Question about Canon PIXMA Pro9000 Printer
Installed new print head, all inks are ok but still wont print
    President:
  • 2,306 Answers
Usually when that happens on the Pro 9000, the purge assembly is not cleaning and priming the printhead properly. A new purge assembly runs around $29.95. Part number
QM2-2973-000.
Posted on Jun 23, 2009
    Problem Solver:
  • 6 Answers
I have an i9900 which stopped printing certain colors one day. After putting in a brand new head, it still would not print. You have to disassemble it right down to the chassis to see it but there are two skinny plastic hoses which prime the print head. One had popped off. It is a messy job. Easy to fix, once you have taken the whole printer off it's chassis. That is the tedious part. I have had to put those little hoses on 3 times so far and probably will again. Probably easier than replacing the pump.
Posted on Sep 12, 2012
SOURCE: MP 360 won't print
the Cartridges is Jammed on my MP360 ImageGlass all - in one Printer
Please advise me how to fix it
Thanks
Yatiha Balfour
Posted on Feb 25, 2008
Ajkill
  • 2035 Answers
SOURCE: It prints ok, but paper is blank (no ink at all)
1. Remove the protective tape from the cartridges:
1. With the printer power on, open the front cover of the printer. The cartridge carrier should move to the middle.
2. Remove the cartridge(s) from the printer.
3. Look on the underside of the cartridge(s). If there is yellow tape and/or transparent blue tape there, remove it.
2. Clean the cartridge nozzles:
1. Go to the Lexmark Control Program or Solution Center and run the Clean print nozzle test.
If a black cartridge is installed, you should see black lines only.
If the color cartridge is installed, you should see yellow, magenta (a reddish purple), and cyan (a dark sky blue) lines.
If a photo cartridge is installed, you may see different colors.
2. Examine the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right, with no gaps.
If there are gaps in the lines, you could run the Clean Print Nozzle page a few more times to try and clear it up or try the "wicking" procedure below to conserve ink.
If the page is faded from left to right and the wicking procedure doesn't clear it up, your cartridge is probably out of ink.
3. Clean ("wick") the cartridges:
1. Remove your cartridges following the instructions in your User's Guide.
2. Take a warm, damp paper towel and fold it so that it has about 4- to 6-ply thickness.
3. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are touching the towel, and hold the cartridge in this position for about 15 seconds. The nozzles are where the ink comes out of the cartridge.
4. Now drag the cartridge lightly across the paper towel in one direction only (left to right) until the bottom of the cartridge looks clean.
5. Turn the cartridge over so that you can see the bar code sticker on the back. Note: Only perform steps 6 and 7 if the contacts look dirty or corroded.
6. Using a clean pencil eraser, clean the contact points on the copper strip (only the little squares just below the bar code). Caution! Do not use the eraser on the nozzles that were cleaned, as this will damage the cartridge.
7. Using a clean part of your dry paper towel, wipe the eraser dust off the contacts; ensure that they are dry, and snap the cartridge back into the printer.
8. Make sure to install the cartridges following the instructions in your User's Guide, selecting Old Cartridge. Failure to do so could reset your ink levels as explained above.
9. Repeat the nozzle cleaning procedure one more time. At this point the diagonal lines should be solid.
10. If they are not and you think the cartridges should have ink in them, contact our technicians by e-mail and let them know the results of this test.
4. Reset the ink levels:
Lexmark printer cartridges do not have ink sensors. The levels of ink are produced by a mathematical calculation of ink drops and page counts. The printer stores this information and then writes it to the win.ini file on your computer.
Ink levels can be reset by telling the printer you have installed a new ink cartridge or by reinstalling the printer drivers and selecting Cartridges Installed. Once ink levels have been reset, there is no way to change them except by printing.
Accordingly, even if your computer says that your ink is full for a particular cartridge, it may be incorrect and the cartridge may need to be replaced. You may want to try a new cartridge to see if that clears up any print quality problems.
Posted on Mar 24, 2008
vegakitten20
  • 685 Answers
SOURCE: installed new ink & it says "Print head is not installed" -
try to unplug it and plug it back in
Posted on Mar 04, 2009
  • 28 Answers
SOURCE: Installed new OEM Epson ink cartridges, get error message 2. Cartridges are installed correctly and tested ok. Chip problem? Print head problem? Cartridge problem?
Go to printers and faxes, and uninstall the printer.
reboot, this should solve the problem
Posted on Apr 14, 2009
pineworks
  • 4041 Answers
SOURCE: Black ink won't print on MFC-885CW printer after
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Mar 09, 2010
My epson black ink wont print??
Blocked print head nozzles
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
Oct 10, 2012 | Epson Stylus Sx235w Inkjet Copy Print Scan...
My epson sx215 wont use my new black ink
Help me please my Epson Stylus SX215 black ink won`t print. I cleaned the head 3-5 times and the nozzle but it still wont`t print black , it is brand new.Is it because the printer didn`t work maybe 2 months. Yesterday i bought all inks and the other are working , the black no :[ please help
Aug 04, 2012 | Epson Stylus Multifunction Inkjet Printer/...
I installed a new black ink cartridge(lc61bk) on a brother mfc-495cw and now nothing is printing.
Check out if you've installed it correctly. Also check out other ink cartridges, are they empty? If yes you won't be able to print anything. However, if all ink cartridges are OK then try to reset the printer or reinstall the drivers. You can find help in MFC 495cw users manual
Feb 27, 2011 | Brother MFC 490cw Color Inkjet...
My printer has new black ink cartridge two days ago but wont print black, how can i clean the heads please it prints colour ok thank you
you will need to use the software included for flushing out some ink and get the clogged out. I'm sure its somewhere on the program you installed with your printer. ;-)
Jun 19, 2010 | Brother MFC-5840CN All-In-One InkJet...
Wont print black ink all outher colors ok cleand
If you did put in a new printhead, it means you need a new purge, or cleaning assembly. If it doesn't clean and prime the printhead properly, it won't print.
Dec 04, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Wont print it prints but no print comes out ink is ok
1st try to clean heads (printer cleaning function)
2nd see if any fresh ink droped on ink basket (inside right/left position.(normaly wrong ink density as non original ink cartriges, have 2 situations: ink too light as low quality ink, drops to much ink on ink basket, and flod and detiorate all metalics parts inside.
Or too heavy, and no ink will pass on print head holes).
3rd u can have the print heads, burnout (u can test on diagnostics tools on printers software), or send for repair, for local repair shop.
Nov 28, 2009 | Office Equipment & Supplies
Black ink cartridge wont print, have installed a new ink refill still no joy. Will print in all other colours.
Well if you already installed a new black ink cartridge and still wont print, then try cleaning your printer head. It can be that the some ink was hardened and got stuck preventing you to print a black color.
Jul 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
Printer wont print black.already replaced with new ink but still wont print black
did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
CANON S9000 won't print in black
Here's what just fixed mine... I was having the same issue...
Mac:
Go to System Preferences
Open Print & Fax
Select your printer and open Print Queue
Click Utility
Select your printer & click Maintenance
Select the "Deep Cleaning"
That worked for my black ink!
Aug 09, 2008 | Office Equipment & Supplies
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Canon PIXMA Pro9000 Printer Logo
530 people viewed this question
old marine
old marine
