I accidentally plugged my Whirlpool ACQ158XR1 AC window unit into a 220V outlet, now no power at all. What part most likely fried and can I repair with a new part?
  • helopil8 May 11, 2010
    Most likely fried the transformer that supplies power to the circuit board. Many of these are soldered directly to the board. Therefore, you may need a new circuit board.
  • taa43 May 11, 2010
    That must have been hard to do. cut your losses don't do that again. maybe ya just tripped a breaker? Good Luck Tom
SOURCE: Window unit trips circuit breaker
Contact between plug and outlet is loose and so there is a leakage of current. Recommend to replace the plug to fit the new outlet.If the breaker still tripping call technician to service your unit.
Posted on Mar 31, 2009
louislevel_2
  • 374 Answers
SOURCE: acq158xpo whirlpool window ac power on unit humms
hello there!
well,humming that's the motor stuck up,it can't start up,the running winding of motor has built up current because it can't move on,the start winding is not wotking,check starting capacitor ,using multi tester have set to RX100 test rod on both terminal pointer will deflect to "o"reading,then reverse the test rod on terminal of capacitor this will deflect also to "0" but gradually go back to original position at high value.if this happen your capacitor is good.but if not deflect.defective capacitor,replace defective capacitor,
if capacitor is good,check relay coil,or check motor starting winding resistance,if you get high resistance more than 100 ohms
you motor is defective replace motor,
have a nice day,don't forget to rate me,thank's a lot
Posted on Apr 28, 2009
louislevel_2
  • 374 Answers
SOURCE: power on unit hums but does nothing else just keeps humming?
hi there,
stuck up motor,could be capacitor check this out and replace.
could be relay.if defective replace.the motor has star winding after replacing capacitor and humming again,check start winding,if high resistance,replace motor.have a good day,rate me if your satified to my suggestion,thank's a lot
  • 13 Answers
SOURCE: cannot engage RESET Button on plug to power the 220v AC unit
The reset button is a voltage leak detector it is possible the unit has a short in it or the cord has a short
Posted on May 15, 2009
shastalaker7
  • 1515 Answers
SOURCE: Our son bought a ARC-125 Whyniter Portable Air
Hi Karen, and yes more then likely a lot of the controls were cooked. It doesn't take long with that high of voltage to take out motors, burn the insulation off of wiring and so on. Depending on how long it was plugged in and how long that much voltage had run through it, try plugging it into a 120 volt receptacle and see what happens. I would do this before any thing else. I have seen this happen on other units and just melt the 120 volt power cord. So, plug it in to see what happens, and if it seems to run good, you may have turned it off in time. If nothing happens, and this unit cost you a lot off $$$, it may not hurt to take it in to a appliance repair shop and get an estimate. If you smelled a lot of electrical burning, I would look at where the power cord comes and ties in, that may be as far as it got and check it if you have someone that is able to do this. But, my guess it is probably dead. I am sorry this happened to you. Please don't forget to rate my post as I know you will be kind.
Sincerely,
Shastalaker7
A/C, Heating Contractor
Posted on Sep 24, 2010
Rainbow e2 type 12 120v , accidentally plugged into 220v, would barely power up, possibly controller board defective?
probably need both as the extra 100 volts would burn the board and the motor
it is never advisable to buy electric equipment from another country because of the voltage differences but even then the plugs are made different so that the cord will not plug directly into the power outlet.
Aug 12, 2015 | Rainbow Vacuums
My child plucked my wii game in22ov socket how to repair it?
When your child plugged the unit into 220VAC outlet, it probably shorted out the power supply Either the FUSE or the power supply itself got "fried" Unfortunately.There may be 4 diodes that are called Rectifiers that probably got burned out when unit was plugged in.
Sep 12, 2014 | Video Game Consoles & Games
How do you change the fuse in a window unit?
some uneit have a fuse in the electronic board, i would put a new electric plug first is it 220v or 110v go for the plug first
May 24, 2014 | LG LWHD1800R Wall/Window Air Conditioner
I accidentally plugged in my pulmoneb in a 220v outlet
plugging a 110v device into a 220v outlet is not likely, as the plugs are a different configuration. In the event that you somehow managed to do that, your device is probably fried, as that would be to much voltage. Hate to say it; but you are probably gonna need a new one
Nov 27, 2012 | DeVilbiss PulmoNeb Compressor Nebulizer...
How to use it if we have 220V outlet?
If the AC unit is 110V then you must plug it into a regular 110V outlet. You cannot plug it into the 220V outlet. Either get a bigger 220V unit or use a 12 gauge extension cord to get it to a 110V outlet.
Sep 06, 2011 | Haier Mechanical Air Conditioner HWF05XC7
I have plugged wii in 220 volt recepatacle though it was 110 volt what to do
There are two possible scenario's when you accidentally plug a 110V device in a 220V outlet:
1: The power supply to the device you plug in gets fried. this is your best case scenario. See if you can borrow a Wii power supply from a friend and test your console with this power supply. If this works, you just need a new power supply and all is well.
2. Your Wii gets fried. Worst case scenario: your Wii got fried. If it is still in warranty, see if they will cover this damage under the manufacturer warranty, if not, I am afraid you will either need to pay for repairs or buy a new console.
I hate to be the bearer of bad news, but plugging a 110V device in a 220V outlet generally will fry one thing or the other or even both.
Thanks for using the FixYa forums!
Mar 29, 2009 | Nintendo Video Game Consoles & Games
110V plugged to a 220V outlet
your unit is toast! sorry time to get a new one! repair parts will cost more than a new machine.
Sep 04, 2007 | Emjoi AP98R Epilator
Xbox plugged into a higher volt outlet
If you can obtain a new power supply unit(external, of course), sometimes referred to as a "Brick", that would be your best first test. However, if that doesnt work, then the unit is pretty much cooked. It is not recommended that you disassemble your unit and attempt to repair it yourself, though if its that broken, you dont have much to lose, unless it's under warranty. At that point, you'd be at a loss for parts, as they dont really sell Xbox parts in your local electronics store. So what you're looking at is either a fried brick, or fried internal hardware. Could be a cheap fix in the former, or a new unit in the latter, there. Check Ebay or similar sites to find a replacement external power unit. As with any tech problem, fix the cheap part first :)
Jun 04, 2007 | Microsoft Xbox Console
Heating & Cooling Logo
189 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
