Sony mhcgnz8d front speakers r not working
Sony mhcgnz8d
Order a new one from Sony service department.
May 26, 2014 | Televison & Video
Sony ta av431 Stereo Amp Front speaker do not
Have you check your sound configuration at front panel?
Oct 09, 2013 | Audio Players & Recorders
How to hook the speakers with the sony STR-DE405
I have a Sony STR-DE405. The front speakers are connected to the FRONT SPEAKERS A terminals L and R. If you are installing surround speakers, they are connected to the SURROUND SPEAKERS terminals LR, RR, and center (front). This model does not have an active wooker connection. The FRONT SPEAKERS B terminals are for connection of a second set of front speakers
Dec 09, 2012 | Audio Players & Recorders
How do i connect my klh bassbite V subwoofer to my sony receiver model str de335?
http://www.docs.sony.com/release/STRDE335.PDF
I am basing hookup on my Bassbite !! manual. The procedure should be the same as on your Bassbite V
I have given you a link to your Sony Owner manual. It looks like you will connect your sub to the sub output on the rear of your reciever using the rca cable. Woofer out on the Sony to the R/Mono input on your Bassbite. If you have the front and rear speakers hook your rears into the rear speaker outputs then connect your front speakers to the front speaker outputs of your Sony. Your speaker jacks on the Bassbite will not be used for this configuration.
Now, adjust your speaker size setting for "SMALL" or "LARGE" speakers as appropriate for your setup (this is for the front and rear speakers and will not effect your Bassbite). Now set your Sony subwoofer output to "ON" You access this setting through your menu. That should be located on your remote for the Sony. You will want to refer to the manual to find the exact method to access your system menu.
If the link to your manual doesn't work for you then go to http://esupport.sony.com/US/perl/model-documents.pl?mdl=STRDE335 and click on Operating instructions.
Hope this helps. Let me know okay? By the way, if this works for you you should be very pleased with the sound quality :-)
Kindly, DAVID (sean1dave)
Feb 26, 2011 | KLH ASW10-120 Subwoofer
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
Car front two speakers arent working. rear two are.
have the front speakers ever worked?
if not have they been connected properly?
if yes then
look under ballance and check theat rear and front ballance is in the middle
if it is then for temporarily replace the front speaker with any old speaker
if that works then you need new front speakers
if no then the radio is broken
but what you could do is rewire the back speakers so they also play though the front ones too
this can be done from behind the radio
find the rear right positive and negative wires
strip the insulation but dont cut the copper wire
cut the front right speaker and attach that to the rear speaker wire
do this for both positive and negative
rear right
positive
..v
..v
I...I
I...I
I...I
.I.I..........< strip cable but do not cut metal
.I.I..______________
.I.I=_______________ <<<front right positive
.I.I
I...I
I...I
I...I
I...I
Jan 06, 2010 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
Out put to the back speakers are low
Check your fader control on the unit maybe it has been adjusted to supply more power to the front speakers.
Dec 27, 2009 | Sony Car Audio & Video
Sound only some out of 2 speakers at a time. I need all 4.
Here you go buddy:
http://www.docs.sony.com/release/STRDE685.pdf
May 19, 2009 | Sony STR-DE685 Receiver
I have a Sony STR-DE635. It has a switch on the front for speakers A, B, and A+B. Normal. When I am on speaker A only, it works fine. B does not work. A+B works, but only through the A speakers. Now,...
Check for bad solder connections on the speaker switch or where the speaker switch board connects to another board. Not an uncommon problem with some Sony receivers.
Feb 25, 2009 | Sony STR-DE845 Receiver
32 people viewed this question
 Grubhead
Grubhead
