Question about Matsunichi Marquis MP977 9.7" 4 GB Wi-Fi Black Tablet Android 4.0, LCD Touchscreen, 1024x768
Can't get Matsunichi Marquis MP977 to turn on
Saw where the cord was fraying a little where it plugs in to the tablet, so I thought maybe is was not getting a "complete" connection. I ordered a replacement cord for a Marquis MP977, just realizing a few minutes ago it was NOT the same machine when I went to their website to look at the FAQ and they had posted above the FAQ a statement saying they did not support the Matsunichi Marquis MP977, that's when I knew I had probably ordered the wrong cord. Can someone please tell me where I can get the correct cord for this machine.
My lepan tablet wont charge
I have seen these problems on such devices... It almost always is that the battery. Check the voltage going to the battery and the voltage in the battery itself.
Feb 10, 2015 | Matsunichi Marquis Mp977 Marquispad 9.7"...
I purchased the Matsunichi M97 in July and now it will not turn on. I purchased it at Walmart but they only warranty it for 30 days, what can I do?
WAS IT DROPPED? HAS IT BEEN WET? OBVIOUSLY THERE IS AN INTERNAL PROBLEM....IS IT CHARGED? YOU DONT SAY IF THE SCREEN LIGHTS UP FOR ANY AMOUNT OF TIME.... COULD BE THE ON/OFF SWITCH.... MAYBE AN OPEN CIRCUIT.
Oct 13, 2014 | Tablets & eReaders
How to open my Matsunichi tabelt because it does not turn on
Hello, The only can you can do is replace the charger and cord to see if it is really charging or not. You might take out the battery and put back in and see if it comes up then. If not you will have to get ahold of cust support for the tablet and go thru their trouble shooting and possibility send back to them or take to a local computer repair shop.
Jun 15, 2014 | Tablets & eReaders
I have a marquis mp977 tablet i was playing a game on it and it abruptly shutdow and wont come back on it wont respond to being plugged in or anything i am unsure if theres a reset button
To perform a hard reset you will need to locate the reset button. The reset button is a small, circular hole next to the charging port on the tablet, beneath the flap. You will need a paperclip, pin or something similar to press it. Press and hold for about three seconds, then release. The tablet should boot normally
Mar 21, 2014 | Tablets & eReaders
Power Problem
I have the matsunichi 9.7 my email has amessage saying connection problem no emails has come in for 2 days. What can i do to fix the problem
Mar 05, 2014 | Matsunichi Marquis Mp977 Marquispad 9.7"...
Matsunichi m97 tablet
my device wont turn on I tried holding the power button while holding the reset button I get 2 vibrations
Jul 22, 2013 | Tablets & eReaders
Nook tablet will not turn on
Yes, press and hold the power button, for up to 30 seconds, or until the "N" logo appears on the screen.
If it does not, suggestions are that the battery is dead or not charging because the power cord itself is broken or frayed inside the cable and you will need to replace with either a B&N cable or a Micro USB cable.
It could also be the wall charger unit is no longer functioning, and this must be replaced.
I have so far replaced one wall charger and three USB cables, so this is a unnecessary common event with Nook
May 03, 2013 | Barnes & Noble Nook Tablet
Matsunichi Marquis MP977 9.7" 4 GB Wi-Fi Black Tablet Android 4.0, LCD Touchscreen, 1024x768 Logo
54 people viewed this question
Top Matsunichi Tablets & eReaders Experts
Are you a Matsunichi Tablet and eReader Expert? Answer questions, earn points and help others
