 | Panasonic PT-51HX40 51" Rear Projection...
Help please
called h.v. shut down call tv repair shop
Sep 18, 2007 | Panasonic PT-47WX49 47" Rear Projection...
LG 42LC2D 42 in. LCD HDTV Logo
23 people viewed this question
Computer Repairing
Computer Repairing
