Question about NetGear N600 Wireless Dual Band Router
Why are the orange and blue lights my wireless N Dish/Netgear duelband blinking
Blinking only started since the technition changed my dsl line to a fiber optics line
  • NetGear Master
  • 2,219 Answers
Orange light means no internet connection.
Check the cable and settings.
Posted on Mar 08, 2015
SOURCE: Wireless LED blinking, normal?
i'm having the same probs but, to answer your concern over the blue lights,her'es the deal.
your router has 7 antennas inside and each of the led's represents an antenna. as the router scans for something to connect to the led's will blink. it will eventually lock on to a signal from a wireless laptop or usb reciever and the 2 strongest signals will be used for transmitting/recieving data, shown by 2 solid led's.
Posted on Mar 13, 2008
Silverblade
  • 173 Answers
SOURCE: netgear router
First I need to know the following infor to provide you some solution to your router problem;
Internet Service Provider:
Modem Brand Name:
Laptop Model Numbe:
Laptop OS:
Posted on Aug 09, 2008
bob_computer
  • 3153 Answers
SOURCE: Netgear Wireless light not working
This sounds like a common conflict fault.
There are a few things you can do to help reliability
You should first make sure that the modem and router are individually
set up correctly.
Read the guide for router and modem first and if any of it may apply to you then try and do it.
Try the following procedure and write down anything you change so that if you need to go back you know what was changed.
Connect ONLY the MODEM to a pc by wire and nothing else
Go to the start menu and select RUN
In the box type "cmd"
Now in the black screen that has come up type "ipconfig /all"
Take note of the numbers that are in 4 groups e.g. 192.168.1.1
Also take note of the name in front of those numbers !
Write down any numbers where it says DNS too as they may be useful (you only need the ones with numbers not the ones with letters)
Now do the same thing with your modem
If that too has the same IP as your router in "default gateway" then you need to fix that issue as that is probably a part of your problems.
The fix for router modem conflict is to set the router to use a different IP range.
To do this only have the router connected (by wire) and open an internet explorer page (it will fail but that's ok)
In the address bar type the number you got for default gateway above for the router e.g. 192.168.1.1 and press ENTER
When it asks for the user name, give it the one you gave it when you set the router up or the default one from your manual
Also give it the password you gave it when you set it up or once again the default one from the manual.
You now need to look for a box that has the number you just used to get into the router.
It may just say IP address or Starting IP or something similar
That is the number you should change. I usually change the third block e.g. 192.168.2.1 as opposed to 192.168.1.1
You should also have some DNS numbers from the checks further up with the MODEM
You should find the DNS boxes and place those numbers in there. This will allow your computer quicker access to finding things on the internet
Now look for the save settings button and do so.
Reconnect the modem and router. The cable from the modem should go to the YELLOW socket on the router.
Power up the modem and WAIT until all the correct lights are on.
Then do the same with the router.
Now power up a pc and check that you can surf without problems
If not then the problem may lay elsewhere. Go back and re-check.
That should help you out
Posted on Sep 07, 2009
  • 1738 Answers
SOURCE: router is blinking orange
There should be a reset button on the back on the router. Press and hold down on it, for about minute or so.
Posted on Dec 21, 2009
  • 16 Answers
SOURCE: My power light on my Netgear WGR614 wireless
Maybe you had a power surge.
The reset button does nothing with the router powered off, basically you hold the reset button in for 30 seconds with the router powered on. Following this you will need to set up the router again as all settings will be reset to factory defaults, from the sounds of it though the router may be dead.
Another reset method is as follows;
1. With the router powered off hold in the reset button,
2. Keep the reset button in, power on the router, wait 30 seconds,
3. Keep the reset button in, power off the router, wait 30 second,
4. Release the reset button.
Did you have wireless disabled?
If you have access to a multimeter check the PSU is working correctly.
Posted on Feb 04, 2010
Why doesn't my neotv netgear remote no longer communicating with box?
What do the different Remote control front LED lights mean?
  • Blink blue color twice per second: Remote control has paired NeoTV PRIME and is trying to connect NeoTV PRIME.
  • Blink blue color once per second: Remote control is trying to pair the NeoTV PRIME.
  • Orange blinking: Remote control battery is low. Please replace a new set of AAA battery.
go to page 15 of the following document:
http://www.netgear.com/landing/stream/img/gtv-specs/GTV100_IG_25Oct2012.pdf
Sep 09, 2014 | Computers & Internet
I have a netgear wnr3000 router and all of a sudden my internet stopped working now there is an orange blinking light
The orange blinking light tells you, you have not got an internet connection. Check the settings on the router.
Jun 22, 2014 | NetGear WGR614 Wireless Router
Why are the orange and blue lights my Dish/Netgear duelband blinking
May 16, 2014 | NetGear N600 Wireless Dual Band Router
Netgear wndr3300 blinking orange light
It depends. Have you checked the Netgear support site for FAQ and the manual. In some routers, orange lights indicate wired 100Mbps connections while green indicates 1000Mbps. In other cases, blinking lights indicated that the router is 'bricked'.
Sep 09, 2012 | NetGear WNDR3300-100UKS Wireless Router
How to troubleshooting DSL conection
Hi.
look at your dsl L.E.D
if the lights blinking, meaning there is a problem on the DSL line and you need to contact the service line provider to solve your DSL line.
(Good
DSL line if the DSL L.E.D light is not blinking led (stable)
regards
Aug 04, 2011 | D-Link DSL-G604T Wireless Router
Have 2 computers connected to Netgear WGT624NA router via ethernet connectors and have operated well for over a year. Now have gotten DSL and have run phone line to modem and via ethernet cable have...
Have you tried to reset router. It has to be done in order.
1. unplug router
2. unplug modem
3. shut down computer and restart after waiting 1 min
4. after restarting computer plug power back into modem and wait for all the lights to start blinking
5. after the modem is working plug power back to router and plug in the computer with ethernet cable and make sure you have internet,
6. try to link up with wireless,
If this does not work you will have to setup the router for wireless if it is att wireless you will have to call them to give you the password to set it up.
Jan 10, 2011 | NetGear WGT624 Wireless Router
Router is blinking orange
Dec 21, 2009 | NetGear WGR614 Wireless Router
Belkin Wireless G Plus MIMO router - connectivity problem
Connect one computer directly to the DSL modem using an Ethernet cable. If your DSL service includes a static IP address, then you will need to change the TCP/IP settings on your computer to connect directly to the DSL modem. that the router or other device on your network . For these you need to follow thse steps.
Belkin router blinking orange FIX belkin router amber light Issue
This may help you.
Aug 10, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Blinking orange light
if you got an orange light to the router, It means that there's no Internet connection or not working from the router. I might advice you to check the Internet connection from your ISP, then check the configuration of your router or you might needing to reconfigure the router.
Mar 10, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
NetGear N600 Wireless Dual Band Router Logo
78 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
