Question about Carrier Heating & Cooling
How to drain water on carrier optima - Carrier Heating & Cooling
    Novelist:
    Champion:
  • 373 Answers
All the window units now days do not drain water out on the ground. the condenser fan is made so that it picks up the water and is sucked through the condenser coil and evaporates it. now if there is a lot of humidity in the air then it makes more water than it can dispose of. if you are getting water in the room than pull the unit and wash it out there is a channel on the right side of the unit if facing going from drain pan to condenser area that will get stopped up and the unit needs to be pulled every year and cleaned
Posted on Jul 01, 2014
I have a 2009 Kia Optima and the air conditioner is leaking water on the floor board on the passenger side
the drain hose has come off of evaporator housing. look for the hose that has come detached and reattach back onto drain nipple of evaporator.
Oct 11, 2014 | 2009 Kia Optima LX
My Carrier split unit model 42KGA007 splashes water through the evaporator
The water drain hole is pluged, you need to restore the water drain circuit.
Aug 25, 2014 | Carrier Heating & Cooling
I want to flush the coolant on a 2003 Kia Optima 2.4 liter Auto with A/C. How much antifreeze should I buy to mix with water? What is the total coolant capacity?
Coolant capacity is 7.7 qts./7.3 liters, for a 2.4 liter 2003 Kia Optima.
You will not be able to get all the coolant out of the engine, unless you do a thorough engine drain and flush. If you only plan on draining the radiator, you will need less than 2 gallons mixed total to refill it, since some coolant will remain in the engine block and heater core.
Sep 14, 2011 | 2003 Kia Optima
How to stop a leak
the water leak is not a big concern -other than the mess it causes, but as to the AC's operational status it is supposed to draw water/humidity from the 'cooling space' so - it's still doing it's job (I'm assuming it's cooling too).
As to the water - I would check the drain to be sure it's not clogged up - which is usually the problem. If the drain is clear and the AC is draining (to the outside) properly - I would then check and make sure the AC is tilted backwards out the window.
good luck!
Jul 13, 2010 | Carrier BCA101R Air Conditioner
Need to adj head light
There are 2 adjusters for each headlight 1 left-right and 1 up-down. Raise the hood and look behind the headlight carrier for 2 long hex screws. 1 at the top of the carrier, and 1 at the center side of the carrier.
Mar 07, 2010 | 2007 Kia Optima
Excessive water usage with Carrier LBP humidifier.
hi the water runs down the pad the fan blows air across is , this controled by the stat which should control the water flow / on or off, this should be under warranty in the first year
Mar 01, 2010 | Carrier LBP Humidifier
Optima G2430 Miele dishwasher with intake/drain flashing light
F13 is an inlet fault.
First the unit drains and then fills with water. When the unit has intially drained open the door and manually fill the unit with water, about 5lts. This will then allow the dishwasher to go to the next step which is to circulate the water. If this works ok then the water tap is defective, water inlet valve is defective or the electronic unit is not sending the signal to activate the valve. The water inlet valve is the white square box attached to the tap. Remove this and check the filter and make sure water comes out of the tap.If ok then remove the bottom panel of the unit under the door. On the right hand side there is a 2 core cable with a male and female connector. Unplug this and check for voltage from the electronic when the unit goes to fill with water. If there is 240v then the electronic is ok. You will then need a new waterproof system from Miele.
Feb 27, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
My 2004 Kia Optima got stuck in a flood and now it will not start. What can I do?
all the electrical has to be checked. starting with the computer.must remove spark plugs turn engine over to make sure there is no water in combustion chamber, drain the oil and replace with new. attempt to start engine,if not stating after new computer scan tool will coach you frurther.
Jan 19, 2010 | 2006 Kia Optima
Water is draining out of a little hole beside drain
drain line is blocked water is accumulating and over flowing clean line out
Aug 22, 2009 | Carrier Heating & Cooling
Heating & Cooling Logo
425 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
