Question about Sector 210 Expander Black Dial Chronograph Mens Watch 3253926025
I m looking a blacelet for my sector 210 3253925035A
Manual for my sector
As there is no manual downloads possible for SECTOR watches, the only solution is to contact SECTOR directly. Of course you can browse all the internet, but I'm quite sure direct contact will save you nerves, time and money.
Here is the link:
http://www.watchservicecenter.it/
Apr 22, 2014 | Sector 210 Expander Black Dial Chronograph...
Sector model 31723 broken stem
An independent watch repairman (used to be one at every jewelry store) can probably replace the stem of your watch for far less money, depending the damage you describe. I suspect that the high repair price given to you by Sector means that they would simply drop a brand new movement into your watch and give it back to you. In most cases, though, a replacement stem wholesales for $7-20, and you might be looking at $30-75 in labor, depending on where you live and the type of watch repair shop you're able to find.
When looking for a repair place, I would stay away from the big chain jewelry stores--and also the "while you wait" watch battery shops. Neither of those operations typically has an in-house person with the right expertise to fix your watch.
When all is said and done, it is possible that the nature of the stem break will require more expensive repairs to your watch. A good repairman will tell you if that's the case. Even then, $400 seems very high to fix this problem. In the old days of even 10 years ago, this would be a $25 repair!
Best of luck with your quest.
Dec 02, 2012 | Sector 2653940025 Wrist Watch
Had rubber band fitted, instead of metal band, when new. Rubber watch band is perished and broken. I need a new metal band, Please. The model watch is :- Sector 700 2653700015
ebay is your friend, look there and you should find one.
Please dont forget to vote this answer was helpful.
Many thanks
Mar 04, 2011 | Sector 700 2653700025 Watch
I have a Sector watch ADV 1000 and need the user manual
I was looking for a manual of my ADV2000. Other web site says its movement is Citizen Cal. 3531 and found the PDF document. It looks your ADV1000's arrangement of buttons are the same with mine, guess it may help;
http://www.citizenwatch-global.com/support/simple_pdf/3531.pdf
Jan 12, 2011 | Sector Watches
Where can I get an owner's manual for a Sector 133 Chrono Alarm watch?
Here is the link:
Rate, please.
Jul 22, 2009 | Sector Watches
Instruction manual
Visit this site (paste it into your browser):
http://www.kenmarwatches.com/sector/mountain-master/
Find your exact model and ask a question. There are no direct downloads, but you can talk to an online representative, email them questions or ring directly by the phone. They will be happy to give you all the info you are looking for.
Don't forget to rate, please.
Jan 13, 2009 | Sector 3251908015 Mountain Master watch
Sector mountain
Visiy this site (paste it into your browser):
Jan 12, 2009 | Sector 3251908015 Mountain Master watch
SECTOR 450 TIME ABJUST
when looking at the face of the watch, the "dial" to the bottom-right is actually a screw-in, screw-out dial, it is not a push dial. Unscrew it until it is freed from the screw AND THEN pull it out two clicks, adjust time as needed...
Apr 21, 2008 | Sector 450 2653450035 Wrist Watch
Sector 255 need to contact sector
need help in setting time on sector 550 2653955025.
Nov 16, 2007 | Sector 2653940025 Wrist Watch
Sector 210 Expander Black Dial Chronograph Mens Watch 3253926025 Logo
26 people viewed this question
Top Sector Watches Experts
staicuma
Level 1 Expert
aravind shet
aravind shet
Are you a Sector Watch Expert? Answer questions, earn points and help others
