Question about 1996 Lexus ES300 Spark Plug Wire Denso
Why my scanner does not turn ok and give me the following message? "No execution program loaded"
  • 23 Answers
There is a bad fuse. Or the pwr wire. Going to the plug isn't given. Any power that why scan tool can not communicate too. Your scan tool is out of date or loose wire from scanner to end of plugging
Posted on Sep 01, 2014
Reset memory for ricoh sp5100
Not exist memory reset,only Memory Clear.Before execute Memory clear print out all SMC data list.
Enter in SP mode : press Clear(yellow key) press 107 press and keep hold more 3 seconds Stop/Clear(red) key select SP mode select SP 5801 or select using the arrows up/down SP memory clear.Press the OK and execute,when the program has ended normally,the message COMPLETED is displayed.If the program has ended abnormally an error message is displayed.Turn the main switch OFF and ON.Adjust the printer and scanner registration and magnification.Refer to the SMC lists and enter any values that differ from factory settings.Adjust the standard white level,initialize the TD sensor.It is a work from 4-5 hours,good luck.
Feb 08, 2013 | Ricoh Office Equipment & Supplies
Tip
How to change Data Execution Prevention (DEP) settings in Windows 7? Data...
How to change<b> Data Execution Prevention (DEP)</b> settings in <b>Windows 7</b>? <br /> <b>Data Execution Prevention (DEP)</b> is a feature that protects our system from viruses and other security threats. The Windows constantly monitors the programs running on our system and closes them if they perform any malicious activity. But sometimes we want a certain program(s) to run even if the<b> Windows alerts</b> us that it is a malicious one. <br /> To change <b>Data Execution Prevention </b>settings in <b>Windows 7</b> follow these simple steps: <br /> 1) Right click on the <b>My Compute</b>r icon on your<b> Desktop </b>and select <b>Properties</b>. <br /> <img src="nonontech_54.jpg" /><br /> <br /> <b>Fig. 1</b> <br /> <br /> 2) The <b>System window</b> opens now. Here click the <b>Advanced system settings</b> link in the left pane as highlighted below: <br /> <img src="nonontech_55.jpg" /><br /> <br /> <b>Fig. 2</b> <br /> 3) The <b>System Properties</b> window opens now. Here click the <b>Settings</b>... button under <b>Performance</b> section under <b>Advanced</b> tab <br /> <img src="nonontech_56.jpg" /><br /> <b><br /></b> <b>Fig. 3</b> <br /> <br /> 4) The <b>Performance Options</b> dialog box opens now. Here select <b>Data Execution Prevention</b> tab and then click on the radio button <b>Turn on DEP for all programs and services except those I select option</b> and click<b> Add </b>button <br /> <img src="nonontech_57.jpg" /><br /> <br /> <b>Fig. 4</b> <br /> <br /> 5) Now select the<b> Executable</b> file (i.e. the .exe file of the program you want to add) that you want to add and click <b>Open</b> button <br /> <img src="nonontech_58.jpg" /><br /> <br /> <b>Fig. 5</b> <br /> <br /> <b><u>Note:</u></b> If you try to add an executable file which cannot be turned off it's <b>DEP</b> feature, then you will receive a warning as shown below. <br /> <img src="nonontech_59.jpg" /><br /> <br /> <br /> <b>Fig. 6</b> <br /> <br /> 6) In the same way, to remove an executable file from the list select that file and click <b>Remove</b> button. <br /> 7) Click<b> Apply</b> and then <b>OK</b> button in the <b>Performance</b> options window <br /> 8) Click <b>OK </b>button in <b>System Properties</b> window <br /> 9) Close <b>System window</b>. <br /> Thanks for reading. <br />
on Jan 28, 2011 | Computers & Internet
Data execution prevention as I am getting this messaGE WHENEVER i GO TO OTHER WEBLINK AND iNTERNET eXPLORER SHUTS OF SO i NEED YOUR HELP
There is two area's that DEP is held One in the perfomance section and the other in IE Firstly we'll fix IE DEP 1. Open up IE and quickly select Tools 2. Select the advanced tab 3. Uncheck the Enable memory protection 4. Restart IE to apply. 1. Start\Control Panel\System and Maintenance\Performance Information and Tools\Adjust visual effect 2. Select the Data execution prevention tab 3. Check the Enable DEP for Essential windows programs and services 4. Restart the computer to apply.Disable DEP using CMD A) In the command prompt, type bcdedit.exe set {current} nx AlwaysOff and press Enter.B You should get a success message back C Close the command prompt. D Restart the computer to apply. Enable DEP using CMD A In the command prompt, type bcdedit.exe /set {current} nx OptIn and press Enter. B You should get a success message back C Close the command prompt. D Restart the computer to apply.
If a program is being closed by DEP, then make sure that it is a DEP compatible version and check for an updated version. If it is not DEP compatible, then you can uninstall the program or turn off DEP for that particular program.Follow the steps below to to close Data execution prevention a. Click on start. b.Right click on Computer and click Properties.c. Click on Advanced system settings.in upper left green area d.Click on the Continue button in the UAC prompt.e Click on the Settings button under Performance section.f Click on the Data Execution Prevention tab. g. Turn DEP On for Essential Windows Vista Programs and Services Only.NOTE: This turns on DEP for only the 32 bit system programs and services. This is the default setting. h.Click on Turn on DEP for essential Windows programs and services only.click on OK to apply. j.Turn DEP On for All Programs and Services Except for the Ones you Select.NOTE: This turns on DEP for every 32 bit program except for the ones that you add to the list. The listed program will have DEP turned off for it.Turn on DEP for all programs and services except those I select. Click Add to add the programs that you do not want to use the DEP feature. m. Navigate to the program's .exe file that you want to add to the DEP exclusion list and select it, then click on Open. n.Click on OK to apply. b. Restart the computer to apply changes.
Oct 24, 2011 | HP Pavilion DV6000T 15.4­ NOTEBOOK LAPTOP...
<RUN PROGRAM> No program!
ncarovic: This is not an error, this message indicate that not exist any program to run. You must load a program to execute it. You can make your program using JobGenerator, or i can help you to develope it. Roberto Martinez padrino99@prodigy.net.mx
Jun 21, 2011 | Unitech HT630 BATCH Barcode Scanner
I TURN MY SCANNER ON AND WHAT POPS UP IS HT630 BIOS V2.03 MEM 4608KB &gt; I JUST WANT IT TO BE ABLE TO SCAN BARCODES WHAT DO I DO?
receiving670: You must load a program to execute it. You can make your program using JobGenerator, or i can help you to develope it. Roberto Martinez padrino99@prodigy.net.mx
Oct 26, 2010 | Unitech HT630 BATCH Barcode Scanner
I need scanexpress a3 usb windows 7 driver pls
I succeeded into installing and using the Mustek ScanExpress A3 USB!
I downloaded the driver for Windows Vista from the Mustek website, then did the following steps:
1. left mouse click on the web.exe downloaded file and choose Properties;
2. in Properties I checked "Execute this program always as Administrator" and "Execute in compatibility mode for Windows Vista";
3. without any scanner connected I executed web.exe, gave the authorization even if recognized certificate;
4. allowed the system to restart;
5. connected the scanner;
6. directly used it into any program.
Please let me know if these instructions was useful!
Regards and good luck.
Sandro from Italy!
Apr 13, 2010 | Mustek A3 USB Flatbed Scanner
Downloaded all the drives and still can use it as the message:"execute appliation" keeps poping up
You need a scanner application such as Adobe Photoshop or other program.
Cannon has one for your scanner at this link.
http://software.canon-europe.com/products/0010399.asp
May 24, 2009 | Canon CanoScan 4400F Flatbed Scanner
Keep getting error Cannot execute btcc.exe
If your device is registered at Intermec.com you should be able to dowload a firmware flash for the device. Follow the instructions and reflash the device. If this does not work the bluetooth radio could have malfunctioned.
Feb 11, 2009 | Intermec Computers & Internet
Installing error code -106
I suggest go to Start/Settings/Control Panel/Add remove programs.
Check and see if the program is in list and remove it. While in control panel go to system/Device Drivers check non have a yellow mark on them if so reinstall drivers or upgrade Reboot and try again.
Jul 22, 2008 | Computers & Internet
Visioneer 4400 Flatbed Scanner - Compatible with Windows Vista
Thank you ever so much for the above solution. My Visioneer could not work with my VISTA but now after I followed the above procedure I have managed to perform my first scan.
Many thanks
Omar
Dec 10, 2007 | Visioneer 4400 Flatbed Scanner
1996 Lexus ES300 Spark Plug Wire Denso Logo
52 people viewed this question
Top Denso Spark Plug Wire Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Denso Spark Plug Wire Vehicle Part and Accessory Expert? Answer questions, earn points and help others
