Question about Kenwood PAC C130EK 13000 BTU Portable Room Air Conditioner PACC130EK
Vent blows hot air needs vent - Kenwood PAC C130EK 13000 BTU Portable Room Air Conditioner PACC130EK
I have a 2003 Tahoe and when I put the heater on only the driver side get warm passenger side blow cold air
2004 Chevy Tahoe. Hot air out of vents on driver's side, cool ...
answers.edmunds.com > Edmunds Answers
Jun 25, 2009 - Hot air from vents-driver side and cool air from vents on passenger side. ... The driver's side vents were blowing out hot air, and everything else wasblowing cold. ... you'll literally have to restart your tahoe/yukon at every traffic light to keep cold air coming ... I was also getting air only out of the defrost vents.
Hot air out front drivers side vents 05 escalade - YouTube
? 3:14
https://www.youtube.com/watch?v=5lnd8UNcx6M
Aug 3, 2013 - Uploaded by South FL Mud Club
Suddenly hot air started blowing out the air vents only on the drivers... ... is a very helpful video ,I wondering if this part number apply for my 04 chevy tahoe? .... I have cold air out of thepassenger side, but warmer air out of the driver's side. .... 2003 Tahoe No Rear Heat Fix, Suburban, Yukon XL Repair!
Heating and AC Temperature and Air Delivery Mode Door ...
repairpal.com > Problems > Chevrolet > Tahoe
Driver/passenger air vents blow hot then cold when using A/C. Back to cold when you restart the vehicle. Upvote (35) ... 2003 Chevrolet Tahoe ... I have a 02 Tahoe ,and the heat system is working only on the ceiling side of the car when turn.
2004 Chevrolet Tahoe Blows Hot Air - Sparky's Answers
Jan 21, 2016 | Cars & Trucks
2002 Lincoln Town Car I have hot air blowing from the vents.
Check you blend door under the glove box see if its opening and closing
Apr 03, 2014 | 2002 Lincoln Town Car
Hot air blows into car from underneath of car what is causing this
does the air blow in when the car is not moving. if it does, your heater switch is on and blowing hot air in through the bottom vent.
Apr 01, 2014 | 1997 Ford Taurus
Bmw defroster blows hot air/vents only blw cold air
These selections are run by Engine vacuum. sounds lie a diaphragm is NG to control the lower door
Jan 08, 2014 | BMW Cars & Trucks
Left Vents blow warm/hot air when calling for cold air
Usually a sign of a faulty blend door under the dash.
The blend doors direct air thru the ac and heater core along with the upper and lower vents.
Sep 12, 2012 | 2009 Chevrolet Silverado 1500
The air conditioner is blowing hot air, there is no water to drain
if it is also blowing cold air out of the other vents you need to vent the hot air its blowing outside
Sep 30, 2010 | NewAir ACP-1000E Portable Air Conditioner
2003 kia van rear air blowing hot
it should ony blow hot from the vent on the floor. this is controlled from a button on the dash labled RR HEATER. if the vents are blowing hot from the roof its another problem. let me know if you need more help
Apr 09, 2010 | 2003 Kia Sedona
Heater control stuck blowinf hot air out vents
did you cheked if there is enough refrigrant ( freon ) in your tubes by measuring the pressure . if there is you may need to check your condensor its may be clogged and not letting enough air comes through to cool the refrigran
May 31, 2009 | 2000 Chevrolet S-10
Center vents cold side vents hot please help bthibs
hello,good day,seems your recirculating pump need tobe check,ty
May 15, 2009 | 1996 Mercedes-Benz C-Class
Heat wont blow through heater or defroster vents
common problem, check under dash by the gas pedal if control arms are muving went selecting from ac to heat cuz this it is the control for the vents to go from ac to heat and to defrost.
Jan 18, 2009 | 1997 Chevrolet K1500
Kenwood PAC C130EK 13000 BTU Portable Room Air Conditioner PACC130EK Logo
46 people viewed this question
Top Kenwood Heating & Cooling Experts
ray gallant
Electro Med Services...
Are you a Kenwood Heating and Cooling Expert? Answer questions, earn points and help others
