What color is the charging light on a nv53a laptopsupposed to be
    Sergeant:
  • 181 Answers
Hello. The charging light should be a green-yellow color. Good Luck.
Posted on May 16, 2014
Gateway ethernet controller driver
Use a USB flash drive on the computer you can access the internet on and save the driver files onto it. Then transfer them to your Gateway NV53A laptop.
How to Save Files to USB Flash Drive
Jun 28, 2014 | Computers & Internet
  1. Plug a USB key into a computer you can access the internet with
  2. Get updated drivers from manufacturers site
  3. When prompted to save download choose the USB drive letter which you should see in My Computer/Computer on your 'desktop' screen.
  4. Save file(s) and them remove the USB key when safe to do so.
  5. Insert USB key into your Gateway NV53A and either run driver installer directly from USB key or copy files onto your Gateway.
How to Save Files Using Thumb Drive eHow
How to change the font on mu laptop
Type Change Window Colors and Metrics into your start menu, when the widow comes up your going to want to select icon (or any other type you want) as the item type. In order to adjust the font change the value selected, you may also want to adjust to font size to match. Make sure you hit Apply, you may have to do this a number of times in order to get the fonts the way you want. This will affect the fonts in your OS (Windows), things like icons, right-click menus, Start Menu.... However if you want to change the size inside of other programs you will need to get inside of their individual settings.
Hope this helps.
Sep 29, 2013 | Gateway mb.bl002.001 - Nv53a Amd Laptop...
My dreamgear chargepack works but when I but my sliver remote control in it lights up which means that its charging but when I try to charge my blue control the lights wont turn on. how do I make the light...
I have several controlers in several different colors, but "coincidently" several of the blue colored controls have had the LED lights stop working completely. I am begining to think that many blue colored Sixaxis PS3 controlers were made during a version that had problems with the LED lights going out and no longer working, or simply a bad batch of controlers.
Did you try letting it charge for a while, even if the ligfhts won't light up, then press and hold the PS3 button to check and see if it took the charge?
On my blue controlers, they still charge and still work, but none of the LED lights illuminate anymore.
Solution would be to buy a new controler, or ignore the lights not working.
Sep 20, 2013 | Video Game Consoles & Games
I have a Gateway NV53A laptop. I love my laptop however there have some problems lately and now it would even charge. The first issue was there would be some sort of a straching noise as if something was...
The charging problem could be a faulty charging circuit in the laptop or the laptop battery is worn out. Rechargeable have a finite number of charge cycles.
The beeping noise is a power on self Test error message and the number of beeps indicates the error code.
You need to take your laptop to a computer repair shop the assess the laptop's fault and when you get the quote then decide to get it repaired or put your money towards a new laptop.
If you decide to get a new laptop you can salvage the hard disk from your old laptop and insert the hard drive into an USB hard drive case and use it as an external USB hard drive for data backups and file transfers.
May 16, 2013 | Computers & Internet
The VGA Port on my Gateway NV53A laptop has come loose. It can still be made to work if I position the vga plug upward at precisely the right angle, but that involves keeping the laptop held still, ot
There should be 2 small nuts holding the connector in place these are also used to secure the external monitor VGA connector to the computer. You can get them from a computer shop.
Apr 12, 2013 | Gateway Nv53a
Delete hardrive on a gateway nv53a
To delete a harddrive you would go into BIOS Setup, and remove.
(Main menu, or Standard BIOS options (setup)
Was there a previous harddrive, you installed a new one, and the old is still showing up, or what is going on?
http://support.gateway.com/s/notebook/2010/gateway/nv/nv53A/NV53Asp2.shtml
My intel indicates press F2 to enter BIOS Setup.
The best method I've found is;
AS SOON AS you press the Power On button, start tapping on the F2 key.
You may hear beeps as you do.
Those are Stuck key Error Code beeps, and it is you that is doing it.
Ignore them.
If you do not know how to navigate in BIOS Setup, or save changes; post back in a Comment.
Totally way off? Post back in a Comment.
Regards,
joecoolvette
Feb 22, 2013 | Acer Gateway NV53A36u
It isn't charging
For this kind of issue, please follow up the following steps to check:
confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:http://www.ifitjams.com/lappower.htm
Oct 28, 2012 | Gateway NV53A NV55C NV59C NV73A Acer...
I need to R&R the keyboard. How do I remove the cover safely? Thankyou Bernice
It is virtually impossible to fix because you cannot get to the rubber contacts in the keyboard. The best solution is to replace the keyboard.
You maybe able to get a replacement keyboard from this WEB site.
Keyboard replacement, LCD screens for mobile phones, Ipodsand computer equipment.http://www.yallstore.com/index.php?main_page=advanced_search_result&search_in_description=1&zenid=1lrjst3ncshlb4c7frn9bev3c3&keyword=keyboards
Jul 24, 2012 | Computers & Internet
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
