Nashuatec dsm725 service mode sc 120 - Office Equipment & Supplies
3 Suggested Answers
santosj27
  • 263 Answers
SOURCE: I have Nashuatec SDM 616 photocopier. I was doing
This code is related to a current leak in the Charge Roller.
The first thing i advise you to do is clean the plug of the PCU (fotoconductor unit) and of course the PCU.
If you take out the PCU you will see a metallic pin and a spring (in the back of the machine). Clean it or vacuum it (could be dust of toner).
This should be it.
If that doesn't work you probably have a defective High voltage supply board.
Hope that helps
Posted on Mar 03, 2011
Cogz
  • 1326 Answers
SOURCE: meaning ofSC 400 Nashuatec C2030 aficio
Nashuatec is made by Ricoh.. SC400 means that there is a problem with the fixing unit.
Posted on Jun 09, 2012
How to clear error code SC302, Dsm615 nashuatec
Yes, mine were successfully RESET from the error code SC:552 and SC:302. Machines runs good, but i about to wander what could be faulty inside, it took one month after error code 302 exist. Mine was exactly DSM615 same model same error code 302 (this is really 302) which resolved by reset. Hopefully machine will run good for two months.
To RESET it
1. Press Yellow button
2. Press 1, 0, 7
3. Hold Orange button for 3 seconds
4. Select MODE 5
5. Select Clear Memory (or something like it) (801)
6. Select 002-Engine
7. Select EXECUTE
8. Turn the switch off and leave it for a minute
9. Turn back machine On.
10. Done, or else there could possibly something else.
Good Luck....
Thanks for using Fixya.
Mar 04, 2013 | Office Equipment & Supplies
Meaning ofSC 400 Nashuatec C2030 aficio
Jun 08, 2012 | Office Equipment & Supplies
How to reset MP161 Ricio
The Ricoh Aficio MP 161 LN give error code - SC 302
Please adivse
Nov 21, 2010 | Ricoh Aficio MP 161 Black and White Copier
Nashuatec 2205 ATICIO problem SC 542
nashuatec 2205 equivalent to ricoh 1022/220 and the problem of sc542 means that you termistor is out of order. Don't panic,with little patient you could solve it.
Firstly,switch off the machine, then take out the fuser unit after you open the lateral door. Below the unit,you will see 2 termistor unit with red contact.Replaced it both with new unit.Reinsrt it the fuser unit back and closed the lateral door.
Switch on the copier, you must go in sp mode . First
push the yellow[c] button follow by button1,0,7 then
push red button[cancel] for several seconds until you in sp mode revealed by the screen.Switch off the copier for 1-2 minutes then switch it on,wa la it working back. It will cost you compare to calling the technician
Apr 15, 2010 | Ricoh 6513 Copier
I HAVE A PROBLEM WITH MY COPIER,NASHUATEC D435.
Enter in the service mode(SPmode),open the front cover and turn OFF the copier.Unpluged the machine,wait 10sec.amd pluged ON.Before clean the thermistors and thermofuses in the image fusing unit.Close the front door and turn ON the copiers.
Feb 08, 2010 | Ricoh Aficio 450 Copier
How to clear error code,sc542 nashuatec photocopier-mp6500
01. Press Clear/Stop Key (Yellow key) 2 tram
02. type 107
03. press Hold down Clear key 5 secend ( Red key)
04. type 5 and press # or Ok
05. type 810 and Press # of Ok
then machine Of and On
Jan 14, 2010 | Ricoh 6513 Copier
I have a nashuatec D445 and it is indicating an error code CS 547-00 what can i do to solve this problem?Please help.
Press 'Function Clear', 1, 0, 7, then press and hold 'Clear/Stop' button for 3 secands. Machine displays SP Mode. Now turn MAIN power switch off for 5 seconds. Turn MAIN power switch back on. This should reset SC 547 code. (Main power switch is located on the left side of the copier)
Dec 15, 2009 | Ricoh Aficio 450 Copier
Error code
This didn't happen on it's own. The mode has to be enabled in service mode, as well as a jumper on the MPCB has been cut in order to enable this mode.
Mar 28, 2009 | Ricoh Office Equipment & Supplies
15 people viewed this question
jasbo
jasbo
