Question about Garden
I had the same model and always had a hard time getting it to start after taking it to shop it started three times ok then the hard to start all over again. It now is in the trash as I refuse to put any more money into it. Stihl makes a great chainsaw but I would never buy another trimmer or brushcutter from them again.
Posted on May 17, 2014
SOURCE: STIHL FS110R weedeater won't start, does not hit
my son flooded out my stihl weedeater, I took it had a new filter put in and it started right up. he went to use it again and now it wont start! It sat overnight and i still can start it! Any suggestions please
Posted on Jul 06, 2009
SOURCE: how to replace coil on stihl fs85 weed trimmer
Remove the starter & cylinder cover and look for the coil mounted next to the flywheel. Remove the 2 screws holding it to the cylinder and cafefully pull the wires through the clips that hold them to the block. Install the new coil in the reverse order and set the air gap between the flywheel and the coil with a business card. Let the magnets on the flywheel pull the coil towards it with the business card in between. Tighten the screws and spin the flywheel to remove the card. Reassemble the stater and blower housing.
Posted on Sep 17, 2009
SOURCE: no manual, starting stihl fs 38 brushcutter
Here is the owner's manual.
Posted on Dec 17, 2009
SOURCE: Stihl FS85 Weedeater
stihl pro fs85 weedeater starts up shuts right off Will not stay running
Posted on Jul 26, 2010
SOURCE: Edger won't run. replaced fuel, air filter and
Check your fuel filter in the fuel tank to make sure it is clean if it is then"
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 12, 2010
Feb 08, 2016 | Stihl TS420
Dec 26, 2014 | Stihl Fs80 Fs85 Fc85 Hs80 Ing Coil Assy...
May 23, 2013 | Stihl FS 85 Weed Eater
Jan 16, 2013 | Stihl Ms290 Ms310 Ms390 Air Filter &...
Sep 17, 2012 | Stihl FS 85 Weed Eater
Jun 29, 2012 | Stihl Garden
Mar 26, 2010 | Saws
Jun 06, 2009 | Garden
Sep 17, 2008 | Garden
132 people viewed this question
