Question about Minolta Office Equipment & Supplies
Konica minolta bizhub 3010 cof 32 - Minolta Office Equipment & Supplies
  • Minolta Master
  • 6,161 Answers
When was the last time the developer and drum where replaced? Does the machine say "REPLACE DRUM in the upper left corner of the operation screen? More then likely your drum and developer need to be replace if not those then the DEVELOPER CARTRIDGE NEED TO BE REPLACE when was the last time that was replaced? Every four drums the developer cartridge needs to be replaced. When the developer was replace was a F8 run from service mode?
Posted on Dec 29, 2014
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
Posted on Nov 19, 2007
  • 8 Answers
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Posted on Feb 02, 2008
Bubbabear64
  • 2794 Answers
SOURCE: konika minolta
CDC##  Appears to be trouble related to security.
The only solution is to contact Konica Minolta to find out what needs to be done to resolve the problem.
That is only solution the service manual has provided.
Posted on Nov 07, 2008
oranous_comp
SOURCE: proplem with KONICA MINOLTA bizhub C450
c-3451
Posted on Nov 10, 2008
  • 10 Answers
SOURCE: service manual for KONICA MINOLTA Bizhub 210/162
Swithc off the machine Press stop button and hold switch on the machine. problem will go.
Good Luck
Posted on Jan 07, 2009
Where can this part for the printer be purchsed ? konica minolta bizhub 160
Except you don't say what 'this part' is :>)
Never mind. Here you go. Or look in Yellow Pages for a technician.
  • Konica Minolta bizhub 160 Supplies and Parts (All) www.precisionroller.com > ... > Konica Minolta > bizhub 160 Konica Minolta bizhub 160 Supplies and Parts (All) for less. Free shipping on orders over $75.00!
  • Konica Minolta Bizhub 160 Toner, Parts, Supplies, and ... www.arcservicesco.com/1016/konica-minolta-bizhub-160-i-toner-parts... Additional Info Konica Minolta Bizhub 160 is a Digital Printer and Copier which was introduced February 10, 2012. Suggested Retail Price:$1,029
  • images of konica minolta bizhub 160 parts bing.com/images th?id=oip.mcd31c057681b6e2e393bc136df5885ddo0&w=140&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.m850c92a4f48e9107608f3f81e06b2feeo0&w=99&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.mdb0ced5306197a197806530dbb355967o0&w=74&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.mb7d2a296bf50d1a0bb42098505ce2c61o0&w=133&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.maedc8ec17eba695445679a648922e7e3o0&w=70&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2 See more images of konica minolta bizhub 160 parts
  • Konica-Minolta bizhub 160 160f 161 161f Parts Manual www.qmanual.com/printer/konica-minolta-1/bizhub/konica-minolta... BRAND: KONICA-MINOLTA: BRANDSKU: No: TYPES: Parts_Manual: SIZE: 1.49M: PAGES: 35: FORMAT: PDF: LANGUAGE: English: QUALITY: High resolution: ...
  • Konica Minolta Bizhub 160 Printer / Copier Parts & Supplies https://discountcopiercenter.com/konica-minolta/bizhub-160.html Save big on Bizhub 160. We offer the lowest prices and highest quality, with free shipping on any orders over $100!
  • Konica Minolta bizhub 160 Parts Guide (160_PARTS) www.atec.ro/parts.../konica-minolta-mfps/konica-minolta-bizhub-160... Konica Minolta bizhub 160 Parts Guide; PN: 160_PARTS
  • Apr 01, 2016 | Konica Minolta Office Equipment & Supplies
    C550 cooling fan not functioning, what can i do to make work?
    Konica Minolta bizhub cooling fan not working Questions ...
    www.fixya.com/tags/cooling_fan_not_working/printers/konica.../bizhub
    Konica Minolta bizhub printers & copiers cooling fan not working related questions and answers. Ask your Konica ... Question about Bizhub C550. 1 Answer ...
    Konica Minolta Bizhub C550 Cooling fan power - Questions ...
    www.fixya.com > ... > bizhub > Konica Minolta Bizhub C550
    konica minolta bizhub c252 error c-5351 C - 5351 Is power cooling fan problem.Verify the cooling fan connectors and clean.For reset open/close the front door.
    cooling fan not operating properly - HP Support Forum
    Nov 29, 2015 | Cars & Trucks
    Bizhub 2510earer coad cobao
    The FN finisher unit elevator motor malfunction.Remove the finisher unit and work with out.
    Jul 22, 2014 | Konica Minolta Clutch for Di3510 3010 2510...
    My konica gives me an error code of cof 32
    Need the change a developer.After 40000 copies the developer,OPC drum,Drum cleaning blade and the imaging unit fuser(SOME MODELS) need to change.Please the copier model for another instructions.
    Jul 17, 2014 | Konica Minolta Office Equipment & Supplies
    Minolta Di152 how do i reset error code cof 32 for developer
    Has the developer been replaced along with the drum They are normally replaced as one. If not that is why it is coding out. If not with power off then on have tech come out and replace the developer and drum mite require the sensor in the developer cartridge mite be bad.
    Apr 29, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
    Apear COF 32,
    replace the drum and the developer
    Jan 06, 2014 | Konica Minolta bizhub 180 All-In-One...
    61 people viewed this question
    Top Minolta Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    CheckitRight
    CheckitRight
    David Burkhart
    David Burkhart
    Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
