Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Manual for Hoover SteamVac F5887-920 - Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
reddevil6
  • 1673 Answers
SOURCE: I need a manual for my Hoover F5857-900 steamvac.
I tried hoover.com, none came up for this model.
We're sorry, we were not able to find any models when searching with "f5857-900". Please check the model number, and if you are still not able to find any results, contact our customer service department at 1.330.499.9499.
Posted on May 22, 2008
  • 107 Answers
SOURCE: NO DIRECTIONS FOR HOW TO ATTACH AND USE STAIR TOOL FOR MY HOOVER
Here is the link to Hoover's manuals. I could not locate a model F5900-900 But i believe it is F5914-900. Please verify before downloading manual by checking the serial number stick for a model. Its silver and should be on the back or bottom.
Posted on Dec 09, 2008
  • 3 Answers
SOURCE: Hoover SteamVac F7222-900 steamvac Brushes do
Solution for Hoover SteamVac (F7452-900) brushes not spinning
Uses the turbine model and same solution would be similar. Root cause is simply the main gear attached to turbine becomes stuck. This problem should not happen as often as I see other people also having this problem. Must be a poor design on Hoover’s part. It takes about 30 minutes and a Phillips screw driver and wrench. Pretty easy, just have to remember what screws went where.
Remove brushes, and front suction cover
On the bottom of the machine:
Remove the 4 screws behind brushes which attach the top faceplate
Remove the 2 screws from base in the sunken holes
Remove the two long silver screws from base which connect all the way to turbine assembly
Stand machine upright
Remove the floor select switch handle
Remove 1 screw near the center beside the intake hole
Remove the 2 screws over the rear wheels
Remove faceplate cover, the front will need to be gently pried over the clear plastic part, be careful about the upright disengaging lever under faceplate, move it under the metal wire
Remove the 2 screws in the front of the turbine assembly
Remove the 2 hoses on either side
Disengage the bar on the floor selector switch
Pull out the turbine assembly
Remove the 4 screws and 3 clips to separate the assembly
Remove the filter (which is most likely clean since, cleaning this is the manufactures only solution)
Remove the large white gear and with a wrench remove ball bearing
Remove other large white gear
Note that the metal gear attached to turbine will not move (this was my problem), with a wrench gently grab metal gear and twist free. Spin turbine to make sure it moves freely.
Put everything back together again and you should be good to go.
Posted on Jan 24, 2009
CorvetteKing
  • 108 Answers
SOURCE: lost manual for hoover steam vac
You can find that manual on hoovers website (hoover.com) it is under customer service/parts.
Best of Luck
Posted on Jun 14, 2009
AV Nerd
  • 4 Answers
SOURCE: Hoover SteamVac Agility
Press the handle release kick-button with your foot, extend the handle all of the way back, and take a look at the gap between the base of the unit and the handle/reseviour assembly. You should see several black hoses attached to the base and running up into the handle assembly. One of them (the dirty water return hose) might be cracked. Turns out that might be a common problem with this model. We had the same problem.
Judging by the interference between the vacuum hose and the "dirty water return" hose, there is NO WAY those two hoses can exist together in that housing without causing the dirty water return hose can last for many full bends of the handle. We opted to not repair our unit, but you might be able to do it yourself for the cost of the part and several hours of your time. Otherwise, seek out your certified Hoover repair center for more info.
Posted on Jun 18, 2009
LS 3500 instruction manual
Hi there! Follow the link to view the instruction manual for the Hoover Steamvac. http://hoover.com/file/610/
Hope this helps!
Sep 22, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Owner's manual for hoover silver steamvac 5858-910
go to www.hoover.com and go to customer service support and download your mode for free or go www. retrevo.com
God bless you
Jul 14, 2012 | Hoover SteamVac Carpet/Upholstery Deep...
I have a Hoover F7458-900 steamVac all terain. I
You can reach under the brush (on top) and pull down. The manual for an all terrain is here to download
F7452900
Apr 10, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
How do you start using the F5815 Hoover Steamvac? I can not find the direction manual.
This link should help
http://www.fixya.com/search.aspx?cstm=0&_s=F5815+Hoover+Steamvac+Manual
Jim
Nov 29, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
How to clean my Hoover steamvac brushes? or
http://www.hoover.com/pdfs/manuals/F5914900.pdf
Press all four latches (B) and pull brush
block out. The brushes can be cleaned
under running water
Godbless
Jun 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Lost manual for hoover steam vac
Best of Luck
We need the OPERRATING MANUAL for Hoover Steamvac 6020-900
download the manual for hoover F5810 at hoover.com. it's the same for your model.
Jan 20, 2009 | Hoover F6020-900 SteamVac Upright Vacuum
May 21, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
119 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
